Old 7th August 2011, 23:12   #151
Thanked: 595 Times
Default Re: Offroading with Thar DI: The Sensible Option
Originally Posted by ex670c View Post
Hi Parm,
Do you thinks it is safe to fit an IFS/Rack & Pinion Steering (Thar CRDe( for a Solid Axle Vehicle (Thar MDI)?
Arka
for the rack and pinion to work correctly it must be mounted to the axle?
and it will give you horrible Bumpsteer with a Solid axle?
Parm is offline   Reply With Quote
Old 8th August 2011, 09:33   #152
ex670c's Avatar
Thanked: 1,799 Times
Hi Parm,
If the Rack and Pinion Steering Unit is mounted on the axle (solid axle) how will you connect the steering rod/Pipe from the steering wheel?
Arka
Old 8th August 2011, 10:27   #153
Thanked: 595 Times
you got it wrong Arka, i just asked that question, it was not a reply from me!
Old 8th August 2011, 22:56   #154
nnn
Thanked: 11 Times
Hi Parm,
Arka
Arka,
Sorry to answer the question you asked Parm and that too with a request for your thoughts.
I believe that it would possibly not be safe, though I have seen photographs on this forum of people doing it. The toe in and toe out will continously keep on changing with resulting tire wear and instability. How much I don't know.
For a sprung axle the Tie Rod keeps the Toe in and Toe out constant as the tie rod floats with the axle. I believe, the fixed axle requires a steering box with a drop arm turning one ackerman arm to steer one wheel and a Tie Rod to correspondingly steer the other wheel in keeping with the ackerman principle.
I believe, that the IFS is pnly compatible with a chassis mounted rack and pinion steering matched to the wishbone setup. Without going to the books, logic says that the Tie Rods on both sides should be under the point where the wishbone hinge to eliminate the mismatch in geometry.
Would love to know more for the experts.
nnn
nnn is offline   (1) Thanks Reply With Quote
Old 8th August 2011, 23:20   #155
Thanked: 595 Times
Originally Posted by nnn View Post
Arka,
nnn
nnn, since im going for Thar MDI, the PS just came as a thought, but im comfortable with the Thar MDI without PS.
since it would be a secondary vehicle for farm work and OTR only.
as Arka said, the MDI is still too basic in stock form and needs some upgrading for the OTR and otherwise.
my budget of 5L for the MDI could be extended to accomodate the upgrading, i would be happy even with it in its stock form as it serves my needs, atleast it would be factory build vehicle and not an ex army re build with frequent trips to my neighbourhood workshop for breakfasts!
Old 8th August 2011, 23:44   #156
nnn
Thanked: 11 Times
nnn, since im going for Thar MDI, ...
Parm,
The Thar MDI should be brilliant in standard fit.
The Second hand ones will always be unreliable. Plus the effort and risk getting one readied is just not worth it. The reworked Ex-Army may end up costing the same as a new MDI.
I believe an MDI will be as good a drive as the Thar Crde for normal use, far cheaper to use (fuel consumption and repairs) and practical. I don't feel compelled to rush at 125 Kmph on the highways, which the Crde can achieve. The lower Fuel concumption of the MDI will be a great benefit with further expected increase in diesel prices.
Please may I request your feedback if you buy one. I may like to change our Gypsy with an MDI.
nnn
nnn is offline   Reply With Quote
Old 8th August 2011, 23:45   #157
AWD
Thanked: 218 Times
Param, you choosing 4x2 or 4x4 version?
What about A.C. Is it easily doable in Di?
AWD is offline   Reply With Quote
Old 9th August 2011, 00:05   #158
Thanked: 595 Times
im sorry i should have mentioned the version.
its Thar MDI 4WD.
im not worried about the AC or PS. i think the AC is doable, since the set up is similar to Bolero DI.
Old 9th August 2011, 08:58   #159
DirtyDan's Avatar
Thanked: 746 Times
Hi Parm,
Arka
Arka, couldn't you use a splennex offset equalizer to align to the Pitman rib and use a jig to hold the two until the glue sets?
DirtyDan is offline   (1) Thanks Reply With Quote
Old 9th August 2011, 09:36   #160
AWD
Thanked: 218 Times
its Thar MDI 4WD. think the AC is doable, since the set up is similar to Bolero DI.
Yet to come across someone on the Board who got it done(AC) in Di! If Im not wrong, think read somewhere about AC in Di being a difficult job, maybe it was BD.
Old 9th August 2011, 18:07   #161
cool_dube's Avatar
Thanked: 372 Times
How much does the Thar DI 4x4 cost on-road in Bangalore?
cool_dube is offline   Reply With Quote
Old 9th August 2011, 21:37   #162
Dunno about B'lore but the break-up in Cochin after the price hike last week is as follows for Thar DI 4wd:As on 09/08/2011.(Waiting period -around 06 months)
Vehicle price-Rs 5,03,400.00
Insurance - Rs 15,515.00
Road-Tax Rs 40,280.00
Registration Rs 3000.00
Total Rs5,62,195.00
Ronnie Zach is offline   Reply With Quote
Old 10th August 2011, 14:44   #163
carrot_eater's Avatar
Thanked: 101 Times
You can't register the DI in Bangalore because its BSIII. Guess quite a few at the dealership will tell you that it can be - but you legally can't - Unless you find someone who has an address outside of Bangalore city limits and register in his/her name.
carrot_eater is offline   Reply With Quote
Old 11th August 2011, 19:35   #164
Thanked: 4,673 Times
Dear AWD - correct. .
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 11th August 2011, 23:21   #165
AWD
Thanked: 218 Times
correct.
Is it more difficult than on Crdi?
Is A.C. setup in Di different from Bolero?
Mahindra Thar Gets a Deserving 1st B'Day, Offroading in Wayanad!! dhanushs 4x4 Excursions 18 20th January 2012 11:35
Corolla to Civic - Sensible lateral upgrade? flipsyde Sedans 41 23rd March 2011 14:49
Is buying an e60 530d highline (new) a sensible option? nirmalkrishnan Luxury, Imports & Niche 22 12th September 2010 10:16
Seating Position / Option while offroading on inclines (at roll angles >30 degrees) Tejas@perioimpl 4x4 Technical 2 19th January 2010 14:56
