Thread Tools
Old 27th August 2006, 13:10   #91 (permalink)
st7677, I had a similar thread runnign sometime ago...
Why dont you consider the option of 2 * JBL GT4 - 12" SVC in a calculated sealed enclosure ?
Similar to what amit_sound has in his accent... though he has been adventurous and used to 15"ers !!
If your going with JBL and budget permits it, go for one of their monoblocks, that was my dream,
but righ tnow im going to have to make do with the amp I have. Otherwise there's a few amps
mentioned in th elink I provided above
__________________
No fate but what we make!
Old 27th August 2006, 14:17   #92 (permalink)
ST7677's Avatar
Thanks S0uljah,
But I am on a tight budget and from various thread I figured out that Pioneer D510 is more value for Money than JBL 300.1CS.
Initially due to space constraint I was only thinking of 1 driver, but as this amp can drive 2 subs, I am thinking of may be 2 pio 12" subs or a single JBL 15".
I do not think Pio has a 15" sub and JBL does not have DVCs in this range?
I need sub amp & subs within 15-20k.
ST7677 is offline   Reply With Quote
Old 27th August 2006, 16:58   #93 (permalink)
If you're really interested in making your subs musical and not just thump, then try Hertz E 300 (SVC) or 300D (DVC) Subwoofers. They sounded far better than Pio to me. I'd recommend you give it a look before you finalise. Even E380D (15 incher) is a marvellous and very Musical Sub. And it doesn't cost gold.
Old 27th August 2006, 18:34   #94 (permalink)
ST7677's Avatar
How much do these cost?
Old 27th August 2006, 18:55   #95 (permalink)
Unsure regarding price.
Since your budgeting and opting out of JBL for this reason and going with pioneer, I think the Hertz might stretch your budget as it costs a little more than JBL.
Alternatively, invest in a good amp which can support 2 subs and start with one subbie for now. and add the second one when the time is right.
I had the 306svc in our lancer, it isnt that great.. but definately bang for buck!
__________________
Old 27th August 2006, 23:00   #96 (permalink)
I think it's somewhere around 7-8k. (yes, I'm thinking).
You can contact your dealer for the exact prices or PM Gunbir.
But as Souljah said, dont go for a lower brand due to budget. Get the best you can afford right now. Go with a one Sub setup for now. Or leave the Sub totally and get a great amp, components and Cables for now. Gather some more moolah and upgrade gradually. You'll be more happy with quality stuff in your car rather than quantity.
Old 31st August 2006, 15:45   #97 (permalink)
ST7677's Avatar
Ok thanks to you guyz, I have once again started thinking of increasing my ICE outley...
At least now I am thinking of going for Hertz Sub
And may be Audison / Alpine amp for compos...
But still lots of questions in my mind...
Our dear old man (Navin), kept saying that it's the speaker sensitivity which matters and I could not interpret it till today when I realized that...
A speaker with a sensitivity rating that's 3 dB higher than another speaker's only needs half as much power to deliver the same amount of sound!
i.e. output of following 3 speaker will be same!!!
85DB speaker @ 100W
88DB speaker @ 50W and
91DB speaker @25W
Q1. Is it just a theoretical equation or does it really holds good (does it really mean that 1 88DB speaker at 50 W = 2 85DB speakers at 50W or = 1 85 db speaker at 100W in reality?
Q2. Does sensitivity hold good only at low wattages or is it good enough for entire wattage range of the speaker (I mean if sensitivity is measured at 1 W then speakers may be tuned to be more sensitive in that region)
Q3. Besides Sensitivity and RMS, what are other important things to SEE in the speaker specs...
Of course the other thing our old man say is listen with your ears and then decide, so would I...
Old 31st August 2006, 16:46   #98 (permalink)
85DB speaker @ 100W
91DB speaker @25W
ya this is true till the stuff compared is rated at the same rating.....
like some rate it at 1 watt / 1 meter
some at 1 watt / .5 meter
some at 2.83 volt / 1meter
this can only be true if one compare the spec with the volt/meter same....
there can be speaker louder with 88 db sentivity written in the specs if compared to a 91 db speaker......
So from my side leave senstivity to a side while deciding a speaker....but make sure that all the speaker should be of same make so that u can easily compare the specs....
all the other specs will confuse a lay man ..... dont go comparing them do what navin ji has said "listen to the speaker then decide" ........this is bottom line while deciding for a speakers for ur car.....and the budet......
Old 31st August 2006, 17:43   #99 (permalink)
Your choices seems to be improving day by day!
You have almost got a qualty setup coming your way! So, do the install soon and get it rolling.
Old 31st August 2006, 18:01   #100 (permalink)
Bass&Trouble's Avatar
85DB speaker @ 100W
91DB speaker @25W
Above statement is entirely true.
LBM very precisely pointed out that the standard for the sensitivity measurement should be the same before we get down to comparing them.
It hold good for any amount of watts (power input), but I suppose you mean 'low frequency or entire frequency range'. The measured sensitivity is usually in the operating band of the speaker to be measured. If not, the sensitivity is not a true picture. For example a tweeter's sensitivity measured across 20-20000 Hz would be unfair and yield a very low averaged value. This is of no use to a system designer. I refer to the frequency response graph when i have to very precisely study the sensitivity and response charachteristics. That is the best way.
