Thread Tools
Old 26th February 2006, 19:06   #1 (permalink)
cooldude1988765's Avatar
Default WagonR Audio
I have a wagonR which currently has this audio setup
HU : pioneer KEH-P7035 (only cassette)
Amp: Silicon 4 channel 600W
Woofer:Premier 800 watt DVC series
Rear speakers:Pioneer 420 watt 6x9 coaxials
Front speakers:Pioneer 100 watt
CD changer: Pioneer p1280(12 cd)
Tweeters:Pioneer 250Watt (may be) mounted on the B pillar
The rear speakers and the woofer share 1 common box and i am pretty happy with the sound qaulity and loudness if i sit in the rear. What can be done to the sound in the front in a very very tight budget of say 3K MAXIMUM (wish it could be lower)
THANKS IN ADVANCE !!!!!!!!!!!
cooldude1988765 is offline   Reply With Quote
Old 26th February 2006, 19:10   #2 (permalink)
One more question: What is the difference in watt and rms
One of my friends told me 10Watt = 1 rms. Is he right ???
Old 26th February 2006, 20:36   #3 (permalink)
jkdas's Avatar
I assume your amp is powering the rear 6x9 and the woofer.
if so, let the 6x9 be powered via the HU and the front powered from the amp instead of powering teh rears. so its front + sub from amp.
and can teh wagonr take a 5incher at frnt? If you drive I recommend a compo at the frnt or teh setup above.
Unit of Power (P) is Watts. We usually go by RMS of an amp or speaker whic is Root Mean Square which is also given in Watts. Your friend maybe talking abt PMPO which is just used for marketing purposes.
__________________
-__-
Old 27th February 2006, 10:18   #4 (permalink)
navin's Avatar
Watt is measurement of power. RMA wattage is a nominal method used to crate a level playig field for all electrical items. It assume that the power is a sine wave and the average power is ROOT MEAN SQUARE.
PMPO stands for Peak Music Peak Power. What that means in numerical terms is anyone's guess. I have seen gadgets rated at 2000W PMPO producing less than 20W rms per channel at less than 0.1% distortion. I am not sure which marketing department thought up this terminology but I would not even consdier it. In fact I would not buy any product if the company even advertised PMPO power.
as far as your front speakers go...I'd suggest looking at blaupunkt GTX or JBL's CS series of speakers.
Old 27th February 2006, 13:29   #5 (permalink)
Sam Kapasi's Avatar
Nope. The wagon R has a dashboard mount (like an alto) which accomodates 4" only.
__________________
Live the YetiLife®
Old 27th February 2006, 18:43   #6 (permalink)
Thanks for the advice but does any one have an idea abt my HU (does it have 3 preamp outlets?)
jkdas says i should power my front speakers to the amp but they are just pioneer 100Watt (i think pmpo) 2 way co axials.Dont you think the back speakers will lose power
Yes i drive most of the time
Dont you think the blau and JBL speakers are tooooo expensive for my budget
Old 27th February 2006, 19:46   #7 (permalink)
jkdas's Avatar
Get a GTO426(2.5k) and power it via amp. Let the rear ovals be powered via HU and the sub too powered via amp.
It has 3 RCA preouts: selectable (front+rear+subwoofer/ front+rear+non-fading)
__________________
-__-
Old 28th February 2006, 07:53   #8 (permalink)
I am sorry but i dint understand what should i power with the amp ???
Old 28th February 2006, 08:22   #9 (permalink)
jkdas's Avatar
Power the front speakers and the sub from amp. I suggest that you replace the present front speakers with a GTO426 as the GTO426 will sing much better when powered via the amp.
__________________
-__-
Old 28th February 2006, 08:54   #10 (permalink)
Will these speakers fit in the stock provision for the wagon R
Old 28th February 2006, 09:45   #11 (permalink)
navin's Avatar
If you cant afford the GTO426 the CS series from JBL are also quite good. A friend of mine uses them in his Santro.
Old 20th March 2006, 13:41   #12 (permalink)
souravbasu's Avatar
Question Need your help to buy Car Audio System for ny new WagonR
Hi ICE Experts,
I have purchased WagonR Lxi last week without any extra accessories and want to buy a decent Audio System. I am crazy music lover and like more bass and thump.
I am planning to go for JBL Speakers (after much hunt, study and RnD in TBHP's forum) and Pioneer / Sony Headset.
Q1. What is your suggestion or feedback for this combination ?
Q2. Is there any need for amplifier right now ?
Q3. Can I add the Amplifier and the SubWoofer later ?
Right now due to financial setback I can afford to spend around 10-12K for the entire system and dont mind to buy grey market products. But I have plans to upgrade it later on.
Please help me buying a good car music system and provide me some ideas about the costings. I am Bangalore based and have initially enquired prices in JC Road for the following accessories:
HU - Sony CDX-GT350S / Pioneer (dont know the model) - Rs 6800/- (Both having same features and Front Aux for iPOD Support)
Speakers: Rear – (400Watts) Rs.3400/- for Pioneer and Rs.3600/- for Sony.
Front – (240Watts) Rs.900/- for Pioneer and Rs.1200/- for Sony.
Speaker Holding Pad – Needed to hold the rear speakers in case of WagonR (Rs350/-).
Radio Antenna – Rs 150/-
Also please let me know about a good place where I can get all this fixed to my car without damaging the MPFI Circuitry.
Looking forward for your help! Thanks in Advance !!
SOURAV
souravbasu is offline   Reply With Quote
Old 20th March 2006, 13:47   #13 (permalink)
navin's Avatar
I dont know what the MPFI has to dow with audio.
12K....
Get a HU for about 6-7K. Sony or Blaupunkt come with B&W. Pioneer with B&W is very costly.
JBL CS series are a good buy at this price range.
Old 20th March 2006, 14:06   #14 (permalink)
prince85's Avatar
Navinji, i feel what sourav is trying to say is that he wants to install an audio system in his car without cutting or splicing any of the wires and electricals. This is required especially for an mpfi car since the dealers on the date of buying the car itself warns the customers that cutting or splicing of any of the electrical wiring in the car shall void the warranty of the car.
BTW,, Sourav i feel that these days most installers use car specific wiring harness which does not involve any cutting of wires. Just tell the installer to use the harness and not cut any wires. Hope it helps and make sure you get the install done at a reputed accessories shop.
__________________
2008 - SUZUKI SX4 ZXI (Leather Option Pack)
prince85 is offline   Reply With Quote
Old 20th March 2006, 15:06   #15 (permalink)
souravbasu's Avatar
Navinji, Prince85 explained my feeling well ... Thanks Prince85 !! I was worried about hurting the MPFI Wirings. I shall now use car specific wiring harness (BOSS Brand - right ??)
Now I have this in my mind (may go for Amps and Subs later):
HU - Pioneer 6800 - (Price???)
Front - JBL 426e (Price???)
Rear - JBL 606 (Price???)
Wiring + MDF Board to fix Rear Speakers + Radio Antenna - Rs 2000
Any idea what would be the cost of the above items w/ and w/o B&W respectively in Bangalore ??
Thread Tools
WagonR LPG Audio Phase-2 Help smokie Ask the Gurus 11 23rd June 2007 10:22
suggestions for WagonR audio needed. double Ask the Gurus 11 8th May 2007 17:42
New WagonR Duo - Audio Setup bharanidharang Ask the Gurus 20 14th September 2006 12:31
car audio for wagonr DCEite Ask the Gurus 12 3rd May 2006 13:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
