| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Which box should be made for this woofer 1) Sealed 2) Ported Please tell the voulme and port lenght and any recomendation about the box also. TS parameters are given below ![]()
__________________ 156.6 db, naa....time is coming to cross it...... Last edited by low_bass_makker : 13th April 2006 at 18:10. |
| | #4 (permalink) | |
| BHPian Join Date: Nov 2005 Location: Delhi
| Quote:
Awesome You guys are good. By the way what you recommend for <<<<<this woofer(the one on my avtar) this is the one i have. | |
| | #5 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
| Quote:
__________________ Playing in my CD player: Rod Stewart - The Story So Far | |
| | #8 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
given the huge Mms and Qms and the high (but not so huge) Qts (in fact Qms is so high that Qts=Qes!) I dont see how to make a practical boss reflex box with this woofer. However I am willing to admit I could be wrong (If I had 1 ruppee for everytime I was wrong I'd be a millionaire). In a 40-50 liter sealed box expect an F3 of about 42Hz. however you can build a BOOM-BOX bass reflex woofer with this too (BB4 alignment). in a 40 liter box with a very long port. I would not be an acceptable sound. However what you can try is build a 40 liter box. see how it sounds. then install a port (easy way is to build an extra side wall with a port attached and switch side walls). I would look at a port that is about 3-4" dia and 12-16" long. Then means that the box must have atleast one dimension that is 3-4" more than the length of the port. However I feel the only practical solution is a sealed box. I'd ask the Guru (Sam, JB, B&T, Gunbir etc...) what their opinion is though. Last edited by navin : 15th April 2006 at 09:27. | |
| | #10 (permalink) |
| BHPian Join Date: Jun 2005 Location: Bangalore
| What the manual says is not rigid. You need to experiment with box sizes, different alignments and port tuning. The wise thing to do is to build a bix box (only limited by the room in your car) and you can always reduce internal volume by filling it up. This way you can experiment tilll you find the sound you want. If you build too small a box, you obviously cannot enlarge it later. Do your homework well before you cut any wood and you will end up with a good result. We are all there to help you.
__________________ Thank God for DIY audio. Last edited by Vivekphadnis : 16th April 2006 at 20:39. |
| | #11 (permalink) | |
| Quote:
I would really like to request all of you ICEers to listen to your ears. I dont subscribe to any magazines or such and if I do read them on occasion I have no reason to believe what they say. I have often found that I dont particularly care for audio components recommended by many respectible magazines and even reviewers. Magazines and reviewers not only have different tastes and rooms but are also led by contraints some moral some technical and some political. You and I are not. We are spening our hard earned money to reporouce music we like to produce what we consider a pleasureable experience. It is that SIMPLE. Last edited by navin : 17th April 2006 at 10:20. | |
| Thread Tools | |
Similar Threads | ||||
| Will fitting wider tires result in loss of FE?Or is it... | undead | Tyre & Alloy wheel Section | 2 | 20th July 2008 10:33 |
| DIY Started, surprising result - will continue | redfire | DIY - Do it yourself | 57 | 9th June 2008 19:58 |
| Race Result - A1GP Zuhai - INDIA WINS!! | MustangMan | Motor-Sports!! | 35 | 19th December 2007 23:38 |
| Tyre Comfort - unexpected result from calculator | comfortfreak | Technical Stuff | 10 | 29th October 2007 22:50 |
| Is the Aveo really so bad as compared to the Fiesta?? | Puffdamgcdragon | Sedans | 64 | 17th July 2006 12:03 |
