| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) |
| BHPian Join Date: Nov 2005 Location: Trivandrum
| guys... I still haven't got around to getting the car kitted out. In the mean time; i have been running through the car audio threads... looks like i'd be getting too confused with all of them!!! I have got some questions regarding the setup options:- 1) Use the sony 504 to power the sub, as well as the 6x9s at the rear. The problem with this is; the soundstage shifts to the rear, and could give me a headache because of too much bass, as the 6x9s would act as 2 8" subs. 2) In the interests of cost... would it be better to simply get a Sony 502, and drive the sub?. I could leave the 6x9s running form the HU. 3)I don't have front speakers yet... for the simple reason that some drilling would be required on the side panels to accomodate them. But, i realize that the best combination would be to leave the 6x9s alone, use the sony 504 to drive the sub and the front speakers. Which of the 3 options would you suggest?..cos i am not too keen on drilling the side panels for the front speakers. |
| | #17 (permalink) | |
| Quote:
I am awaiting your suggestions.... besides; is the sony 502 capable of driving a sub?... or should i look for something better? | |
| | #18 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| guys guys guys. at this rate i'll be retireing. very nice gunbir et. al. Not much to add. the JBL 8" mated to a 502 will serve well. an option is to get the sony 504 if budget permits and some 4-5" speakers for the front as well. let the 504's other 2 channels drive the front speakers. |
| | #20 (permalink) | |
| Quote:
I mean.... from the amplifier...for the 6x9s...set the High Pass Filter to ON, and for the sub...the LPF to ON. Would this work?... reduce the bass a bit?.. I dont mind the soundstage..cos as it is; i dont have front speakers as of now | |
| | #21 (permalink) |
| it might even sound better! The sony will have less work so might do it better. the LPF for the sub is sorta mandatory anyway. in reality Guru Sam has told me that many like the midbass hump they get with a sub and 6x9s working in tandem. |
| | #22 (permalink) |
| ah!.. thank you thank you!!! thats the answer i wanted to hear ![]() i was against this drilling bit to put in those front speakers.. Well, i just guess i will go ahead with the sony 504/554, and the JBL 8", with 2 channels from the amp running the 6x9s :-) Plan to get the install done by end of this week... So; do keep the suggestions pouring in :-) |
| | #23 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
__________________ Operator! Give me the number for 911! | |
| | #25 (permalink) |
| Thats naughty Sam! ![]() Anyways...i got my system, its up and running.. Here's my configuration Sony CDX S22S headunit Kenwood 6x9s at the rear JBL GTO1000B Subwoofer box Sony 554Z 4 channel amplifier Pioneer tweeters up front I have left the HPF Off on the sub. Then cancelled the lows from the headunit. System sounds pretty good. What do you think guys? All suggestions/comments/ and brick bats are welcome |
| | #26 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Amigo, that sentence makes no sense. An HPF only allows high (treble and mid) frequencies to go thru. So your statement is umm.. wierd. The GTO1000B is a passive sub so i assume you meant the amp driving it. Well of course the HPF isn't used, you use the LPF (which is what i suspect you meant) I think what you are trying to say is that you kept the amp on flat and used the sub out on the HU right? Because if you cancel the lows from the headunit, then there's umm... nothing coming out of the sub. So this is what you could have done/can do. You can use the subwoofer out on the HU, and cut it off at about 80hz or so. Or you can use the LPF on the amp to the same effect. Or you can use both to achieve a slightly steeper cut off curve (a little advanced there, no worries if you cant get it) The only actual change i would request is to change the "tweeters only" in the front configuration to a component set( Mid woofers, crossover and tweeter set). If you can return the tweeters, pay a little more do it, well and good, if not, maybe this is the first change you should make at some later date. Congratulations on the system, enjoy your music. A later edit: I just read back and saw that you merely added an amp and a sub box. I must say it is a good choice to buy a pre-fabricated boxed woofer, if you dont, or worse your installer doesnt know what he might do. A wrong box will ruin the sound. So since you have only added a 4 ch amp and a Sub, you've not done badly at all and you dont deserve any brickbats. next step, buy a set of components (chuck the pioneer tweeters) and use that 4 channel amp to drive the components and the woofer. Let the kenwood 6X9s run off the HU amp ok? Cheers.
__________________ Live the YetiLife® Last edited by Sam Kapasi : 15th May 2006 at 20:31. | |
| | #27 (permalink) | |
| Quote:
You are right. I have used the sub out on the HU. and the LPF on the amp is set ON. The HPF is not used. Hope this clears everything up :-) As of now; the soundstage is towards the rear, but its ok. At a later date, i will try the component set | |
| | #28 (permalink) |
| Just need to know, how best to fine tune the system for best sound reproduction. Do you guys have a specific manner in which you try out different settings that would give the best option possible? What settings should i be trying out? with regard to the Fader/Sub volume, as well as the Low/Mid/Highs? |
| | #29 (permalink) | |
| Senior - BHPian Join Date: Feb 2006 Location: Phew... CBE!!
| Quote:
__________________ A closed mouth gathers no Feet. | |
| | #30 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| 4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 | Bass&Trouble | Shifting gears | 7 | 19th March 2008 10:27 |
| Amp for existing Baleno Setup | Speedme | Ask the Gurus | 14 | 11th December 2006 09:14 |
| K&N Air intake system for Accord | Sahil | Modifications & Accessories | 11 | 24th August 2006 14:43 |
| Keyless Remote & Security System | nrajeshkumar | Modifications & Accessories | 0 | 18th July 2006 01:37 |
| Good Sub+Amp combo to add to my Esteem? | aalaap | Ask the Gurus | 23 | 21st January 2006 09:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