Very briefly, this depends on the drive unit. For a sub, the T-S parameters like Fs, Vas, Qts etc are very important for enclosure considerations. For a tweeter, you'd like to have the frequency response curve, sensitivity etc. So varies based on the need. Wattage is important for everything so that you can accordingly select a suting amp.
Edit: I'm trying to remove the bold parts of my text but it shows up as normal text in the editor and bold in the thread. ???
__________________
Losers Commute. We Ride.
Old 31st August 2006, 20:14   #101 (permalink)
navin's Avatar
B&T shame on you. even a PC-Newbie like me managed. :-)
__________________
Scixelsyd Etinu
Old 1st September 2006, 19:38   #102 (permalink)
ST7677's Avatar
So how do we compare sensitivity in 1st & 3rd scenario i.e. (W/m vs V/m)
I know Hertz measures in V/m and probably due to this their sensitivity seems to be higher than others...
Old 2nd September 2006, 01:42   #103 (permalink)
SPL is one of the most misused and maligned driver parameters out there today. Because most know that SPL has something to do with the loudness of a driver, they think bigger is better. And in general, it is... But recently, some manufacturers have taken to using unusual steps to "rate" the SPL of a driver. These can range from using non-standard drive levels, to measuring at 0.5 meters, to using in-room calculations. And unless they tell you what they used, you're out of luck! Or are you... Actually, no! There is a way to actually CALCULATE the efficiency of a driver. That is, you can run some simple equations, and come up with measure of just how efficient a driver is at converting electrical power to acoustic power. And from that, you can easily get to SPL. So now, you can actually "level the playing field" by removing any bias from the manufacturer's numbers...To start with, we'll need some of the basic Thiele-Small (T/S) parameters. I assume you can at least get these. If not, then take EVERYTHING that manufacturer says with a HUGE block of salt! If they aren't going to give you the absolute basic parameters about your driver, well...
Anyway, what you'll need is: Qes, Vas, and Fs. Yes, with these three little parameters, you can calculate the effective efficiency, and subsequently the SPL, of a driver. Here's how you do it:
Efficiency = 9.64 * 10^(-10) * Fs^3 * Vas / Qes
where
10^(-10) is ten to the minus ten power (0.0000000001)
Fs is the resonant frequency of the driver, in Hz
Vas is the equivalent compliance of the driver, in liters
Qes is the Q of the electrical system of the driver
This will give you a number, usually called n0, or eta naught. And, it's usually expressed as a percent, so multiply by 100.
Now, n0 is a measure of the efficiency of power conversion of the driver. That is, it tells you what percent of input electrical power is converted to acoustic power. Thus, you can calculate the output acoustic power by multiplying the input power by n0.
Now, don't be scared of a number down below 1% (0.01)! Rather, this is VERY typical of most subwoofers. Yes, drivers are inefficient, but that's what we've got to work with... So, how do we calculate the SPL of a driver from n0? Use the following equation:
SPL = 112 + 10 * log(n0 )
Where
n0 is the efficiency calculated above
log is the base-10 logarithm
SPL Calculations 2
So, let's run an example. Say, our Shiva subwoofer driver. For starters, we have: Fs=21.6 Hz, Vas=136.6
liters, Qes=0.3996. So, the n0 would be:
n0 = 9.64*10^(-10) * Fs^3 * Vas / Qes
n0 = 9.64*10^(-10) * 21.6^3 * 136.6 / 0.3996
n0 = 0.0033 or 0.33%
Now, let's put that into SPL:
SPL = 112 + 10 * log(n00 )
SPL = 112 + 10 * log( 0.0033 )
SPL = 87.21 dB SPL @ 1W, 1m
That's the 1 Watt, 1 meter sensitivity of Shiva. Go ahead and run your own favorite driver, and see if the manufacturer's being straight-up with you!
the above is taken from adire audio web site.....this formula will help one to atlest compare the driver with there actual senstivity......
Old 2nd September 2006, 18:37   #104 (permalink)
Dan Wiggins is one superstar!
__________________
Old 4th September 2006, 01:56   #105 (permalink)
some thing more on the driver senstivity part let us shed some more light on this....
http://www.the12volt.com/installbay/...TID=73962&PN=1
some good detail on the senstivity calculation
http://www.mhsoft.nl/Reference.asp
here is a calculater to find the senstivity of the driver....
like take example of adireaudio bramha
fs-29
vas-22.7
qes -0.4
results comes out to 83.2 accurate as suggested by the manufacturer....
the famous xxx sub....
fs-27
vas-56.5
qes-0.44
results comes out to 85.8 as suggested by the manufacturer 85.9 hardly any differnce...
lets us take a popular pioneer 306c..
fs-32.9
vas-51.76
qes-.5
result comes to 88.2 as compared to manufacter 89 state still close...
one can do it to the woofer one person is going to buy...how much the manufacturer is cheating on him......
people please do it for ur speakers and do post the results.....
Thread Tools
Lateral Movement - Skoda Octavia to Honda Civic? EDIT : Bought Civic! Jay5150 Sedans 44 19th August 2009 07:07
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 3 16th March 2009 01:27
TV subwoofer transplant to car audio? Glass Ask the Gurus 27 3rd June 2008 14:39
Audio enhancements needed for Safari Dicor. Dragonov Ask the Gurus 14 7th October 2006 15:41
lightning audio beast subwoofer FORDLOVER Ask the Gurus 36 7th September 2006 17:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
