| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| BHPian Join Date: Mar 2009 Location: Allahabad
Thanked: 99 Times
| Guys need your kind help on ICE upgrade I purchased a JVC HU few months back and it works great in my Santro Xing. my Current Set up is HU - JVC 526 Rear speakers - Blaupunkt oval 3 way, installed in Box Front speakers Blaupunkt round 2/3 way (don't remember), in Dash on standard location of santro. Now I want that Bass Thump, current setup gives Bass but still lacks that effect, I don't want boom boom effect of a bass tube so its out of questions. All I want is tight bass at low volumes, don't want to sound like a "DJ on the move" but want extra bass to please my ears. I don't plan to go for any very expensive stuff but recently I came across JVC new DRVN series Amplifier and sub. Amplifier I wish to purchase is JVC KS-AX3102 its a bridgeable 2 Ch. Amp. and sub JVC CS-G-1200 (30cm subwoofer, in a box) please share your experience about these products, are they worth for my hatchback. Has anyone here used these woofers, how's the performance or what are the other alternatives for Sub+AMP for 10k budget. |
| | #2 |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
Thanked: 958 Times
| Buy a 4 channel amp Sony or Pio (~4-5K) and a JBL sub (~4K) in a sealed box (~1K). Use the front 2 channels to power the front 4" coaxes (you need to, otherwise you will have a rear-heavy sound stage), and bridge the other 2 channels to drive the sub. Keep the rear 6x9s on the HU. * You will need to spend a bit more on wires & cables * With a sub comes rattles, so you may need to damp the sides of the boot and the hatch |
| | (2)
| | #3 | |
Thanked: 99 Times
| Quote:
Also Sealed box is a new thing for guys in my small town, so let me first ask him to get the box ready. Being a newbie in such ICE upgrade, my only hope to save myself from buying a CRAP is team-bhp. I think I might get it installed on coming friday but not sure about the brand. Last option would be to get the wiring etc installed then try a couple of combination however I am not sure if listening and tuning in short session would help me bring out the clear picture. | |
| | #4 | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
Thanked: 1,112 Times
| Quote:
Before you buy the JVC sub at least hear a few other brands. Blaupunkt and JBL are well distributed so should be easy to find. | |
| | (1)
| | #5 | |
Thanked: 99 Times
| Quote:
All the boxes available in the market were having the small round vent above the subwoofer space, the dealer was so surprised by my inclination towards sealed box that he took me the carpenter workshop where all the boxes were having that air vent(may be I am forgetting the exact name). He said all he could do is get a new custom box made as per my requirement, as I need the sealed box suggested by experts here, can someone post the sizes required for a 12 inch JBL Subwoofer ? I would get the box made possibly tomorrow then if needed I can use the sealant to seal it and get it installed on this weekend. Can someone please help me with required box size for a sealed subwoofer box. Edit: Got this link, but being a newbie I would do what Team-bhp ice addicts suggests. Last edited by ghpk : 20th March 2012 at 23:35. | |
| | #6 | |
| Quote:
2. JBL used to supply recomended sealed and ported box designs with their subwoofers. I dont know if they still do so. I am sure your dealer will know. A sealed box is just a sealed box. A ported box is the box you saw wiht a hole and a pipe stuck in the hole so one has to design not only the size of box but also the diameter and length of the pipe. Dont buy a subwoofer just because it sells a lot. Buy it because it sounds good to you with your music. I suggested JBL and Blaupunkt becuase I know they are well distributed. Some smaller brands like Bull Audio are also good but they are not as well distributed so you might not have access to them. if the dealer has a JBL sub in the ported box take a listen. The worst that can happen is that you wont like the bass. Take some cotton cloth and stuff the port and listen again. Last edited by navin : 21st March 2012 at 09:55. | |
| | (1)
| | #7 |
| BHPian Join Date: Apr 2006 Location: chennai
Thanked: 22 Times
