| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I have following set up right now. All fitted by dealer. Pioneer HU, Blaupunkt tweeters inside wing mirror ornament Blaupunkt front speakers In the door panel, Blaupunkt rear speakers on the parcel tray. I got it right, I do not know the par numbers of any of them. In fact I was/am not very serious about the audio set up. Still didn't want to get bored during routine office drives so got them fixed. Reason I went for Blaupunkt speakers is that they were OEM ad did not need any cutting and breaking of anything on my then new car, they were bolt on. After seeing extravagant set-ups in this site, I some times felt, "could I have had a better ICE?", and some times I have felt at times the music from the rear speakers are distorted, and door panel resonates some times. Still I do not want to go for a lot of bells and whistels, Dont wanna hide amps everywhere and make loud noise (Music lovers excuse me for this). Could the experts here, please help me minimise my small grouse I mentioned, with out much of tweaking. Does replacing the speakers to JBL do anythihng better? If so do they fit in without having to use saw and chissel? What can be done to stop/minimise resonance? Thanks in advance guys.... Not to forget, who can do this work in Bangalore best?
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #2 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Phew... CBE!!
| Rear speakers distortion... either the speakers are bad... or the HU is clipping.. Panel rattling... you will have to subject the panels to some kind of sound proofing treatment like Dynamat/wurth etc.. Tweeters... I am sure you would have tried lowering the treble/High frequencies on the HU.. does this stuation exist despit this? EDIT: Oh Yes... What car??
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 8th June 2006 at 18:51. |
| | #3 (permalink) |
| BHPian | Well, My car Fiat petra... Welcome your comments, Keep it going gentlemen. I did not quite get your comment about tweeters.. And the rear speaker problem! Its funny, It started after Sundaram changed the rear window glass. They had spilled glass peices (minute) on the speakers. I cleaned them later and the problem got sorted out. Now I am looking out for a little more better quality. How better are JBL compared to Blaupunkt?
| | #4 (permalink) |
| Senior - BHPian | Blau do have good units and used to be associated with Merc sometiem back ( now too? ). Just figure what you can shell out or what you want. Do you want compos or co-ax? Since you have a sedan, a 6x9 at rear would give you nice thump and a compo at front a cleaner sound. Maybe you can even have a co-ax at the frnt. Its your taste. An amp would definetly help you get a better sound. If the original speakers are good; keep them and jsut add a 4 channel amp. And as KB said, get soem deadeners for your doors.
__________________ -__- |
| | #5 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Blaupunkt Velocity and ODx models are quite ok. I have not been happy with their GT models (not to be confused with JBLS GTO series). If you have Velocity all I would do is add a nice amp and a sub (depending on the ammount of space you are willing to sacrifice). If you have no boot space to sacrifice for a sub a pair of 6x9 can do fine. With some effort and the right sub you can even use a pair of 6" coax and a sub in the rear deck. Either a 4 ch amp (with 2 channels bridged to drive the sub) or a 4ch and a 2/1ch. amp or a 5 ch. amp would also help. Please let us know your budget and goals.
__________________ Scixelsyd Etinu |
| | #6 (permalink) |
| BHPian | Gurus, Pardon my ignorance! What ever you are talking, like a Italian dishes, sounds yummy, but do not have a clue what you are talking about. What is a sub( I assume a sub woofer)? What is an amp ( amplifier?) What is compo? no guess Sounds like shrt form for component, but again, what component? What is co-ax? sounds like co-axial, but again, co-axial what.. cable? What are its advantages? What are you trying to put in my boot? why are you talking about sacrificing it . are you goint ot cut its throat?I assume channel means a channel of amplification in amp? For a stereo you have 2 channels, what is 4 channel then? What is bridging? Please give me some gyan guys.... . Is there linky I can check this out?
| | #8 (permalink) |
| subwoofer usually require significant space in the boot. in return they offer you bass (low freq. sounds). it is usualy a trade off between how much bass one wants and how big a subwoofer one wants to install.
| | #9 (permalink) |
| Distinguished - BHPian ![]() | Looks like I'm the one who will answer your questions forgive us, we take things for granted sometimes and it takes a little audio innocence like yours to bring us back to earth. OK so let me help What is a sub( I assume a sub woofer)? Yes What is an amp ( amplifier?) Yes What is compo? no guess Sounds like shrt form for component, but again, what component? A component set is a set of speakers where you get 2 mid woofers (generally 5.25" or 6"), a crossover network and a pair of tweeters. These sound very nice in the front of your car. What is co-ax? sounds like co-axial, but again, co-axial what.. cable? Co-Axial means speakers with a common axis. For example, regular car speakers have a woofer, midrange and tweeter built all on the same axis. Probably like your blaupunkts right now. I assume channel means a channel of amplification in amp? For a stereo you have 2 channels, what is 4 channel then? A 4 channel amplifier is basically 4 seperate chanels of independent amplification in one body. You can use 2 channels to drive the front speakers in stereo and the other 2 to drive the rear. What is bridging? Instead of running pair of speakers on 2 channels, if you combined the power of two channels to give you one powerful channel to drive (for example) a subwoofer, that is called bridging.
__________________ Live the YetiLife® |
| | #10 (permalink) | |
| BHPian | Quote:
.. Buts its true,This is how I feel when I go thru posts of Navin, jkdas and other ICE Gurus Its really complicated to understand there Hi-fi terms... It would really be helpful to people like me and DRC if you people can suggust things in layman terms. Cheers Last edited by greatDrive : 9th June 2006 at 19:59. | |
| | #11 (permalink) |
| greatDrive, I thoguht we WERE using layman terms! Just ask Sam how much effort I put into tempering the technobabble out of my posts. Apparently I am not doing enough. Thanks for the info. Will try to keep it simpler still.
| | #12 (permalink) |
| BHPian | Bhai log, Thanks a lot... The linky and the answers you experts gave, really helped me a lot.. Now, I can spell many words in this subject. Many questions answered, and many getting surfaced. More questions to follow gurus,,, BTW, did any one answer "should changing the speakers alone to JBL make a reasonable diff to the sound quality?" Is it obsolutely necessary to add an amp?
| | #13 (permalink) |
| Senior - BHPian | Usually OE speakers are low end ones and hence an upgrade to better version of same brand or a good brand like JBL would do wonder. Cheapest 4 channel amp: Sony 504z ; 5k approx. Amp will help you with more cleaner sound as they 'do provide' continous power to your speakers unlike a HU.
__________________ -__- Last edited by jkdas : 11th June 2006 at 01:00. |
| | #15 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Live the YetiLife® | |
| Thread Tools | |
Similar Threads | ||||
| Are you thinking what I’m thinking | Tumbler | Introduce yourself | 11 | 4th July 2008 07:40 |
| Thinking Car Computer! | zuch | DIY - Do it yourself | 2 | 8th June 2008 15:57 |
| Thinking of getting a Ducati..Help!! | Spartan | Motorbikes | 11 | 9th June 2007 02:46 |
| Thinking of IIPM? | simran | Shifting gears | 1 | 11th October 2005 20:40 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
