Thread Tools
Old 22nd May 2006, 18:21   #1 (permalink)
sharu's Avatar
Default Car audio setup for zen
Hi All,
Found lots of useful info on the thread....but was not able to understand most.....since iam very new to the audio installs....
Guyz could u pls guide me get the best audio setup.... My budget is around 20-22K......and my car is zen vxi 2003 model....
sharu is offline   Reply With Quote
Old 22nd May 2006, 18:37   #2 (permalink)
rsjaurr's Avatar
Originally Posted by sharu
Hi All,
Pioneer HU 9k
front 6.5"compo
& rear 6.5"coax 10k
wiring+install with rest of money
for more bass,get 6x9" for rear but that wil increase ur budget.
upgrade with a decent 4-ch amp later.
spk brabds r sony/pio/kicker/blau/JBL/Hertz etc...
rsjaurr is offline   Reply With Quote
Old 22nd May 2006, 19:21   #3 (permalink)
sharu's Avatar
thanks rsjaurr for the reply.....
looking at ur suggestions i started browsing the different speakers available.... found C608GTi
16.5cm (6.5") 2-Way Coponent System (JBL), also
XS-HT170SN
17cm 2-way Seperate Speaker (SONY)
now confused which one is better also dude on the JBL website iam not able to find rear 6.5"coax could u pls help me out with the model number...
pls help on the brand and model numbers for each
thanks
Old 22nd May 2006, 19:35   #4 (permalink)
jkdas's Avatar
HU frm 5 to 9k ; Pio, Blaupunkt, Sony; Alpine maybe too but frm 10k up I guess
Sony and Blau HU's come with B&W version
as rsjaurr posted; compos at the front is a good thing if you love your music. YOu can go for co-ax if you aint particular.
And at rear, just co-ax. But if you want a bit more thump at less money ( no amp + sub) get a 6x9.
Check out other Bangy TBHpians install for an idea. Stay with same company speakers if you can. JBL, Blau, Pio, Sony speakers would keep you within your budget. There are other brands too taht may please you , so check and get back to us or teh best thing, use your ears
For PIO hu price http://www.team-bhp.com/forum/227800-post36.html (Audio setup for Wagon R Vxi)
__________________
-__-
Old 23rd May 2006, 15:01   #5 (permalink)
rsjaurr's Avatar
XS-HT170SN
thanks
JBL is far better than sony.
I am not sure abt model no. but u must go for compo for front and 2/3-way for rear.U can find plenty of information here abt model no. or Sam can help u.
Old 23rd May 2006, 15:46   #6 (permalink)
sharu's Avatar
thanks rsjaurr and jkdas,
after going thru the forum, i have shortlisted these for my zen, work has been a hectic offlate so no visits to any shops yet, planning for this weekend or next....
pio 6850
front - GTO 427
rear - GTO 937
wiring + install
guyz now, could u tell me how much could this cost(will i get this within my budget 20-25K) , also is this a good setup or any other option....
is this setup good enough for good bass, or do i have to get a sub woofer as welll.... also is amplifier a must if i have to get a sub woofer...
pls rply guyz....
Old 23rd May 2006, 16:14   #7 (permalink)
amit_sound's Avatar
pio 6850
front - GTO 427
rear - GTO 937
wiring + install
pls rply guyz....
Without subwoofer setup:
pioneer HU would cost aroung Rs 8500,
GTO 427 is Rs 3000 i guess (becaue price of old GTO426 was Rs2500)
GTO 937 is 4950
JBL wiring kit Rs 2990
4-channel sony amp- 4500
Total = Rs 24000 app
Amplifier is a must if you wish to install a woofer, beause HU dont have enough power for driving a sub.
Ya i just heard the new GTO 7 -series rear and front speakers, and they were great!! With this setup your bass needs should be satisfied without a subwoofer. Believe me this above setup is a good setup without a woofer.
If you wish to have a sub, then i guess you will have to sacrifice the front speakers or the rear speakers , because your budget is 25000 max.
