Thread Tools
Old 11th July 2006, 14:52   #1 (permalink)
929RON's Avatar
Default Impedance of Subwoofers
We see subs with the same RMS rating with usually 2 different Impedances, like a 500 RMS sub can be either dual 2 ohms or Dual 4 Ohms, now how do they differ in construction ?
Is it the coil meterial or guage makes the difference ? what makes them 2 or 4 ohms
Experts please throw some light !
929RON is offline   Reply With Quote
Old 11th July 2006, 15:09   #2 (permalink)
low_bass_makker's Avatar
I think the gauge and lenght does the trick. In a 2 ohms sub the lenght of the wire used would be less and in the 4 ohms version it will more. this is like a basic concept. there are some woofer for example jbl gti sub in which is a dvc both the vc are made seprately, but in the normal case both the coils are wounded together. not like first one coil is made then the other coil is wounded on the first coil. doing this will change the behavoiur of both the coils so they are wounded simultaneously.
for the coil material for a same series of sub it will be the same.
rest there are more experts here to clear ur doubts.
B&T where are u man this thread will surely attract u. and you are make ur sub youself , u must add a some thing to it
low_bass_makker is online now   Reply With Quote
Old 11th July 2006, 19:26   #3 (permalink)
Bass&Trouble's Avatar
Hi LBM, someone told me you were beckoning
It's great fun to build speakers/ subwoofer, and the brighter side is that even if it turns out sounding bad, you atleast know who to blame. (ok, 2 smileys up)
You are right about the gauge and length part LBM, those are the only 2 easily variable factors affecting the end-impedance of the driver. There is a third, which is resistivity, a property of the material being used to make the voice-coil, and commercially available voice coil copper is mostly standard, so we dont need to worry much about that.
So either you use voice coil wire of a greater length, or you decrease the cross-sectional area of the wire used, to increase impedance, or the converse to decrease impedance.
The other approach is to use 2 or more different windings and internally parallel or serial it to get the desired impedance. This would make the voice-coil multi-layered. So it's like having ....
hang in there lbm, more later. gotta rush now. sorry
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 11th July 2006, 19:43   #4 (permalink)
Ya I missed the vc material it is mainly copper so i assummed to be a fixed. But i remember aluminium is also used these days. or any exotic stuff is not used .....lol
hey thanks man will be hearing soon from u ..............
Old 12th July 2006, 03:59   #5 (permalink)
929RON's Avatar
Even I will be waiting for the concuding part............
Old 12th July 2006, 11:14   #6 (permalink)
navin's Avatar
Usually parallel wires are used. imprdance is a factor of length, "effective cross-section", and conductivity/resistivity of wire. The resistivity of Aluminum is 2.655 while that of Copper is 1.678. For the audiophiles the resistivity of Silver is 1.586.
Hence a copper wire is about 60% more conductive than an Aluminum wire. However copper is also over 3 times are dense as alumimum. Hence for voice coils aluminum is often the best choice. In addition since aluminum is a softer material than copper one can draw it into rectangular crosssections quit easily and wind the aluminum wire edge wise. This allows for faster dissapation of heat generated as the adjacent coils have full sruface contact vs point contact if round wire was used. Some companies use a hexagonal wire to ensure better thermal dissapation.
Another reason to favour aluminum is that al2o3 (anodised aluminum) is a very good thermal conductor while being a very poor electrical conductor so if one were to use anodised rectangular alumiun wire and find a way to edge wind it without damaging the anodising layer one could get a light, thernally and electrically voice coil.
Copper is better used where the ductility of copper and mechanical strength of copper is required.
__________________
Scixelsyd Etinu
Old 12th July 2006, 17:36   #7 (permalink)
Damn...I can hardly believe I spent some extra time at office rather than heading to Churchgate station to head back home, just to write out the reply to this thread yesterday. If not, I could well have been picked off the tracks in pieces somewhere along the western train lines. Maybe I should have listened to Navin and headed to the 'burbs with him. Nevertheless, I'm glad to be here...glad to be anywhere for that matter. .. I signed off abruptly cos that's when news first came in about the blasts.
Yeah, so... a multi-layered voice coil gives you the advantage of arriving at the same impedance desired. But since the current is made to flow through a larger amount of winding material, this is viewed as a technique to increase your power handling. Before, Navin points this out, there is a side effect of the moving mass increasing and this is more profound in smaller drivers and ones that use lighter cones, formers etc. Voice coils wound in series are rare, because it is essentially the same as winding a longer length (more turns) of the same wire rather than breaking and re-joining. Parallel is very common. Also, multi-layer voice coils have to be usually applied so that the required effective length of the coil is achieved without having to increase the winding width and induce unnecessarily large and inefficient overhangs.
