Thread Tools
Old 2nd May 2006, 21:54   #31 (permalink)
Bass&Trouble's Avatar
Does this thread somehow suggest that someone out here wants to buy a good quality 3-way component set?
In that case I have my Canton Pullman 3.28 which I don't need any more thanks to the Corals which I think I should get to the marketplace. It's an old model but unused.
__________________
Operator! Give me the number for 911!
Old 3rd May 2006, 05:59   #32 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
Originally Posted by Sam Kapasi
LOL by that logic, I should be happier when you buy Infinity panky- it's the same company
I know sam bhaiya, lekin....thats how my budget permits....to keep ya happy on JBL only!
__________________
SINGH IS KINNNNNNNG..
Old 10th May 2006, 22:24   #33 (permalink)
panky12345's Avatar
thanx everyone! aage kaa to ho gaya...ab thoda peeche bhi dekh lein!
wondering if anything could be done to accomodate a pair of components at the rear doors as well....cauz by default, Indica does not has a stock location to accomodate the speakers at the rear and trunk is gonna be full with sub(s) in ported box(es).
custom-made fiberglass enclosure....na baba, too expensive.
__________________
Old 11th May 2006, 04:04   #34 (permalink)
panky12345's Avatar
sorry, if NOT too expensive!
__________________
Old 11th May 2006, 07:28   #35 (permalink)
panky12345's Avatar
gunman bhaiya.....kahan ho aap? or i'm too early by IST!!
__________________
Old 11th May 2006, 16:32   #36 (permalink)
kb100's Avatar
Originally Posted by navin
nice gunbir...love your show and tell pics...
there are many 4" components out there. mate them to a 6" woofer and you can make your own 3 way speaker by modifying the crossover.
How do you modify a crossover.... I have found the price difference between a 2-way and a three way is rather steep... definitely does look like most maufactureres are charging a premium for it...
In fact I had almost decided going Active would be a much cheaper alternative..however this would also be an attactive proposition for those who want to go passive, yet keep costs in control...
__________________
A closed mouth gathers no Feet.
kb100 is online now   Reply With Quote
Old 11th May 2006, 16:58   #37 (permalink)
I wouldn't call modifying a 2-way crossover to support a 3-way system a particularly easy job. The easier option, as JB professes, would be to use the drivers in concern in an active configuration by using a good quality active crossover, and get rid of the passives altogether.
__________________
Old 11th May 2006, 17:23   #38 (permalink)
Autophile's Avatar
Modification of crossover will not help. The price difference between 2-way and 3-way is not because of the crossover. Its because of the addition of a midrange driver which is generally expensive moreover dome midranges are expensive than cones.
Going passive is the cost effective way of going 3-way. In active there are problems caused mainly by additional expenses .
There are very few headunits which have provision for 4-way active system and are expensive (eg. Clarion HX-D2, Pioneer P9 combo & ODR's etc). Adding a crossover is a solution but a good quality crossover costs as much as a heaunit itself, when added with the cost of the headunit comes same as the HX-D2's and P9's which are better options anyday.
Also the amplication cost increases as you need only two channel in passive front stage vs 6ch in 3-way active and 4 ch in 2-way active.
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Old 12th May 2006, 10:56   #39 (permalink)
navin's Avatar
Originally Posted by Autophile
Modification of crossover will not help. ...
The 4ch 2 way active mated to a 2 way passive (making a 3 way) might be the best option. 4 ch. amps are common. Using on 4 ch amp to power 3 way front speakers and using a second 4 ch amp to power the sub and rears is a grea idea if you own a car that can accomodate a midrange and tweeter on the dash.
BTW most midrange domes dont go mcuh below 250-300Hz. Midrange cones can go lower and the expense of some loss in upper mid detail. BTW 300Hz is about the 50% mark on the Energy spectrum. About 50% of musical energy is below 300Hz and 50% is above.
Old 12th May 2006, 16:11   #40 (permalink)
Autophile's Avatar
BTW most midrange domes dont go mcuh below 250-300Hz. Midrange cones can go lower and the expense of some loss in upper mid detail..
Right navin, dome midrange sound better than cone midrange because of low moving mass of the diaphragm and the dispersion pattern of dome. The issue is that they don't go low.
As in the case of midbass their ability to produce midbass well or midrange well same happens in the midranges ability to play upper midrange well or lower midrange well, either of one can happen. Its upto a persons choice what he/she wants.
__________________
Danes Don't Lie !
Old 12th May 2006, 16:23   #41 (permalink)
If a DIY movement has to be put in place, maybe you guys could let me know, since Peerless makes a wide variety of drivers that would be very useful to the DIY enthusiast. I'm actually reminded of this by the mention of the dome midrange (DMR), and Peerless makes a 2" metal-dome DMR which is quite a sparkling lil fella. Another Peerless product that I think could be of interest in the car audio domain is a 4" enclosed midrange that they make. It's a 4" glass fiber cone neo motor driver with a rear chamber. This could be useful for cars like the Santro where the 4" stock location upfront is a silly one which causes the bass to cancel unless used in conjunction with a steep and high, high-pass filter. It is practically pointless to invest in an expensive 4" component set for a car with a location like that. The only drawback of the Peerless 4" midrange however, is the mounting depth. The rear chamber is about 4" deep, and would probably not fit into the dash of an Indica, but I haven't tried. I believe the Peerless products are exceptionally good quality for the money. I haven't had the time to explore the potential of such products in-car to the fullest, but would willingly help anyone wishing to engage in the same.
__________________
Old 12th May 2006, 17:14   #42 (permalink)
navin's Avatar
B&T, I sincerly wish and hope that Peerless India is able to help DIYers. However I I fully understand their inability to do so given that we are such a small community with such extreme demands.
Old 12th May 2006, 17:17   #43 (permalink)
Autophile's Avatar
And extreme weather conditions of India which peerless drivers has to deal with
__________________
Danes Don't Lie !
Old 12th May 2006, 17:19   #44 (permalink)
navin's Avatar
It is usally the surround that dies first and this is easily rectified using butyl rubber.
Old 12th May 2006, 17:37   #45 (permalink)
I don't see the trouble with Peerless speakers in the Indian environment. And none of the Peerless speakers employ foam/ cloth surrounds, all are butyl rubber, and they have almost competely stopped making paper cone speakers except for some overseas home audio clients.
__________________
Thread Tools
Indica Vista: What's the right size? k_ajay Tyre & Alloy wheel Section 11 15th September 2008 13:49
TATA Indica XETA wheel size luvjascha Tyre & Alloy wheel Section 18 23rd July 2008 20:46
Speaker size for Palio Stile 1.6 Sports? uttamc Ask the Gurus 7 29th May 2007 23:14
Fiat siena (new shape) speaker size ece2k2 Ask the Gurus 17 25th April 2007 13:53
Upgrade to Mid Size Car within 6-7 from Indica Rahulk76 Hatchbacks 22 21st January 2006 07:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
