Thread Tools
Old 4th April 2006, 19:47   #1 (permalink)
low_bass_makker's Avatar
Default Power Rating of Amp. (1141rms at 4ohms, 1022rms at 1ohms)
334 watts RMS x 2 channel at 4 ohms and ≤ 1% THD + N
1141 watts RMS x 1 channel at 4 ohms,14.4V supply and ≤ 1% THD + N
1022 watts RMS x 1 channel at 1 ohm, 14.4V supply and ≤ 1% THD + N
these are the specs of jbl BPX1100.1 1100 Watt Subwoofer Amplifier from the website can some one explain how come the amp is giving 1141 rms in to 4 ohms but 1022 watts in 1 ohm it should increase than 4 ohms. One more thing this is a current base amp ,and there are voltage base amp what diff does the have.
low_bass_makker is online now   Reply With Quote
Old 5th April 2006, 11:28   #2 (permalink)
navin's Avatar
current dumping limitaiton - extremely poor power supply
Old 5th April 2006, 14:04   #3 (permalink)
It means the amp is not good at lower ohms rating and will not will be able drive multi sub systems. This are the spec of jbl-crown series amp, which where used in the great eyeballer palio. I have heard the palio myself the person giving the demo had no knowledge of the audio stuff installed in the car i myself adjusted the hu myself and listened to the sound. it was nice. but one thing i did not like was the external power supply. why man ? if make a car make it in itsself no extrenal power sources should be used.
Old 5th April 2006, 14:14   #4 (permalink)
navin's Avatar
When the word Crown comes up in any conversation I relook at my theory. Crown amps are behemoths. I have seen them being used to magnetize rare earth magnets (providing as much as 140A into DC). so I relooked at my earlier rushed statement...here is what i found...BTW Harmon Intl owns both JBL and Crown as well as Infinity and Revel and a few other brands.
1141W @ 4ohms = 17A
1022W @ 1 ohms = 32A
not exactly a slouch but yes if the power supply or output transistors permited it it could have dumped even more current. looks like the current is limited to 32A.
most amps are volt amps. they should double power as impedance is halved. 100W@8 ohms = 28V, 200W@ 4ohms = 28V, 400W@2ohms = 28V and so on. Now if you relate 400W@2ohms which is a lot of power you see that the current is only 14A! still a bit less than the above mentioned Crown amp.
current based amps are those where the current is controlled and hence you see that the current is limited to 32A. usually this is done using a tightly regualted power supply. the advatange is that such amps seem to manage reactive loads better than volt amps. reason being is that as the impedance of a reactive load rises or falls the watts are the same. As you can see in teh above example the Watts at 4ohms and 1 ohms are almost the same.
LBM, 32A is a lot of current. It would require 8 (4+4) Hitachi SJ50/SK135 Mosfets to dump that much current and only the metal body ones would disappate the heat properly over the long term.
see pic on post #1 here
http://www.diyaudio.com/forums/showt...294&highlight=
Old 5th April 2006, 14:22   #5 (permalink)
Sam Kapasi's Avatar
Hi LBM,
The Eyeballer was not designed for normal usage. It was able to run in a car that was running (the alternator current would be added). Ideally it would have needed 2 or 3 batteries (for current) and a charging system that would complement the power supply.
However please consider that it was used at various shows, many indoors. With the exhaust and the heat of a running car, it was a nightmare. So the external power was used. (125Amps 12V)
And the current limitations are assuming you use it in your car.
__________________
Live the YetiLife®
Old 5th April 2006, 14:47   #6 (permalink)
navin's Avatar
BTW I must admit I am a biased person. I am fond of crown. I dont own one but have heard them and seem do some darn impossible things (for amplifiers).
The 2SJ50/2SK135 Mosfets mentioned above are not used by Crown but by me in my own home made car and home amps.
http://www.sjostromaudio.com/datashe..._datasheet.pdf
these are great devices but over long term I would not use expect more than 4A out of each of them (v/s 7A as speced) unless you got fan or oil coolling.
Old 5th April 2006, 17:29   #7 (permalink)
Autophile's Avatar
FYI the external power supplies are used during exhibitions and indoor demos. As it is important to keep the engine running for charging the car battery. So in indoor places to avoid the exhaust fumes the external power supplies are used. There is nothing like liking or disliking as it makes no difference in sound its just a convenience.
I have seen the Eyeballer setup and I don't think car electricals should have any problem handling that with engine on.
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Old 5th April 2006, 19:44   #8 (permalink)
One more thing did the eyeballer had sealed box for the sub and what volume they had ?
Thread Tools
Amplifier rating Vs Speaker rating CaAT Ask the Gurus 28 31st October 2008 20:32
Speed rating & cost of tyre DocG Tyre & Alloy wheel Section 16 29th February 2008 00:31
Amp Power Control with Engine. km120 Ask the Gurus 14 10th January 2008 09:54
Matching HU amp power with Speaker power? hitra Ask the Gurus 12 29th August 2006 12:27
JD Power : Low rating for Baleno venkatrx The Indian Car Scene!! 46 18th May 2006 09:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
