| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Hey guys , im back .. So all of u might have read my thread regarding the accident i had with my zen .. Yes i am thankful to god and all my wellwishers that we got out alive without any injury scares .. Now coming back to ICE .. As u all know the zen had the following running : 1. Pioneer 7750 HU with 3 preouts .. 2. Alpine 450 - 5ch amp .. 3. Hertz ESK 130 ( 5.25") components .. 4. Hertz ECX 165 (6.5") coaxials .. 5. Hertz ES 250 D DVC sub .. 6. Audison cabling .. As u all know with the accident im very lucky that my ICE setup didnt suffer much .. But yes i did pay a price for it .. Only the right coaxial grill broke .. And the speaker got damaged and has been deformed .. So that leaves me with no choice but to replace the coax set .. Since i needed to take the amp off immediately , i had once again but no choice than cut the RCAs mid way so that i could take off the seat .. I wasnt carrying the allen key to the amps face plate and hence had to do this .. Which eventually means : 1. Need to replace the coaxials .. 2. Need to replace the RCAs , speaker wires seem to be long enough for the use on the baleno im thinking .. Now the main question being reagarding the sub.. As u all know i have 10'' and im totally spoilt by the SQ that this system gave in the zen , that punchy bass etc etc .. As im sure the 10'' wont do justice on a baleno even if put as free air , what i would like to know is : 1. Would a 12'' in a sealed enclosure do a good job , im spoilt by the tight punchy bass .. 2. Or should i go in for the 15'' in a ported enclosure .. I have a strange feeling that this would be overkill .. Anyways navin , JB , gunbir , sam fire ur thoughts out on this .. 3. Preferably now that i might be going in for a 12'' or a 15'' i think i might need a monoblock or a 2ch amp to run the sub .. I dont think the 5th ch of the 450 can drive the sub ?? Can it ?? If not what would be the ideal choices for the amp .. The rest of the system is up for an upgrade in due time but for the time being plan to use the HU , amp and the compos from the previous setup, my 1st priority is speedrun for which il be spending quite a lot on my car .. So right now on a tight budget .. So ur valuable inputs regarding the sub/amp combo required .. Feel free to point out anything that i might have left out .. Now over to navin , JB , gunbir & Mr. sameerji ( if he is around somewhere here ?! ) ..
__________________ Phoenix! |
| | #2 (permalink) |
| Senior - BHPian | You have seen the set up in my car right.. two 12" with monoblock amps.. go for it baby.. also i dont understand the point is that why are you planning on increasing the body weight of the car? no street racing?? ![]()
__________________ I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer. |
| | #3 (permalink) |
| BHPian | mclaren1885, One 15 inch sub for your baleno will not be an overkill if you are going in for the ported enclosure in your boot. The 5th channel on your alpine may not be sufficient for the 15 incher though. Like Godfather has suggested, go in for a monoblock just for the sub. On another note, read your thread about the accident, I am glad you are safe and lived to tell the tale. Take Care Mate. Cheers Santhosh
__________________ Cheers Santhosh |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| 1. why do you feel that the 10" wont do justice. I figure in teh right box it can be quite adequate. I would ask JB/Gun bir to post the recomended box volumes (sealed/ported) on this sub. 2. a 15" sub will not be overkill either. It will reall rock. I have played with 15" subs in the car (Kicker Solobaric etc..) and they can rock. Now before you sat that the above to statements sound like they contradict each other. What I mean to say is the 10" sub might be adequate givne that you already have it but a 15" sub would really rock. From wht I know the 5th channel of the 450 puts out 100W/4ohms. while it may not drive a larger sub as well as say a JBL 600.1 would it could also do a reasonable job if the 15" sub is efficient enough. So I would first try the 450 with the 10" Hertz woofer in a box and only if I felt I needed more SPL would upgrade the sub and/or amp. a) try the existing sub and amp if you want more SPL then b) upgrade sub and see if you like it but ifyou want more SPL then c) add monoblock using the 450 as a 4 ch. amp. as resale value on the 450 will at best only buy you a 4 ch. amp of equal quality. The cabling could still be audison and the coax could still be Hertz. You were happy with these right? |
| | #6 (permalink) |
| BHPian Join Date: Sep 2005 Location: New Delhi
| Hi McLaren, Congrats for your Baleno... As far as you ICE is concerned there are lot of options. All depends on what you are looking for. 15" subwoofer is not an overkill it is all about tuning and installation .Baleno is much bigger car than zen so I suggest you go for 2 X 10's or 1 X 12's in IB or 1 X 15" in ported box in the boot. The only issue with 15" in boot is that it will wreck the baleno's boot lid with vibrations. If you damp the boot & boot lid well with damping material then there is no issue. 450's sub channel supports 4 ohm load. Hence adding another 10" will give you 4 ohm final load. And the 15 is 4 ohm SVC. So it can be either two 10's or one 15. In cabin subs will give you immediacy where as 15 in ported box will play loud & low. Choice is yours .You can use 5" components at the back and go for 6.5" in the front.
