Old 29th March 2011, 07:08   #121
Thanked: 822 Times
Talking Re: Offroading with Thar DI: The Sensible Option
Originally Posted by jeepster View Post
& i know the reason for the weight is more & 7 seater configuration.
Hmm , not that simple . Your thinking is not wrong but there is another angle for that .
Class/category of vehicle changes by weight , seats etc . & so will change the other mandatory requirements( necessities/formalities ) ,
Now effectively you will find the Jeep sitting next to SX 4 0r Honda city( may be , in legal terms ) & that translates to more costs
Or you will find it in commercial class , then its out of the OTR scenes .
Nikhil , its time to study law books , so next time you come to Pune there is a mandatory visit to a book shop ,( non auto books ) Dont worry , I will take you there.
Sudarshan
Sudarshan is offline   Reply With Quote
Old 29th March 2011, 08:35   #122
jeepster's Avatar
Thanked: 984 Times
Default Re: Offroading with Thar DI: The Sensible Option
i was referring about this aspect only raju bhai.
weight is to comply ECC/CMVR norms under M1 category.
& more people on bord are for less excise duty. (same reason for creating mm 650/750 LWB's in 80's~90's)
jeepster is offline   Reply With Quote
Old 29th March 2011, 08:46   #123
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
What is ECC? ^^. What essential criteria differentiates M category with N category?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 29th March 2011, 09:38   #124
jeepster's Avatar
Thanked: 984 Times
key difference between M,N categories is GVW.
its EEC not ECC.
Old 29th March 2011, 09:58   #125
Thanked: 757 Times
^^ Oh OK EEC, is GVW the main difference?
Spike
Old 29th March 2011, 10:11   #126
ex670c's Avatar
Thanked: 1,799 Times
Dear Santosh - You have become an expert, but please read only one lonnnnnggggg sentence below:
A typical AC installation requires a compressor, that compressor has to be driven by the engine via the crankshaft pulley, then it becomes a natural requirement that the compressor must be mounted in such away that the belt line of the crankshaft pulley and the compressor pulley must lie in one plane, then it becomes natural to presume that the compressor would be mounted on the lower side of the engine in order to keep belt length small, then you would open the bonnet and look at the obvious mounting locations, then you would realize that this thing has a rigid axle which would move up and down and occupy precious space, so your eyes would move to the top of the engine, so you would want to mount it next to the rocker arm cover, then you would realize that there are not enough supporting points to locate the compressor here, then you would also realize if you could find place to fit the belt at all, the belt length taken from the crank shaft pulley would be very large which would result in belt whipping, then you would think of driving the compressor off the water pump pulley, then you would realize that the water pump pulley has a single groove, then you would think of making a double groove water pump pulley and even if you got away by mounting like this, you would ruin the water pump bearings prematurely. Whew! That was only a very small part of the compressor mounting DFMEA (Design Failure Mode Effect Analysis) and I have not yet really started the DFMEA. I think you have got the message. Next - where does the blower unit go? Where does the condenser go? Even if you somehow manage to do the whole thing, what would happen to the acceleration with a 3.73:1 axle ratio? Then, you would try and change the axle ratio as many of our common friends would advise you to do, maybe also a bigger length of axle with the great "FFRA", also with "something something" which may finally give you "nothing nothing" ????? .
Hi DB Sir,
IIRC the Bolero MDI3200TC is fitted with the A/C we can surely apply after-market parts bin assembly line technology and engineering.
w.r.t changing the differential ratio in a DANA 44 is pretty simple made simpler by the fact that the MDI3200TC has minimal electronics, governing the fuel pump.
Besides the 2010 NGCSMM550 (new Army JEEP (MDI ) is fitted with some of the above, excluding A/C of course.
Arka
PS - You only have to guide us.
Old 29th March 2011, 10:26   #127
jeepster's Avatar
Thanked: 984 Times
i had read some where about the weight difference, it also depends on engine power, privet/commercial use, no. of passengers etc.
i remember the post of Behram sir in crde thread about Thar with yellow no. plate without M1 spec's.
& spike. dont my leg , please give me a link where i can get clear information about vehicle categories.
(L1 ,L2, L1BOV ,L2BOV, M1, M2 ,M3, N1, N2, N3)
Old 29th March 2011, 10:32   #128
Thanked: 757 Times
@Jeepster you will find most things here:-
https://www.araiindia.com/
Spike
Old 29th March 2011, 14:19   #129
headers's Avatar
Thanked: 459 Times
Sir, it is really great that DFMEA and PFMEA is applied. It would be wonderful, educative (and entertaining for some) if you could share the table along with the RPN values.
Old 29th March 2011, 14:22   #130
Torque-ative's Avatar
Thanked: 54 Times
Originally Posted by ex670c View Post
Hi DB Sir,
Arka
Wait a min. are you implying the 2010 MM550 is the same as the Thar MDI,.albeit with different suspension mounts for the 7.5 x 16 sandgrips.
Hmm...if true then for the first time the civilians get the same jeep as the Army from the MM range!
Torque-ative is offline   Reply With Quote
Old 29th March 2011, 16:15   #131
svsantosh's Avatar
Thanked: 1,392 Times
Agian, no
Because... I didnt know of the 'looong line' earlier...
Now, yes.
But I still feel some Mallu/Coogi will show us how to AC a 4x4Mdi Thar very soon... Clue already provided by Arka.
svsantosh is offline   Reply With Quote
Old 29th March 2011, 16:35   #132
sreejeshmp's Avatar
Thanked: 571 Times
SVS,
One AC fitted Major 2WD MDI is there in my place Let me check for the details.
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 6th May 2011, 15:39   #133
jeepster's Avatar
Thanked: 984 Times
yesterday i saw a Champagne colored 4x4 MDI with 6x16 NDMS tyres.
no pictures. (was going for my EXAM)
will try to contact the owner & get a feed back.
(AFAIK this may be the first 4x4 sold by mm here from last 10+ years)
Old 15th May 2011, 12:38   #134
AWD
Thanked: 218 Times
Any updates? Considering A.C. fitment on Crdi is not smooth either, one can choose lesser of the two Evils!
AWD is offline   Reply With Quote
Old 28th May 2011, 17:42   #135
jeepster's Avatar
Thanked: 984 Times
this thar mdi is bought by our city's airport company.
Name:  28052011022 Medium.jpg
rgds,
Nikhil
Mahindra Thar Gets a Deserving 1st B'Day, Offroading in Wayanad!! dhanushs 4x4 Excursions 18 20th January 2012 11:35
Corolla to Civic - Sensible lateral upgrade? flipsyde Sedans 41 23rd March 2011 14:49
Is buying an e60 530d highline (new) a sensible option? nirmalkrishnan Luxury, Imports & Niche 22 12th September 2010 10:16
Seating Position / Option while offroading on inclines (at roll angles >30 degrees) Tejas@perioimpl 4x4 Technical 2 19th January 2010 14:56
