| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #17 (permalink) |
| Senior - BHPian | ![]() His setup. Pio 944 powers teh sub. One pair of channel for one 4ohm coil. Cant he feed teh subs each coil with 250W in bridged mode ? Amp specs: Bridgeable 4-channel capability 4 x 150 W or 2 x 500 W or 2 x 150 W + 1 x 500 W (max. power) • Continuous output power (14.4 V): 4 x 75 W (20-20 kHz/4 ohms) 4 x 125 W (20-20 kHz/2 ohms) 2 x 250 W (Bridged 4 ohms) ----------------> what i said • 4 x 115 W or 2 x 360 W (DIN45324, +B=14.4 V) I guess the old installer didnt tune or use any LP filters and hence he wasnt happy with teh amp/sub setup Also, what do you think abt his boom box? Dump it and then do teh wiring as I said above? The pic shows his sub in a skoda boot! So imagine the box size.
__________________ "She may not look like much, but she's got it where it counts, kid." Last edited by jkdas : 19th March 2006 at 21:34. |
| | #19 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
what he can do is put the 2 coils in series. that would give him 8 ohms but that would give him about the same SPL as he is getting now. | |
| | #20 (permalink) | |
| Senior - BHPian | Quote:
note:944 dont support 2ohm bridged setup and hence I can connect the coils in parallel as you had guessed
__________________ "She may not look like much, but she's got it where it counts, kid." | |
| | #21 (permalink) | |
I forgot to add. The box is empty. Nothing inside it except teh sub. and two holes in the front.
| | #22 (permalink) |
| BANNED Join Date: Sep 2005 Location: New Delhi
| JK tell Karthik to go for sealed box. If he wants ported then he should use port tubes with correct diameter and length. Ported sub only sounds good by using right spec ports. Not by making two holes in the box. |
| | #23 (permalink) |
| Senior - BHPian | Guys..i've got a new enclosure made according to the size given in the Pioneer website. So now have one doubt.. I'm plannin to run the sub with the 944 for now. So JK told me that i can bridge the channels frm the amp and make it a 2ch and use it for the sub alone and the rear speakers will be connected to the HU until i get a small amp for the speakers. Now the guy who doz the installation work said thats not possible cuz we can bridge only 2channels and the other two can be used for the rear speakers. So guys what do u say??
__________________ Slow and steady wins the race... But there is nothing like a 300kmph dash to the line!! |
| | #25 (permalink) | |
So you have 2 X 250W to power both coils. Thsi way it almost like you have 500W powering teh sub. ![]() comments awaited. Connection to be done by eve today or tomorrow. condition: Want max boom. Cant change amp or sub now to a better one.
| | #26 (permalink) |
| Senior - BHPian | Seal The Open Holes In The Box And See The Diff U Might Not Need To Change Any Thing. Also While U Wire U Sub To Each Channel To The Sub Check The Output Of The Amp Of Both Channel Should Be Identical. For This Play A Sine Wave Of 70 Hz And Check The Voltage With A Multimeter At Both The Channel They Should Be Equal Or Else The Sub With Not Achive Full Power. To Adjust The Output Adjust The Gain Of The Amp Ur Box Size Is Very Large Can U Give Me The Outside Dimm Of The Box I Am Curious About The Size. |
| | #27 (permalink) | |
The box was dumped yesterday! He gave an order for a new box which would be made according to Pioneer website specs.
| | #29 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Live the YetiLife® Madonna is a Goddess. | |
| Thread Tools | |
Similar Threads | ||||
| esteem ice upgrade | amannarwal | Ask the Gurus | 8 | 11th April 2008 11:12 |
| ICE Upgrade | saintsinner | Sound Off and Show Off | 119 | 30th January 2008 07:46 |
| ICE upgrade for Baleno...... | BWN | Ask the Gurus | 10 | 1st January 2008 08:09 |
| Help with a Skoda ICE upgrade | nanu28 | Ask the Gurus | 19 | 7th March 2007 12:19 |
| First/Best bang for the buck Upgrade for a Skoda 1.8TPI | nanu28 | Modifications & Accessories | 11 | 4th November 2005 16:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