A DVC sub would not parallel the two discrete coils internally, and would connect the 2 taps of the voice coil to different external terminal tags to allow the user to alter the impedance in a manner suitable. Although I have been saying impedance, the real notable variation in all these instances is the DC resistance of the voice-coil. So please treat impedance as nominal impedance and not operational impedance which would swing vastly based on the frequency of the input alternating current.
When a manufacturer makes two variants of the same sub, and offers two different impedance options without drastically changing the subwoofer's operational parameters, the two subs are made with exactly the same voice coil diameter, winding width and magnet system, but using different no. of voice coil layers and/ or wire gauge to achieve the exact same thermal power handling.
Tool style... Hope this helped.
__________________
Old 12th July 2006, 22:55   #8 (permalink)
navin's Avatar
B&T between you and me we are gonna scare everyone away.
__________________
Scixelsyd Etinu
Old 13th July 2006, 01:20   #9 (permalink)
just when searching about this vc funda I can across some related to senstivity and xmax and Mms .... here it is
You have to be careful when looking at reference efficiency (sensitivity). You can make a speaker really efficient by designing the voice coil to fit entirely in the magnetic gap. This would likely yield a sensitivity of 104 or so. This speaker may work very well if powered by a low powered amplifier because of the high efficiency but would not be able to produce high SPL at low frequencies because it would have a very small xmax. Actually, if the voice coil length was the same as the height of the magnetic gap, it would have no (zero) xmax.
You can also design speakers for very high power handling and high SPL but those speakers would likely have a very low reference efficiency. Speakers designed for high SPL in cars generally have a larger xmax and therefore lower reference efficiency but would easily out perform the speaker (in the previous example) with the higher reference efficiency at low frequencies.
Speakers that are designed to operate in very small enclosures are usually less efficient than speakers designed for larger enclosures. To make the speaker perform in a small enclosure, the suspension has to be stiff. This will raise the resonant frequency. To get a lower resonant frequency, they must add mass to the cone of the speaker. This added mass and the stiff suspension kill the efficiency.
acording to the person say that a high power handiling speaker with less senstivity would outperform a high sentivity in low frequency.......
above stuff was taken from ->http://www.bcae1.com/speaker.htm
Old 13th July 2006, 02:00   #10 (permalink)
is there any way one can calculate the senstivity of a driver from it theile parameters ??????????????
Old 13th July 2006, 02:11   #11 (permalink)
929RON's Avatar
Smile
Well it did not scare me , this was exactly the kind of info I was looking for, thanks for the Invaluable Gyaan people, much appreciated.
And hey I think I saved someones life too with the post ,
as long as its all for the good ! I will keep troubling you with posts with questions.
Peace
Old 13th July 2006, 02:15   #12 (permalink)
kb100's Avatar
HEY B&T ... great to hear you're okay man... We wouldnt want a B-in-T!!...lol
Yes I agree Navin,,.. that was a frightening post!
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 13th July 2006, 14:32   #13 (permalink)
navin's Avatar
Yes if you have complete set of T/S parameters not just the famous 3 (Fs, Qts, Vas). If you know Cms, Bl, etc.. you can calculate No (efficiency).
__________________
Scixelsyd Etinu
Old 13th July 2006, 14:41   #14 (permalink)
which other parameter are we taking about except the famous 3
Like u have added Cms, Bl and which others???????
Old 13th July 2006, 16:41   #15 (permalink)
navin's Avatar
LBM this is a topic for diyaudio.com not ICE. Transducer design is a long topic. If we went into it here we'd loose the rest of the audience (excpet for a few hardened souls - they know who they are!) :-)
i'd suggest reading books by Weems and Dickanson, and mags like Speaker Builder and Voice Coil.
__________________
Scixelsyd Etinu
Thread Tools
Which subwoofers?? panky12345 Ask the Gurus 84 6th February 2008 23:20
A question about impedance adityamunshi Ask the Gurus 3 13th October 2007 14:36
Questions about subwoofers tsk1979 Ask the Gurus 26 31st May 2007 19:04
Subwoofer Impedance 929RON Ask the Gurus 11 29th July 2006 21:05
More Impedance Doubts 929RON Ask the Gurus 8 6th July 2006 15:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
