| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #151 (permalink) |
| BHPian Join Date: Feb 2005 Location: Bangalore
| Image Dynamics IDMAX12D4 v3 - costs 27K Image Dynamics IDMAX10D4 v3 - costs 25K I had one question about these subs... Their recommended power range is 200-1000W RMS. 1. Is it a suitable companion for an Amp with 600W RMS @ 2 ohms? (Crutchfields suggest keeping AMP and Speaker values as close as possible, where it's fine if amp is more powerful). 2. Let's say I have installed this speaker (with a 600W RMS AMP), what happens when I play it at low volume? Will the sound be distorted below a specific volume (when the speaker is not getting 200W power or volume has nothing to do with power)? Last edited by ST7677 : 15th September 2006 at 12:36. |
| | #152 (permalink) | |
| BHPian Join Date: Jul 2006 Location: Bangalore
| Quote:
On the long run this would be bad to the speaker!.... With the setup mentioned above, you wont get the sound distorted at low volumes.... regards, ant. | |
| | #153 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
these watt ratings are thermal. most speakers are more limited by their physical (mchanical) limits. like i have said before 500W at 200Hz is one thing, 500W at 20Hz will make most woofers complain.
__________________ Scixelsyd Etinu | |
| | #154 (permalink) | |
| Quote:
I am worried that since the Sub is rated at 1000W RMS, using a 600W amp might send clipped signal to it and damage it before it reaches it's physical limit? Last edited by ST7677 : 15th September 2006 at 16:02. | |
| | #155 (permalink) | |
| Senior - BHPian | Quote:
the idmax can be installed in a infinte baffle .....when insatalled that way the 600 watts is more than sufficent as u cannot drvie it to the max when installed in that manner.... if u go for seal then the 1000 watts will make a diff...... last but not the least is ID max avalable in banglore...... | |
| | #156 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
| Quote:
Lets try this... consider your woofers are tyres, and your amp the engine. Would you damage your tyres (which are rated for 160 kmph max) if you only drive upto 80kmph? No, at least not because of that. If set right, your amp will not go into clipping. You will not damage your sub that way. The iDMAx is considered unique among super subs because of its efficiency. You dont need huge power to get high music output levels. 600w is good power, and with one iDMax12 you will get way loud. If you have two running off 600w each, God help you and your car. Have you seen the Image Lancer ("IMAGE" Autopsyche Lancer ICE Install Pics) install? Each iDMax12 runs off 400w in that car and it gets LOUD!
__________________ This used to be a Funhouse, but now its full of Evil Clowns | |
| | #157 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
When clipping, it's more like driving a 160kmph capable tire on some really lousy and bumpy roads. If not the tires, you'll atleast wreck your suspension if you drive it at 80kmph on a road as described. A 600W rms amp can easily overpower a 1000 watt subwoofer, the important thing like you and Navin both mention, is to not use the power recklessly. Gain matching should be accurate, and if not, one should be careful while listening.
__________________ Losers Commute. We Ride. Last edited by Bass&Trouble : 15th September 2006 at 16:59. | |
| | #158 (permalink) | |
| Quote:
ok even if it is 26.5mm and the subs is super good etc.... lets look at sensitivity. lets assume a sensitivity of 87db/1W/1m. at 200W you are looking at SPLs of 110db! Are you sure you want to LBM yourself?
| | #159 (permalink) |
| Ok guys, I am somewhat convincing my self that Audison 4.300 and Audison 1.400 / 2.500 are good amps for me ![]() Audison 4.300 does 4x65W RMS @ 4 ohms with hertz / focal components Audison 1.400 does 1x350W @ 4ohms (damping factor 200 @ 1khz,4ohms) 1x650W @ 2 ohms and 1x900W @ 1 ohm !!! I was thinking of a good subwoofer to go with the Audison. I am not into SPL/showoff, this has to be pure SQ. Though 350W should be sufficient, I think I would still run the amp @ 2 ohms to get 650W RMS max. Please share your opinions/feedback... |
| | #161 (permalink) | |
| Quote:
ebsides the front and rear (Hertz in your case) I'd look at either 2 12" in sealed boxes for the bass. 2 woofers means twice the Sd means have the travel for the same SPL that means distortion can drop by a after of 4 or more (at the voice coil travel gets more non linear distortion really goes up).
__________________ Scixelsyd Etinu Last edited by navin : 15th September 2006 at 18:23. | |
| | #162 (permalink) | |
| Quote:
Here is a good setup done recently by Autopsyche in an Accord. I am posting it here to show you a good 5ch is usually enough for a balanced SQ system. iraghava and aZa heard the car. You can ask them to comment on the sound, loudness etc. Also ask them about the SQ of the Hertz HX300D sub. This car gets loud. Maybe all you need is a 5ch amp based setup. Of course, if you like it REALLY loud, you can always go the other way and get 2 amps. ![]() ![]() ![]() ![]() ![]()
__________________ This used to be a Funhouse, but now its full of Evil Clowns Last edited by gunbir : 15th September 2006 at 18:46. | |
| | #163 (permalink) | |
like mentioned below.... 1) adire audio -> Brahma 12D4 http://www.adireaudio.com/Mobile/BrahmaSeries.htm 2) adire audio ->Tumult 12D4 http://www.adireaudio.com/Mobile/TumultSeries.htm 3) RE -> XXX 12 dvc version 4ohms http://www.reaudio.com/html/xxx_ts.htm 4) RE -> SX 12 dvc version 4ohms http://www.reaudio.com/html/sx_ts.htm 5) RE -> XXX 18 dvc version 2 ohms http://www.reaudio.com/html/xxx_ts.htm 6) ID -> IDMAX dvc version 4ohms http://www.imagedynamicsusa.com/prod...idmax&type=sub all of them are high xmax sub starting from..just 26.5mm of IDMAX to the max of 33 mm of the mighty Tumult..... all the above subs are very good subs which can beat SQ when compared to any other brand or model of subs...... and these are for real LOW_BASS not every body can handle them.... Last edited by low_bass_makker : 15th September 2006 at 18:53. | |
| | #164 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water. | |
| | #165 (permalink) | |
Every now and then I meet some dude who would have spent his daddy's hard earned money on ICEing a ride. The end result is such a disgrace because there is no way anyone can sit and enjoy music inside the cabin...forgetabouttheoutside!!!!! P.S : This thread is turning into a KB ka dB - II ![]()
__________________ No fate but what we make! Last edited by s0uljah : 15th September 2006 at 19:45. Reason: tags | |
| Thread Tools | |
Similar Threads | ||||
| Lateral Movement - Skoda Octavia to Honda Civic? EDIT : Bought Civic! | Jay5150 | Sedans | 44 | 19th August 2009 07:07 |
| Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) | drkunaldas | Sedans | 3 | 16th March 2009 01:27 |
| TV subwoofer transplant to car audio? | Glass | Ask the Gurus | 27 | 3rd June 2008 14:39 |
| Audio enhancements needed for Safari Dicor. | Dragonov | Ask the Gurus | 14 | 7th October 2006 15:41 |
| lightning audio beast subwoofer | FORDLOVER | Ask the Gurus | 36 | 7th September 2006 17:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
