Thread Tools
Old 14th February 2006, 10:34   #1 (permalink)
Default Need some Advice on my Car Audio
Hi, I need advice regarding my audio set up in my car. I have just bought a Swift. And my budget is 40k. I spoke with few people here in Bangalore and they have suggested me the following:
HU -> Pioneer 5750/6850 (Rs.7400/10500)
Front and back speakers-> Boston/Lighting Audio Component speakers (Rs.5500/7500) x 2
AMP-> Sony-4 Channel (Rs.4500)
Sub Woofer-> Pioneer-800watt (Rs 3000)
Installation-> Rs. 5300
PLEASE tell me which speakers are better Boston or Lighting Audio. (i am told Boston requires drilling a hole in all my doors).
Also PL tell me whether 5750 is good or 6850. People here are asking me to go for 6850 as it has 3 RCA outlets. The Pioneer web site clearly says 5750 also has 3 outlets.
PLEASE let me know which is best configuration within my budget.
Thanks!
Satish
satishri is offline   Reply With Quote
Old 14th February 2006, 10:53   #2 (permalink)
mclaren1885's Avatar
With a budget of 40k id sincerely suggest u to look at an alpine HU .. They are more refined/laid back in terms of sound quality .. Navin shall give u further updates with the model numbers ..
As far as the amp is concerned , i think u ought to go for a better amp than the sony 504 .. This amp is the most basic amp in the indian market now and seems to be the weakest link in ur setup .. Look at pioneer 6100 .. Its a decent buy at 7k ..
As far as the speakers and sub are concerned a better thing would be to go in for known brands such as alpine , JBL and blaupunkt .. However , as ur in bangalore i suggest u visit TMC Electronics and check out the speakers from Hertz line-up .. I have felt these to be the next best to alpines , better than blaupunkt , boston , soundstream , LA , RF , MBQ etc ..
Installation charges arent that costly amounting to the 5.3k that u have mentioned unless u have accounted the cabling costs in that too .. At most the installer might charge u 1-1.5k for the install ..
Id recommend this setup personally :
1. alpine hu at 9-10k ..
2. alpine/hertz components for the fronts - 7k ..
3. alpine/hertz coax for the rears - 5k ..
4. pioneer 6100 4 ch-amp - 7k ..
5. wires and install - 4k ..
6. With the money left over u can decide on which sub to go for (arnd 7-9k) ..
Total : 10+7+5+7+4+7(sub+box) = 40k ..
What say navin ????
PS : I also suggest u hear all these speakers before u take a call .. Because its ur ears that need to be pleased , not our recommendations ..
__________________
I am proud of you, binzy boy !!! Keep up the good work.
Old 14th February 2006, 11:22   #3 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by mclaren1885
With a budget of 40k id sincerely suggest u to look at an alpine HU...Navin shall give u further updates with the model numbers
visit TMC Electronics and check out the speakers from Hertz line-up .. I have felt these to be the next best to alpines...
Total : 10+7+5+7+4+7(sub+box) = 40k ....
good job mclaren...
i'll just add my 2 paise worth...
a) Alpine 9847 retails for about 12-14K the 9843 is a bit cheaper at about 10K
b) I'd also check out Infinity and Boston speakers they fall in the same price range as Alpine and Hertz
Given the above this is one option...
Alpine 9847 - 14K
Pioneer 6100 - 7K
Infinity 6510cs components - 7K
Infinity 6012i coax - 5K
RCA Wires - 2K
Install - 1K
Total - 36K
optional subwoofer and amp
Sony 502 - 3K
JBL 1200T - 6.5K
RCA wire - 2K
total for sub and amp 11.5K
navin is online now   Reply With Quote
Old 14th February 2006, 11:33   #4 (permalink)
Thanks a Lot Navin and Mclaren for your response . I will certainly visit TMC electronics to make a choice as per your inputs.
Does installing component speakers involve drilling a hole on my doors. Is that a good thing to do?
Old 14th February 2006, 11:35   #5 (permalink)
Also is it a good idea to have component speakers in the front and the rear?
Old 14th February 2006, 11:36   #6 (permalink)
Oooppsie .. Yes forgot infinity ... So its alpine,infinity,hertz,boston that he might want to listen and choose from .. Like i said before it would be better to listen to all these brands and then pick from what u feel is the best rather than going by our recommendations ..
__________________
Old 14th February 2006, 17:51   #7 (permalink)
PL tell me whether its a good idea to have component speakers at the front and at the rear doors. And not install any coaxial at all...
Old 14th February 2006, 17:57   #8 (permalink)
Well actually i feel there is no need to go in for compos both at the front and the back .. I prefer using compos at the front while sticking to coax at the back .. Because the rears are used as fillers and hence must be barely audible..One must feel the entire sound coming from the front .. However i think navin would suggest to go in for compos all around , it might help gain even tonality .. But i feel its just a waste of money (atleast for me) .. Id say get compos for the front and coax for the rear , there is no harm in having compos both at the front and back however ..
__________________
Old 14th February 2006, 23:12   #9 (permalink)
jkdas's Avatar
Mcl would be right if 'you' drive. The idea is that the listener gets compos whe re he sits. So if you drive you get compos for frnt and if you get driven, compos at back.
I will opt for compos all around if one has the money. I like those Infinity ones that come in 3 piece pack.
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 15th February 2006, 07:58   #10 (permalink)
Team-BHP Moderator
navin's Avatar
Actually the rear speakers in most cases are tucked onto a parcel shelf or a pod. Only in cases like the Swift are the rear speakers in front of the rear seat passenger.
Given this the rear speaker sound is never direct it usually is indirect via the rear windshield and/or roof and usually very much off axis.
The advantage of components in the back is not only do they do a good job as fillers but teh rear passengers dont feel left out. A system must be looked at in totalilty. If one adds a simple HU + 4 speaker system with the HU costing say 8K and the 4 speakers costing 8K (5K for the front comps and 3K for the rear coax) then adding 3K more for rear comps might be a significant increase in cost but if one is has a a more expensive system with amplifiers, subs, DVD etc... then the 3K difference in rear (components / coax) is not so significant.
Old 15th February 2006, 08:24   #11 (permalink)
Speaking of speakers have a look see if you can find infinity speakers found that vocal pretty good. Their components are sweet.
gary_yuen42 is offline   Reply With Quote
Old 15th February 2006, 08:28   #12 (permalink)
Team-BHP Moderator
navin's Avatar
Sure Infinity, Boston, Focal and Alpine all fall into the same price range. One step below are Blaupunkt and JBL.
Thread Tools
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi Ask the Gurus 8560 18th August 2008 15:57
Car Audio Advice for Indica XETA aad2007 Ask the Gurus 11 29th October 2007 09:45
Budget Car Audio Advice Needed Guys thief Ask the Gurus 22 26th January 2006 13:59
advice needed: car audio in hyundai accent amit_baghe Ask the Gurus 273 24th December 2005 23:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
