| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I am new here, had few doubts on how to wire subs with amps keeping in mind the Impedance, Saw some people's posts and thought this is the best p-lace to clear them out, Now I had 3 main doubts , 1) Suppose I have a pair of Single 4 Ohm Voicecoil subwoofers , and want to run it with an Mono Amp which is 2 Ohm Stable, how do we wire both to get the optimum output from the amp which is at 2 Ohms. Also how should I wire it if it had to be run on a 2 Channel amp whose Bridged max output is at 4 Ohms. 2) Suppose I have a pair of Dual 4 Ohm voicecoil subs, and want to run them with the same two amps above how would it be wire to get max output ? 3) Suppose I am running one Single 4 Ohm Voicecoil amp with a single 2 Ohm Stable amp, if I directly connect the sub + , - to the subwoofer's + , - terminals, will the amp set itself to 4 Ohms and produce the output it can produce only at 4 Ohms and not peak power which is at 2 Ohms. |
| | #3 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Phew... CBE!!
| 029RON -- Aint no guru but here goes.... 1) Suppose I have a pair of Single 4 Ohm Voicecoil subwoofers , and want to run it with an Mono Amp which is 2 Ohm Stable, how do we wire both to get the optimum output from the amp which is at 2 Ohms. You wire the subs in PARALLEL 4 / 4 =2ohm Also how should I wire it if it had to be run on a 2 Channel amp whose Bridged max output is at 4 Ohms. you Wire it in SERIES 4+4 = 8 ohms. In this case however you will be presenting an 8 ohm load - generally avoided when doing subs because this reduces the amps output. Ideally you should go for TWO 2 ohm subs IN SERIES to make use of this option, Or if you want to use your 4 ohm subs you will have to get yourself a amp that is stabel @1 ohm 2) Suppose I have a pair of Dual 4 Ohm voicecoil subs, and want to run them with the same two amps above how would it be wire to get max output ? Well you can do ('/' indicating parallel and '+' indiicating series) a) 4+4+4+4 = 16 ohm b) (4+4)/(4+4) = 4 Ohm (or the other way - same result - (4/4)+(4/4) c) (4/4)/(4/4) =.0.5 ohm or is it 1 ohm - slight blip here.. d) Wire them in Stereo - one sub per channel (parallel or series depending on the amp and the above philosopy) 3) Suppose I am running one Single 4 Ohm Voicecoil amp with a single 2 Ohm Stable amp, if I directly connect the sub + , - to the subwoofer's + , - terminals, will the amp set itself to 4 Ohms and produce the output it can produce only at 4 Ohms and not peak power which is at 2 Ohms As explained taking higher impedences than an amps rated minimum impedance is normally not a problem... in certain instances its acually good - the amp has to work a lot lesser. This comes with a max power trade-off. However I dont think this is optimal for Sub loads - The GURU's will now elaborate!!...
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 3rd July 2006 at 11:20. |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| I thiknk KB covered it. 1. Parallel both coils to get 2 ohms. 2. parallel both coils of each sub and run the amp in stereo (2 ohms per channel) most amps that are 2 ohm stable in mono can manage 2 ohms in stereo rather well. 3. amp will manage well and maybe even run a bit cooler.
__________________ Scixelsyd Etinu |
| | #5 (permalink) | |
| BHPian | Quote:
3. Amp will manage well indeed but will it set itself to 4 Ohms ? so for example: if the mono amp's output is 400 RMS @ 4 Ohms and 800 RMS @ 2 Ohms then will it produce 400 RMS If I wire a single 4 Ohm sub directly to the +,- of the amp ? | |
| | #6 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Live the YetiLife® | |
| | #7 (permalink) | |
| BHPian | Quote:
| | #9 (permalink) | |
| Senior - BHPian | Quote:
1) Suppose I have a pair of Single 4 Ohm Voicecoil subwoofers , and want to run it with an Mono Amp which is 2 Ohm Stable, how do we wire both to get the optimum output from the amp which is at 2 Ohms. You wire the 2 subs in PARALLEL 4*4/4+4 =2ohm and then connect it to teh amp which has 2 ohm impedence. 2) Suppose I have a pair of Dual 4 Ohm voicecoil subs, and want to run them with the same two amps above how would it be wire to get max output ? same as setup 1) and connect each pair to each sub ! 3) Suppose I am running one Single 4 Ohm Voicecoil amp with a single 2 Ohm Stable amp, if I directly connect the sub + , - to the subwoofer's + , - terminals, will the amp set itself to 4 Ohms and produce the output it can produce only at 4 Ohms and not peak power which is at 2 Ohms As explained taking higher impedences than an amps rated minimum impedance is normally not a problem... in certain instances its acually good - the amp has to work a lot lesser. This comes with a max power trade-off. However I dont think this is optimal for Sub loads -
__________________ -__- | |
| | #11 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Singapore
| Quote:
Amps dont 'set' themselves in case you are thinking that there's a switch or setting of some sort.. Its the simple V=IR relationship.. The amp supplies a current based on the impedance it 'sees', in an inverse relation.. So, keep reducing the impedance and the amp's current increases, till it cant handle it, starts clipping, and then finally blows.. Last edited by nitinbhag : 4th July 2006 at 12:14. | |
| Thread Tools | |
Similar Threads | ||||
| Doubts on ports | jCube | Ask the Gurus | 5 | 12th November 2007 15:03 |
| Subwoofer Wiring | gunbir | DIY - Do it yourself | 57 | 26th March 2007 11:25 |
| More Impedance Doubts | 929RON | Ask the Gurus | 8 | 6th July 2006 15:01 |
| Doubts | qqplus | Technical Stuff | 15 | 10th February 2006 23:20 |
| Doubts abt airbags | speedsatya | The Indian Car Scene!! | 4 | 5th September 2004 14:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
