| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| i have a pair of BOSE 3 1/2" MID range (2 Ohms) powered by my HU. problem is they trying to reproduce the low frequencies whenever i crank up the bass; as such i cant get a clean sound from them. any suggestions how to rectify? |
| | #3 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| a 3.5" mid cannot produce much below 150Hz. try using a bass blocker such as one found here.... http://www.crutchfield.com/S-q0FAONs...h=bass+blocker Or http://www.crutchfield.com/S-q0FAONs...skipvs=T&g=760 it wont produce bass but atleast it wont distort when you turn it up. then you can add a sub. |
| | #8 (permalink) |
| panky. he he. If i get technical the resident gurus scream "NAHEE!" :-) a 3.5" speaker cannot possibly reporduce bass freq at a level that is reasonable. so one would have to add a subwoofer or woofer and relieve the 3.5" from such duties (producing bass frequencies). the simple way to do this is to put a capacitor in series with the 3.5" speaker. however the capacitor value has to be large or a small cap will block out all the freq except the very high. the sad part is that these large caps are usually electrolytic which is not good. so you have to perform 2 operations with/on these electrolytic caps to make them usable. a) use 2 caps back to back meaning connect their +ve end together and use the -ve leads only. like this ASCII text drawing HU/amp--->-----cap---+ve---+ve-----cap----->---speaker b) use a bypass cap around the above "double cap" to improve the sound a bit as electrolytic sounds tend to have a harsh sound. a small polyester cap will do this. you connect the small polyester cap to the 2 remaining -ve leads. hope this helps. me no Guru, just a Mod. Last edited by navin : 11th April 2006 at 09:55. |
| | #11 (permalink) |
| Senior - BHPian | jars? Dump it and get some decent speakers ![]() Panky had problems with too much trebble not jarring. My JBLs dont jaar even at high vol( fed via amp) and hence I love those.
__________________ "She may not look like much, but she's got it where it counts, kid." Last edited by jkdas : 11th April 2006 at 10:12. |
| Thread Tools | |
Similar Threads | ||||
| Swift 2nd Gear Problem EDIT: Now first gear problem | BUSA | Technical Stuff | 81 | 10th February 2008 11:58 |
| NHC - BullKit Problem :EDIT: now detected to strut problem | ibcool | Technical Stuff | 13 | 9th September 2007 12:02 |
| HU problem.... | panky12345 | Ask the Gurus | 4 | 7th April 2006 10:56 |
| R1 problem..... | vidurc | Motorbikes | 2 | 8th March 2006 17:02 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