__________________ Danes Don't Lie ! |
| | #7 (permalink) |
| Senior - BHPian | Guys thanks a lot for the response .. Navin , got ur point and yes it does make sense .. Spoke to gunman too a while back about the setup .. From all this what i have inferred is : 1. Get a 15'' and try and run it on the 5th ch and see if its good enough .. 2. If not get a 2ch or a mono .. 3. Bloody damp the boot well .. I pity my spoilers condition for all the bouncing it will be doing .. Not to mention the passengers ... 4. Move the 5.25 '' compos to the rear and get the 6.5 '' for the front .. 5. The usual audison cabling as well .. From what i was told there arent any 15'' available as of now , so i think i will have to wait for a month at the most .. For now , i think i will do with the sound of my engine , freeflow etc etc (which should be in by sometime next week after returning from track day) .. Anyways with speedrun coming up i would have to once again strip the entire setup again .. So i guess i better install the setup once thats done .. What say guys ?? As far as the tuning is concerned , we will be meeting up at the goa meet .. So JB and gunman can have a look at it then ??? Btw navin arent u coming to goa ?? I think we ought to meet .. The other ICE gurus are coming as well ..
| | #9 (permalink) | |
| Quote:
b) JBL has some 15" (GT4-15 for example) available from what i hear. but if you are looking for Hertz, JB/Gunbir would be your guide. | |
| | #10 (permalink) | |
| Senior - BHPian | Quote:
One question bro.. even in your wildest imagination / dream do you think we will let you drive the car after the "works" has been done.... if you think so then you are mistaken..so ummm i guess we dont come under the passengers list... YOU DO bro.. ![]()
__________________ I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer. | |
| | #12 (permalink) | |
.. Im sure since the last incident not many are comfy driving my car .. Anyway lets get back to topic ..
__________________ Phoenix! Last edited by mclaren1885 : 4th March 2006 at 11:15. | |
| | #13 (permalink) |
| Senior - BHPian | Hi there McClaren, Lots cooking for you eh Enjoy your new ride and sure your going to have a blast with Baleno on the track!!!Quick question, where are you planning to get all your ICE installed?
__________________ "Its not the size, its the heart, so dont hate... Accelerate !!!" |
| Thread Tools | |
Similar Threads | ||||
| Time for ICE upgrade in my Lancer | leadf00t | Ask the Gurus | 15 | 14th July 2008 19:29 |
| ICE upgrade time! | etchemkay | Ask the Gurus | 84 | 4th May 2007 13:36 |
| Ice Upgradtion Time !!! | parth | Ask the Gurus | 14 | 25th October 2006 17:18 |
| Time to ICE up the Aveo! | karthik247 | Ask the Gurus | 50 | 17th June 2006 15:43 |
| Baleno - Deck up time | vivaid | Modifications & Accessories | 73 | 14th July 2005 17:34 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
