| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2005 Location: Coimbatore
| Hey guys...need some help in connecting an active sub... Present system Pioneer HU + 12 disc changer HU does not have Pre-amp out 4 crap pioneer speakers Want to add: Blaupunkt VPc component speakers (2 pairs) Blaupunkt ODsb 8000A (active sub) Now, how do I connect the sub? The only way I can think of is to parallel the rear spealer wire, with one going to the active sub. The other goes to a "high pass filter" and from that to the "crossover" of the component system. Any other easier way? Can i buy some kind of adjustable cross-overs that will send the lows to the woofer and everything else to the speakers (To guy that suggests I change the HU )
__________________ Don't have mercy on your liver and tyres. They are evil |
| | #4 (permalink) |
| Senior - BHPian | there is one pair of rca out in ur head unit try connecting the active sub there and for the componets use in hu amp or connect a new amp ( for the componets) with a y lead to give the rca to both the active sub woofer and the amp for the componets.
__________________ 156.6 db, naa....time is coming to cross it...... Last edited by low_bass_makker : 24th April 2006 at 22:03. |
| | #5 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
| Quote:
Dude... The link you posted... ![]() Your HU has one RCA preout. Or am I missing something you're saying?
__________________ Playing in my CD player: Rod Stewart - The Story So Far | |
| | #8 (permalink) | |
| Quote:
1) Now how do power the sub? Will it be a problem if it is on whenever the car is running? 2) How do I prevent the rears from getting the low freqs? 3) Any hi pass filters that cut out below 150hz available locally?
__________________ Don't have mercy on your liver and tyres. They are evil | |
| | #9 (permalink) | ||
| Quote:
- Positive - cable from your battery +tive terminal (including a fuse) to your amp - Ground - cable from a good ground point near the amp - Remote - cable from the HU's remote output (theres a yellow cable behind your HU) to your amp. Connecting the remote cable to your amp will Quote:
__________________ Playing in my CD player: Rod Stewart - The Story So Far | ||
| | #10 (permalink) | |
| Quote:
.... Connecting the remote cable to your amp will ensure the amp (or active sub in your case) will turn on and off with your HU, as in switch on /off automatically when your HU switches on and off.
| | #11 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Minimum ofcourse is ONE pair of RCA outs. Not much you can do with this. Even if you split it and use it for the rear and front/subwoofer, you will have no control over the lelels and fading and you might even get "ground loop" buzzing, which is very annoying under any circumcisions. For good quality amplified sound you need atleast 2 pairs (front and rear out) but with 3 pairs (front, rear and subwoofer out) you can have great control. But with that comes great responsibility.
__________________ Live the YetiLife® Madonna is a Goddess. | |
| | #12 (permalink) | ||
| Quote:
Anyways...crossovers here i come...wikipedia here i come i mean ![]()
__________________ Don't have mercy on your liver and tyres. They are evil | ||
| | #13 (permalink) | ||
| BHPian Join Date: Feb 2006 Location: Buffalo,NY (Hyderabad)
| Quote:
| | #14 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| the simplest XO you can buy are the PLLXO made by FMod. they are cheap (about $29 a pair) and fixed at 12db but they work. I thought the active Blau sub you are using has a XO built in. why not use that. |
| | #15 (permalink) | ||
| Quote:
My rears are puny 5" comps. Thats all i can fit in the space i have (octy) I don't want to even try getting low-bass from those. The fronts are 6 1/2" and hopefully will handle it . Quote:
__________________ Don't have mercy on your liver and tyres. They are evil Last edited by epyupc : 25th April 2006 at 10:37. | ||
| Thread Tools | |
Similar Threads | ||||
| ARTICLE: Pre-delivery Inspection & Check List | normally_crazy | On buying a car | 70 | 27th August 2008 15:28 |
| pre charger or foam pre-cleaner for K&n Universal filter | warchild | Modifications & Accessories | 6 | 13th August 2007 10:42 |
| Do I need a Pre-amp? | Steeroid | Gadgets, Computers & Software | 5 | 28th February 2007 09:28 |
| Pre-owned Optra / Pre-owned Accent CRDi / New Tata Indigo | ashthedivx | Sedans | 15 | 24th February 2007 13:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
