| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Phew... CBE!!
| GURUS.. Without taking names Muchas Gracias to everyone who has helped me reach till here so far... Just need your help to finish the job! (and hopefully ONLY the job!!) I have already BOUGHT a BLAU PA275 amp... I am planning to pick up the Alpine 575 (making sure I dont run outta "gasp" - keeping things future-proof) The 275's were to have driven IDQ 12" or Energy 300's ... Now I find that with the 3/4 channel bridged the 545's would give 500 SMACKS ... way more than the 275's 200W (@4 ohms) .. I am now confused ... 1. Do I use 545 to drive front & rear and the 275 for the Sub Or is it better to use the Alpine 3/4 channels Bridged for the sub then do I have to .. 2. Buy a bigger or better sub for the power - 500 Watts? The other two channels of the Alpine will continue to give me 125w @ 4 ohm , 14.4 volts .... and the Blau 275 puts out 75 Watts each at 12V. 3. I am planning to use 6.5" comps in the front and matching 6.5" co-ax in the rear. So which one of the Amplifiers do I use and where.. the fronts and the rears? 4. I am looking at the Kappa/Hertz Hi-Energy range - suggestions on comparable/better alternates welcome! I am looking for "TIMBRE" ... Bass that "THOCKS" .. and Highs that well... I kinda want hear the striker strum...? (I dont quite get the Forward/Laid-back bit!) .. I like DEPTH - dont like flat tinny sounds a la Bose. GURUS .... I had brought all of 4,500 Rupees to this table for a pair of replacements for my OE front speakers. JUST LOOK AT WHAT ALL OF YOU HAVE GOT ME INTO!!! I am running the serious danger of being slaughtered by my wife!!! So improvements you suggest needs to be now kept within 10% of the overall budget! Romba Tanx!
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 26th March 2006 at 19:29. |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| KB, LOL I wish I had such choices! If you are using a 275 and 545 i suggest the following. Use ch. 1 and 2 for the front comps. Use ch. 3 and 4 bridged for the sub Use the PA 275 for the rear. why. 1. the amp with the best "voice" should be used for the front (545 ch 1&2) 2. the amp that can swing the most amps should be used for the sub (545 ch. 3&4) the rear gets the leftovers. If I were you I would get the 345 instead and samve some buck for better cables. Then use the 345 for front and rear and the 275 for the sub. Last edited by navin : 27th March 2006 at 10:08. |
| | #4 (permalink) | |
| Quote:
Dont mind the 345.... they will give 300 W bridged for teh Sub.. The balance two will sit smack in the 275 territory @ 75 Watts each!... Is this a possiblility too??.. if so which one do we use where??.. Or is the overall tonal balance better with the 345's driving the 4 channels and the 275 thr subs.. Also between the 545 and the 345, which one will make those speaks "SING" better??
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 27th March 2006 at 10:46. | |
| | #5 (permalink) |
| MRV-F345 = $ 265 (online car stereo) [Power Features] • Bass EQ (45Hz, +16dB for CH3/4) • Multimode Capability (CH3/4) • MOS-FET Power Supply Transistor • BI-POLAR Output Transistor • Amplifier Link (Model 2005) • Phase Selector • Speaker Input (RCA conversion) • RCA Pre-out • Independent Variable Crossover • Over Current Protection • High Temperatur Protection • STAR Circuit • Digital Control Center Display • Discrete Pre-amp Stage • DC-DC PWM Power Supply [Power Specifications] • Weight 4.2 kg • Dimensions 330 x 60 x 228 mm • S/N Ratio 93dBA • 300W x 1 Bridge (4ohm, 14.4V, 0.3% THD, CH3/4) • 75W x 1 Bridge (4ohm, 14.4V, 0.3% THD, CH1/2) • 50W x 4 RMS (4ohm, 12.0V, 0.08% THD) • 75W x 4 RMS (4ohm, 14.4V, 0.08% THD) • Max. 140W x 4 • Input Sensitivity 0.2-4V (at 10k ohm) MRV-F545 = $ 334 (online car stereo) [Power Features] • Bass EQ (45Hz, +16dB for CH3/4) • Multimode Capability (CH3/4) • MOS-FET Power Supply Transistor • BI-POLAR Output Transistor • Amplifier Link (Model 2005) • Phase Selector • Speaker Input (RCA conversion) • RCA Pre-out • Independent Variable Crossover • Over Current Protection • High Temperatur Protection • STAR Circuit • Digital Control Center Display • Discrete Pre-amp Stage • DC-DC PWM Power Supply • MOS-FET Output & Power Supply Transistor [Power Specifications] • Weight 5.6 kg • Dimensions 420 x 60 x 228 mm • Frequency Response 20Hz-20kHz (0, -1dB) • Input Sensitivity 0.2-4V (at 10k ohm) • S/N Ratio 96dBA • 500W x 1 Bridge (4ohm, 14.4V, 0.3% THD, CH3/4) • 125W x 1 Bridge (4ohm, 14.4V, 0.3% THD, CH1/2) • 100W x 4 RMS (4ohm, 12.0V, 0.08% THD) • 125W x 4 RMS (4ohm, 14.4V, 0.08% THD) • Max. 225W x 4