Infractions: 0/1 (7) | For a santro I would recommend an 8/10 inch sub with a sealed box . The volume of the box is around .75 cft to 1 cft . And pls do not buy a "readymade" box . Just go to the respective manufacturer site and download the dimensions of the box and get it done . Most of the readymade boxes are smaller in size . A better option for a santro would be an 8inch underseat sub . You can neatly tuck it under the front seats so that you do not waste boot space . |
| | #8 | |
Thanked: 958 Times
| Quote:
Also, an 8" sub is no comparison to a 12" sub in going low. Good 6x9s mounted on a parcel tray give as much bass as the usual 8" sub. Good 8" subs, if they are available, cost the same as 12" subs. | |
| | #9 | ||
Thanked: 99 Times
| Quote:
secondly DerAlte is right about the wire under the santro seats which will prevent it from going correctly to center where back seat passengers would not step on it. Quote:
his ported box is Lenght 18 inches Depth 13 inches Height/Width 14 inches made from 0.75 mdf board, but not used silicon or any other thing to make it TIGHT. plus the port drilled above 12inch subwoofer is only as seen on most boxes, no pipe or based on any suggested specs. I am going to his shop to get specs of the subwoofer now, and once I have those figures I will try to calculate and finalize the required dimensions tonight. please keep the suggestions coming :-) | ||
| | #10 | |
| Senior - BHPian Join Date: Feb 2006 Location: MAA
Thanked: 147 Times
| Quote:
I got myself a 10" sub when I was actually searching for 8" ; good that I did not find a 8" else I'd be kicking myself now. redesigned the sealed box once to get the bass right. | |
| | #11 | |
Thanked: 958 Times
| Quote:
I would rather go for a smaller box for sealed duty, say 1-1.1 cft. (Gurus, please give the desired internal volume for a JBL sub). The box would then be 15x12x14 (1771.875cu.in./1.03cft) or 15x13x14 (1940.625cu.in/1.12cft). * You can ask them not to cut the hole, otherwise assemble the box as they were doing earlier * For sealing, ask them to mix MDF sawdust with Fevicol, and press the mix along all the inside seams with their finger (I am sure they will understand this, and bless you till eternity for that knowledge )* Account for bringing out the connecting cable through a sealed hole. Use a PA system connector (red+black) or similar - whatever you can get locally. Make sure you seal it well to the MDF | |
| | (1)
| | #12 | |
Thanked: 99 Times
| Quote:
| | #13 | |
Thanked: 22 Times
Infractions: 0/1 (7) | Quote:
Polk and JBL do have a cost effective 8" inch sub . Most of the small hatches need the boot space and using a 12" sub really blocks the usable space . I wish manufacturers made 6" and 8" subs for under seat application . Probably I would use 2 subs under the front 2 seats . | |
| | #14 |
| BHPian Join Date: Apr 2006 Location: Chennai
Thanked: 20 Times
| hi gurus, need some help with my new innova, i've booked a new innova VX. the problem is that the O.E. system has a sub out but does not have a video out socket, but i want to mount 2 head rest monitors. i need a system that has that option as well as a stock look. also it should be able to accomodate the controls on the steering wheel. i'm willing to forgo the stock look if the system looks good. what should i go in for. the dealer tells me that for Rs. 30,000.00 they could add a kind of adaptor for a video out. but i refused as a few thousand more can get me a whole new system.what should i do?? confused. Mods: sorry again place this where you feel is right. Last edited by VANOS : 21st March 2012 at 22:05. Reason: accidentally wnt to quick reply. |
| | #15 |
Thanked: 99 Times
| I tried some combinations and I think sealed box which I should go with should be 1.033 cubic ft. one. 14.5"W x 14.5"H x 12.0"D = 1.03 cu ft Air Space Sealed However one question arise in my mind, will the box still hold the subwoofer intact with 1-1.5 inch left on all four sides of subwoofer ? Here's the calculation done from the website I mentioned earlier. ![]() |
Similar Threads | ||||
| Amplifier settings for Subwoofer | druberoi | Ask the Gurus | 10 | 9th February 2012 13:22 |
| Subwoofer without Amplifier works.. | headers | Ask the Gurus | 54 | 30th May 2009 07:53 |
| Which Subwoofer and Amplifier | ramie2400 | Ask the Gurus | 86 | 14th April 2009 12:06 |
| Help in selecting Amplifier and Subwoofer for my Wagon-R | ravi@64bhp | Ask the Gurus | 37 | 28th June 2008 20:40 |
| need help for subwoofer on JVC KS-F171. | amit_mechengg | Ask the Gurus | 11 | 13th February 2008 15:38 |
