Thread Tools
Old 16th August 2004, 17:09   #1 (permalink)
Sahil's Avatar
Default iTrip for iPod
Am planning to get the iTrip for my iPod in a few days as i am sick of making 100s of cds for my car this seems like the easiest way to solve the problem. However i wanted to know how good the quality of this radio transmitter iTrip is? If anyone here is using the iTrip for their iPod do let me know how much quality do u lose? I dont want too loss too much quality in the bargain.
__________________
______________
__________
______
__
Sahil is online now   Reply With Quote
Old 16th August 2004, 17:13   #2 (permalink)
Rehaan's Avatar
Sahil,
The other option you have is getting an AUX cable for your system.
Is it a blaupunkt or alpine? (does it aldready have a CD-changer?)
Because you get a Rs 650/- AUX cable (for blaupunkt) that plugs into your CD changer port which you can plug directly into your iPod with much less loss in quality.
See if this is a viable option,
R
ps - why the itrip? i know a couple of people who have FM transmitters and i think they all have the Belkin one.....so just wondering.....
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 16th August 2004, 17:20   #3 (permalink)
Rehaan's Avatar
Also, just as a theoretical point of reference,
Cd quality is 44.1Khz 16bit Stereo
Radio quality can be equated to 22Khz 8bit (Mono/Stereo)
R
__________________
Old 16th August 2004, 17:44   #4 (permalink)
Sahil's Avatar
Thnx for the reply Rehaan... The iTrip looks really neat and it is made for apple by i think Belkin only. I have the factory fitted Clarion system (Single Cd) in the accord so how do i go about getting the AUX thing for it? How is this AUX thing fitted?
__________________
______________
__________
______
__
Old 16th August 2004, 21:14   #5 (permalink)
Rehaan's Avatar
Hey Sahil,
Well its good news that you dont have a CD changer.
Why dont you give the accessories guy @ the honda showroom a call and ask him if he knows of an "auxilary input cable" for your system. Even if he doesnt, give some other car audio shops a call and check it out.
The Blaupunkt cable looks like this fyi >
So one end goes into the back of your head unit... and then the tricky part is the other end (with the 3.5mm headfone jack)....which needs to be pulled out from somewhere in your dash or under it... or maybe even the glove compartment!
cya
R
__________________
Old 16th August 2004, 23:11   #6 (permalink)
lamborghini's Avatar
u can also get a sony cass head....
its a cass. with a wire coming out of it from 1 end which is connected to the ipod andu put the cass in and play the son of yr choice on the ipod
my dads got the itrip....
it aint very good as its got a range of 1 meter only
i will ask him for details if u like
__________________
¢нєєяѕ
ℓαмвσ
lamborghinirules@gmail.com
lamborghini is offline   Reply With Quote
Old 16th August 2004, 23:52   #7 (permalink)
Rehaan's Avatar
Originally Posted by [b
Quote[/b] (lamborghini @ Aug. 16 2004,20:41)]u can also get a sony cass head....
Ahh!! old school
I totally forgot abt that....lol
used to use that with my discman b4 in dash CD players were affordable....
However do note that the quality will be better with the aux cable.
cya
R
__________________
Old 17th August 2004, 00:10   #8 (permalink)
aadix's Avatar
hey rehaan and lamborgini, how will u use a cass head in a single cd player??, cass head looks like a cassettte right?
i would suggest sahil go with the aux cable, better yet , if you have time go to the honda dealer and ask him to remove the head, most of the time the aux wire port looks like the normal ones in the tvs and vcds, ie one red and one black
u get sony aux wire for 80 bucks(looks same as rehaan pic , but instead of the purple thing u will have the read and white connectors), this is what i had done for my esteem which has a pioneer single cd player, i use a casette player with it
__________________
"live to ride,ride to eliminate"
aadix is offline   Reply With Quote
Old 17th August 2004, 02:16   #9 (permalink)
Rehaan's Avatar
Quote[/b] (aadix @ Aug. 16 2004,21:40)]hey rehaan and lamborgini, how will u use a cass head in a single cd player??, cass head looks like a cassettte right?
Lol,
I just assumed it was a 2DIN with cd & cassete in the accord since lambo mentioned it.
Quote[/b] ]
Hey aadix, what you are talking about are RCA plugs.
Actually that is just a roundabout way of doing it.
Instead of getting a direct 3.5mm to aux input, u will have to get a 3.5mm to RCA & RCA to auxinput.
However....if this cable has aldready been providedwith the head unit...then the 3.5mm to RCA will be a less expensive proposition.
A lot of head units have RCA outputs for amps etc... whether this one has a direct RCA input is worth a look at....
Check it out>
cya
R
__________________
Old 17th August 2004, 02:29   #10 (permalink)
aadix's Avatar
no r
think you didnt understand me
in my case my pioneer already had an aux in port in the form of those rca ports (ie those red and whit input slots, not the wire)
i bought the wire from a sony authorised centre, which had the red and white conncetrs and that 3.5 mm
bascially it was just like how you plug into a vcd player or a tv!
added after rehaan edited his post:
hey rehaan didnt see you editing the post, my wire is same as in the second pic of yours
looks like now we r on the same wave length!!
__________________
Old 17th August 2004, 17:07   #11 (permalink)
Sahil's Avatar
I will check for the AUX cable i think that would be the best option ... a close frnd of mine owns a shop on milan subway for all this ... i got my amp and woofer put in the accord thru him also so i will ask him abt it. I think a common AUX cable should fit in all deck makes. About the casstte thing, i was aware of that option and yes the panel is double din but i hate the whole cass hassel used to do it with my discman in the previous cars. The iTrip puts u to soo much ease man no wires thats the best part!
__________________
______________
__________
______
__
Old 17th August 2004, 17:24   #12 (permalink)
Rtech's Avatar
straying a bit here, but have you guys heard about the Digisette. It looks and feels just like a regular cassette but is infact an MP3 player! You just pop it into our regular player like you would a cassette!
Pretty cool IMO.
Check out the review Here
Rtech
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 17th August 2004, 18:18   #13 (permalink)
Rehaan's Avatar
Quote[/b] (rtech @ Aug. 17 2004,14:54)]It looks and feels just like a regular cassette but is infact an MP3 player! You just pop it into our regular player like you would a cassette!
Wow...thats really cool!!
R
__________________
Old 21st August 2004, 15:24   #14 (permalink)
cool
anyone have prices or do i have to settle for a regular single din player ......
p.s
sahil how do u like ure honda supplied system abd spkrs
__________________
¢нєєяѕ
ℓαмвσ
Old 21st August 2004, 22:26   #15 (permalink)
Sahil's Avatar
@ lamborghini- The system that came with my accord is the double din Clarion not sure of the model number. I changed the speakers to pioneer 300W just the rear and have added a woofer and amp in the trunk on a box without any tray cutting.
Well i got the iTrip its good but not that clear... maybe i havent set it up too well sometimes there is a disturbence specially when i press the horn or put the rear defogger on.
__________________
______________
__________
______
__
Thread Tools
Help with Ipod viper Gadgets, Computers & Software 15 6th July 2008 12:52
need an ipod whatcanthisbe Gadgets, Computers & Software 32 15th May 2007 02:19
The Great Ipod Thread - All Ipod and MP3 player related threads are merged here. gunbir Ask the Gurus 154 8th November 2006 10:55
Ipod Help! Iceman Gadgets, Computers & Software 7 7th August 2006 19:24
Ipod Itrip Pirate radio stations. sbfx Shifting gears 4 20th December 2004 18:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