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 27th March 2006 at 11:27. |
| | #6 (permalink) | |
| Quote:
for the $60 difference better cables would give you a much more percetable improvement in sound. remember this is car audio system and not an amplifer we are talking about. a chain is only as strong as the weakest link. | |
| | #7 (permalink) |
| WOKAY...345 it is!! Navin SAAB.. Pls suggest the various cables/makes/models you recommned for each stage of this setup Ps: Gunbir just sent me his complete price list -- Just got off the ventilator.. Anybody needs Bricks - I got plenty here !! ???? ![]()
__________________ A closed mouth gathers no Feet. |
| | #8 (permalink) |
| BHPian Join Date: Sep 2005 Location: Batala
| KB100,initially instead of buying two amps,u could have gone for alpine 450 or some other 5ch/6ch amplifier.That could have made install a bit more neat. Anyway i would recommend 1st deciding abt budget and then going for ICE stuff.If u have budget for 545,go for it.Why buy less powerful/quality amp if u got the budget. And as subw r more power hungry,i would recommend feeding 'em on separate amp,blau275 in ur case. Do keep good budget for good wiring and install.get the box [sealed box i suppose]made by some local guy and use terminal plugs and banana plugs so that u can easily disconnect and remove subw box when u need to. I am using wiring stuff sent by Gunbir and i'm very much satisfied with the quality. Last edited by rsjaurr : 27th March 2006 at 14:21. |
| | #9 (permalink) |
| Navinji... waiting for your responseee..... Doc... Box being designed by Gunbir and his "mad-scientist' partner JB He was talking about a ported box though.... ?????
| | #10 (permalink) | |
| Quote:
Audison makes some decent wire too. and lastly Monster Interlink Jr. is nice wire atleast it is well made and wont allow noise. My favourites are Steetwires and Twister. | |
| | #11 (permalink) | |
| Quote:
hte 450 would make a nicer install but it is not available and KB already got the PA275. The Alpine 545 swings more amps than the PA275 in bridged mode and hence would make a better sub amp. The 345 is about the same as the 575 and it makes sense to use it's sweetness for the rear instead of wasting that on the sub. | |
| | #12 (permalink) | |
| Quote:
oh yeah........i agree with u navin. But KB100 got huge budget. So we should not worry abt his budget.If he is going for SQ setup[like infinty speakers],he needs as much power as he can [rather his amp] manage. Now my JL audio is rated 110w rms @14.4 @2ohm,but i still want to have more power,though not sure why.lol.Just human nature i guess. Abt ur last few words,thats what i also meant that alpine amp's [545 or 345]sweetness should be used for rear spk rather than subw. And i dont think blau275's 250w is insufficient for any subw. | |
| | #13 (permalink) |
| I need an education in what the DB in speakers is all about... I found, for instance, the db of JBL (forget the series) to be higher than the Hertz Energy... Therefore what happens? Is there any thread on this subject - I am yet to come to terms with the search function here ![]()
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 27th March 2006 at 19:55. |
| | #14 (permalink) | |
| BANNED | Quote:
Hey, You can try Esoteric Audio, Kimber Kable and Stinger as well. Kimber is excellent but priced a bit on the higher side. Viper | |
| | #15 (permalink) | |
| Quote:
![]() Sure will help if you can indicate what each of these kits will cost .. EGAD ... I have a twin Amp Setup!!Brrrrrrrrrrrrrrrrr
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 27th March 2006 at 20:18. | |
| Thread Tools | |
Similar Threads | ||||
| Alert - Fake JBL products (Amps, Speakers, Subs...) | Sam Kapasi | Product Discussions | 31 | 13th July 2008 16:11 |
| Amps, Speakers & Sub for RS | amgup | Ask the Gurus | 43 | 10th January 2008 00:19 |
| JL Audio Amps | jCube | Product Discussions | 10 | 3rd October 2007 21:14 |
| conFUSION !!! | murlee | Hatchbacks | 31 | 31st March 2007 13:51 |
| Confusion v/s Confusion | geek | Sedans | 32 | 7th July 2006 20:23 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
