Thread Tools
Old 30th April 2006, 12:26   #16 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Originally Posted by panky12345
i think one can achieve this with stuffing poly-fill to the fullest in the door panel or is there some other dumping material as well?. wotsay?
No. Firstly, your door has moving parts in it (windows scissor mechanism etc) so you cant really stuff the door with anything.. Secondly, Polyfill, foam etc will retain moisture which will lead to accelerated corrosion and rotting of your doors.
You need damping sheets like Dynamat.
__________________
Often imitated, never duplicated!
Old 30th April 2006, 23:55   #17 (permalink)
gunbir's Avatar
also, where do u mount tweeter in this set up?
Found it...
__________________
Old 1st May 2006, 00:47   #18 (permalink)
panky12345's Avatar
gr8 guns....gunman! thanks a lot for the pictorial representation!
__________________
SINGH IS KINNNNNNNG..
Old 1st May 2006, 17:44   #19 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Hey GUN,
Could you please help us to figure out how should we use dynamat in the doors for dampening. I want to do it in my ALTO as I am fitting 5.25" components in it.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
Old 1st May 2006, 19:48   #20 (permalink)
gunbir's Avatar
Originally Posted by speedzak
Hey GUN,
Speedzak... I'll try to revert with a how-to thread. But that may take some time...
In the meantime, read up on the resources on Dynamats tech page
http://www.dynamat.com/technical_sou...tes_intro.html
http://www.dynamat.com/faqs_faqs.html
Feel free to ask questions here if you have any.
__________________
Old 2nd May 2006, 00:44   #21 (permalink)
navin's Avatar
nice gunbir...love your show and tell pics...
there are many 4" components out there. mate them to a 6" woofer and you can make your own 3 way speaker by modifying the crossover.
Old 2nd May 2006, 01:51   #22 (permalink)
jkdas's Avatar
okok, just show me how it can be done for a Xing!
__________________
-__-
Old 2nd May 2006, 05:16   #23 (permalink)
panky12345's Avatar
boss, can u elaborate how?? am actually looking fwd to buy a 3 way, but budget doesnt permits me!
__________________
Old 2nd May 2006, 10:35   #24 (permalink)
navin's Avatar
step by step (with no pics - but I am sure gunbir can provide the pics).
1. get 4" components.
2. get appropriate 6" woofer
the 4" components come with a 2 way crossover which is a paralleled LP and HP network.
now add a LP and HP network at say 100-150Hz a better way is to use an amp with this network and use 2 LP channels for the 6" woofer and 2 HP channels for the 4" component set.
Old 2nd May 2006, 11:51   #25 (permalink)
s0uljah's Avatar
What would be a cheaper alternative, if there is one availble locally? (i know of other brands like RAAmat, fatmat etc... but im talking real cheap alternative). I will go with dynamat for my next car but currently if i put in 6.5" front compo's in my santro I will definately need some dampening as the car is built like a tin can !!
__________________
"Its not the size, its the heart, so dont hate... Accelerate !!!"
Old 2nd May 2006, 13:01   #26 (permalink)
Sam Kapasi's Avatar
yup JK, infinity has a 3 way but all for $ 250 - 300 and above (at least here in US)
so just sticking to JBL, economical, good sound....and above all sam wd be happy!
LOL by that logic, I should be happier when you buy Infinity panky- it's the same company
__________________
Live the YetiLife®
Old 2nd May 2006, 18:03   #27 (permalink)
speedzak's Avatar
Thank you GUNbir for that!
I think this will solve my probs!
BTW, is it advisable to install 6X9 Blaupunkt velocity speakers in my rear door panels of ALTO? I want to keep the boot free from a parcel tray, that's it!
__________________
Old 2nd May 2006, 18:15   #28 (permalink)
navin's Avatar
a 6x9 in the rear door might not fit. if you manage to shoehorn it in it would work well. I would choose between a 4 ro 5" for the rear door.
every speaker needs room to breathe and bigger speakers need more room (very generic statement)
Old 2nd May 2006, 18:38   #29 (permalink)
jkdas's Avatar
How abt two custom made boxes for Alto, that fit at the ends of teh boot? You get stuff like these here anyway.
__________________
-__-
Old 2nd May 2006, 19:37   #30 (permalink)
Autophile's Avatar
There is a lot more than adding just LP and HP filters. The drivers are aligned to each other in the passive crossover to use in the car environment and moreover the voicing, sensitivity and timbre of each driver is matched in a three way component to give a coherent sound, rather than each driver blowing their own trumpet.
In a three way component the midrange is the most important and critical driver and is the most expensive component in the whole set in majority cases. The midrange driver of 4" component cannot match the performance of these dedicated midranges when it comes to reproducing complex midrange passages of music and female voices.
I suggest if someone want to use three way, use the properly designed three way system which will save on the hassle and save on the amplifier channels.
For DIY and experimenting with different drivers Go Active !!! (then you have to spend on multiple amplifiers and active crossovers) For three way front stage you need 6-Ch of amplification + 2 ch for rear fills if any + Mono for subwoofer if any.
So I suggest go for passive 3-Ways...its easier on pocket.
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Thread Tools
Indica Vista: What's the right size? k_ajay Tyre & Alloy wheel Section 11 15th September 2008 13:49
TATA Indica XETA wheel size luvjascha Tyre & Alloy wheel Section 18 23rd July 2008 20:46
Speaker size for Palio Stile 1.6 Sports? uttamc Ask the Gurus 7 29th May 2007 23:14
Fiat siena (new shape) speaker size ece2k2 Ask the Gurus 17 25th April 2007 13:53
Upgrade to Mid Size Car within 6-7 from Indica Rahulk76 Hatchbacks 22 21st January 2006 07:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
