Thread Tools
Old 22nd May 2006, 04:51   #1 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
Default ICE performance differs in petrol or diesel vehicles?
Hi, I dont know how far its true....but I went to Circuit City (MN to be in particular) today with one of my freinds to get his ICE done.
He owns a diesel car and wanted to have something real bassy and punchy. There was a works manager,Tom, who gave me a new line to think. He said that the good ICE installs perform very well in petrol vehicles and not the same in deisel vehicles as the alternator in deisel vehicles is not meant for ICE loads and the current drawn by bassy/punchy ICE set ups leads to further problems in deisel vehicles....commonest of them being repeated problems with SELF.
what is this? i was clueless and told my friend to wait 4 a day or two so that i can get some logical deductions. (TBHP zindabaad!)
__________________
SINGH IS KINNNNNNNG..
Old 22nd May 2006, 07:57   #2 (permalink)
jkdas's Avatar
Diesel cant dont depend on teh battery to run and maybe hence it doesnt haev a powerful alternator, maybe.
I was suprised to see that the stereo of karthik247's skoda didnt shut off when he started his car. Maybe an advantage being a diesel.
Can someone enlighten.
__________________
~ I n d i v i d u a l l y , we are one drop. Together, we are an ocean. ~
Old 22nd May 2006, 11:06   #3 (permalink)
panky12345's Avatar
exactly JK, that's exactly i was wondering on.....what the heck the mode (ie diesel/petrol) on the earth has something to do with ICE (or battery/alternator).either we can assume that diesel vehicles are equipped with not so good alternators (generally) that can take a good ICE load (***-u-ming that they have some other more important functions to perform)?
__________________
Old 22nd May 2006, 13:26   #4 (permalink)
Sam Kapasi's Avatar
I think this is absolute crap and I don't agree. ICE can perform just as well in a refined-diesel vehicle as a petrol.
I also think diesel cars often come with a better equipped battery (to run the heater etc?)
I may be wrong, but I think Tom doesn't know what he's talking about.
__________________
Live the YetiLife®
Madonna is a Goddess.
Old 22nd May 2006, 14:08   #5 (permalink)
low_bass_makker's Avatar
Infractions: 0/1 (5)
As far I Know the diesel Vehicle has a larger battery than the petrol model due to excessive current demand made by the starter due to diesel engine. The diesel engine require more power to start than a petrol. In the diesel engine the fuel has to be compressed. But the petrol the fuel has to be ignited. Thats why the petrol engine are lighter and diesel are heavy. As far ICE is considered it will sound the same whether it is petrol or diesel. But in a diesel it will play for a long duration as the battery is larger than the petrol one. But I advice if u have a amp in ur car never play it with engine off. Always start ur engine before playing ur ICE........
__________________
156.6 db, naa....time is coming to cross it......
Old 22nd May 2006, 14:18   #6 (permalink)
Bass&Trouble's Avatar
Rooobbish! .... Sir Geoff Boycott
Most diesel vehicles have higher-amperage alternators than petrol vehicles. The self starter has nothing to do with the alternator. During cranking, only the battery is supplying the power. Diesel starters are more rugged than petrol ones, but once the engine is started, there is no dependence on the battery/ alternator except for a small electrically operated fuel switch, which is required to stop the engine or sometimes the microprocessor. There are also no spark plugs in a diesel engine, so that's one area (compared to a petrol engine) where in fact, electrical interference with your audio setup is out of question. Where is the disadvantage?
In most cars, the 'ACC' contact which supplies the power to the head unit is disconnected when the key is turned to the cranking position, and reconnects when the spring loaded starting switch returns back to the original position. This is a safety measure, and is also intended to disconnect all power consuming devices so that the most energy can be used for cranking. If you connect the stereo to some other ignition position, or direct to the battery, or if the 'ACC' remains on even during cranking, the HU could remain on, and the illumination may just dim a bit when you crank. This, however, is not desirable. It is best to switch off the stereo before starting.
Yup, powering up the heater plugs is one. Also the torque to crank a diesel (compression ignition) engine is far higher than that required for a spark ignition engine. So these guys have much larger batteries that have higher cranking currents.
I've used the word 'crank' so much, i'm feeling cranky.
__________________
Operator! Give me the number for 911!
Old 22nd May 2006, 19:39   #7 (permalink)
speedzak's Avatar
The man should be feeding his diesel car with something other than diesel that his car started behaving absurd, now he is confused and took some heavy stuff and WOW! another einstein is born : he invented that ICE sounds better in petrol cars and not in diesel cars!
What an amazing discovery!!!!!! Yaaaa????
__________________
Chitty Chitty... Bang... Bang... Boom!!!
27th October 2008.
Old 22nd May 2006, 20:05   #8 (permalink)
shuvc's Avatar
I wonder how it sounds in LPG cars and maybe the Reva .. hehe
__________________
PIGZILNKILJBSCOMB
Old 22nd May 2006, 20:10   #9 (permalink)
Don't even try to fit a SPL system in your Reva unless you have a really long 'extension box' to remain charged wherever you are going!
__________________
Old 22nd May 2006, 23:37   #10 (permalink)
panky12345's Avatar
thanx for all the replies....had this statement been made by our freindly sadakchaap car accessory wala in dilli, i wdnt' have posted here. but yaar surprised, even in US and that too Circuit city and top of it, WORKS MANAGER looking after ENTIRE ICE set-ups. I mean gimme a break! i'm gonna offer him a membership to TBHP (only if he pays me 500 $$$$) LOL!
any more inputs?
__________________
Old 24th May 2006, 15:55   #11 (permalink)
any more inputs?
The only way a diesel vehicle would be inferior to a petrol vehicle could be in terms of the engine noise, which is higher in most but not all cases.
__________________
Thread Tools
Mechanical upgrades for Indian vehicles for enhanced offroad performance DKG 4x4 & Off-Roading 13 30th August 2008 10:03
ICE in the Most unexpected Vehicles blueraven316 Sound Off and Show Off 34 23rd October 2007 17:38
Diesel engines -- different types and good diesel vehicles FourXFour Technical Stuff 3 23rd September 2006 08:57
cng:diesel and petrol vehicles hellspawn Technical Stuff 2 21st April 2006 21:12
Registration of CNG/petrol vehicles. Tarun The Indian Car Scene!! 0 29th July 2004 18:20
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
