Thread Tools
Old 6th April 2006, 07:28   #1 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
Default HU problem....
i've had a strange problem recently....whenever i turn on my HU (sony XR-4800) in my maruti 800 (no amps; just a clean matching sony speakers)....it starts to blink, as if its not getting the right amount of current. i checked with an 12V adapter, it worked fine. i checked my battery and alternatortoo....all is fine. any suggestions?
Old 6th April 2006, 16:44   #2 (permalink)
Bass&Trouble's Avatar
Have a good electrician check the power line coming to your head unit from the 'ACC' switch. Secondly, when you connect it through a 12V power supply, do you connect the speakers also? Ensure that the speaker cables are not shorting anywhere or maybe they are stripped somewhere and touching some metal part of the car.
Bass&Trouble is online now   Reply With Quote
Old 6th April 2006, 18:02   #3 (permalink)
low_bass_makker's Avatar
check the ground cable and the speaker cable shorting .I will happen when the speaker wire get touch with the chassis.
low_bass_makker is online now   Reply With Quote
Old 7th April 2006, 01:09   #4 (permalink)
panky12345's Avatar
i have done this all and everything seems to be perfect, i installed a new genuine Sony wires and problem doesnt go away!
Old 7th April 2006, 11:56   #5 (permalink)
navin's Avatar
take the car to your installer and ask him to connect another HU and see if that has the same problem. if it stops you knwo it is the HU if not the wiring. there is not much else left. often during intallation the speaker tabs touch the metal body and that could be the reason.
Thread Tools
Battery problem or starter problem or....?? Srinivas Technical Stuff 7 21st October 2008 18:42
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 81 10th February 2008 12:58
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 13:02
problem with ac zenopio Technical Stuff 4 5th April 2007 21:22
R1 problem..... vidurc Motorbikes 2 8th March 2006 18:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