With subwoofer:
Pio hu 8500 RS
Rear GTO (7-series) 937 Rs 4950
Amp 4 channel pio 6100f Rs 7500 (app)
pionner woofer Rs 3500
Wiring 2k
Total app = 25000
But do remember to bargain on the above mentioed price list
I would perfer the first setup option (without subwoofer), as i make a good basic system, and futher upgradations would be easy.
amit_sound is offline   Reply With Quote
Old 23rd May 2006, 16:38   #8 (permalink)
sharu's Avatar
Hi amit sound, thanks for the rply.....if i go with the first setup....do i need the 4-channel sony amp....also could u tell wht is the advantage of having this amp, and if i dont have this amp wht wil i miss out on....for the fist setup with out sub woffers
Old 23rd May 2006, 17:14   #9 (permalink)
amit_sound's Avatar
In the first setup i.e without the woffer, you can skip the amplifier. But, by not installing a 4-channel amp, the sound produced will not be very clean. Morover without the amp, if you turn up the volume loud, you will get distortion, which we call "speakar fattha hai!!!". For example using a pioneer HU, which has max volume level of 62, you will notice clearly that at around 30 volume level and above distortion occurs. At low volume level you will not notice too much of distortion.
What i would suggest is that on the day when you go for the setup, just listen your system with and wihout the amplifier. I bet you'll see a hell of a difference.
Old 23rd May 2006, 17:19   #10 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Here's my 5 cents guys!
The first setup is good for a basic install which can be upgraded anytime. And I think you can avoid the 4channel amp and save up those bucks too.
And if you do want a SUB now, then consider this option:
Pio hu Rs. 8500
Rear JBL 2way 6" co-axials Rs 2750 (app)
SONY Amp 4 channel Rs 5000 (app)
pionner SUBwoofer (DVC) Rs 3500
Alpine SPE 1002 4" co-axial speakers Rs 2400
Wiring Rs 2000
Total app = Rs 24,150 = BANG FOR da BUCK!
I would still recommend you to stick with the first option and upgrade one at a time. This way you'll be able to buy better options without hurting your pocket much.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
Old 23rd May 2006, 17:51   #11 (permalink)
sharu's Avatar
What i would suggest is that on the day when you go for the setup, just listen your system with and wihout the amplifier. I bet you'll see a hell of a difference.[/quote]
thanks amit_sound....i will surely keep this in mind.......
also speedzak, thanks for ur comments.........right now will go with the first setup and then as u say wil upgrade one by one
Guyz is there any thing i have to take care of while going for the install for the first setup, ..........in one of the thread i read about the quality of wires beeing used as well, could u guyz suggest which would be the brand i need to go for.....
Old 23rd May 2006, 18:12   #12 (permalink)
amit_sound's Avatar
Yes, wiring does demand a lot of attention. JBL original wiring kits of good value for money, Monster cable is also fine...There are many brands, but i again we need to look at the budget also.
During the installation:
1. Make sure that the wiring is genuine and not damaged. As i had read in one of the threads, that in delhi, a person installed wires that had a lot of cuts on it.
2. Avoid looping of wires.
3. Keep about 1 or 2 feet extra for wiring, so that in future shifting of some audio components is easy.
4. I installing speakers in the front door, make sure that there is no leakage of water inside the door, because monsoon is arriving.
Rest.... keep your eyes open during installation, and maybe then you can also guide us about extra precautions to be taking while installation!!!!
Old 23rd May 2006, 18:15   #13 (permalink)
sharu's Avatar
dude also, is it better to go for the box for the rear speakers or to go for the plank........
Old 23rd May 2006, 18:23   #14 (permalink)
speedzak's Avatar
If you're getting 6X9 ovals, then box is highly recommended. Or MDF parcel tray will suit fine too. But never ever consider mounting these into the boot door.
If you're getting 6" co-axials, then fitting it into the door is OK, But put it into some good box till the SUBwoofer arrives.
__________________
Old 23rd May 2006, 21:13   #15 (permalink)
sharu's Avatar
hi speedzak,
planning to get rear - GTO 937 6X9 for the rear, so need a box....also do we need to go for the custom box made by the installer, or are the boxes available from the manufacturer itself.....
i suppose custom made boxes would be cheaper....any idea wht material they need to use
Thread Tools
Woofer from a computer sound system possible in a car audio setup? Deeps Ask the Gurus 2 5th August 2008 23:51
Car Audio Setup for SANTRO XING jkdas Ask the Gurus 588 7th October 2007 11:38
Ice Setup Zen – Audio Gurus plz help nicejits Ask the Gurus 14 20th September 2007 16:45
Advice needed for high end audio setup for my car Aryaan Ask the Gurus 9 12th September 2007 11:40
Please Advise on this Car Audio Setup k_ajay Ask the Gurus 29 6th July 2005 14:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
