| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Ok guys, here I am back with a good week of hoilday or what ever you say. I just wanna start with one thing, I have taken a vdo of a install it can be my install or anyone other but dont ask me who`s install it is.I am gonna post some pics of that same vdo as it will be easy for all to see without downloading the vdo. I just wanna hear from the experts of this forum that is this normal voltage which are shown in the vdo. One more thing in the pic no one cannot tell which car it is , which make is the audio equipment , who is installer, who is the cutomer......blah blah so dont starting pointing fingers on me, but one thing I am gonna confirm is that the equipment used in this install is top of the line not the local alpine or such. so guys put ur expert advice is it normal to have such voltages in a car audio install. ![]() ![]() ![]() and the best one is the last one....lol ![]() Mods I posted on this thread because it is related to power segement of the car audio. If not ok u can shift to the appropiate thread. |
| | #2 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Phew... CBE!!
| WAH.... LBM's BAK!!... and looks like back with some BIG-BANG!! BUddy... surely this has to be yours... why the secrecy... cant wait for you to tell us all!1 Anyways... those voltage readings... are they during transients??.. or regular load.... seems low man... way low... you Batt surely is'nt getting charged!
__________________ A closed mouth gathers no Feet. |
| | #3 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
LBM, I don't need to see the video to hear the amps screaming for help! (Whatever the cause may be)
__________________ Operator! Give me the number for 911! | |
| | #4 (permalink) |
| Senior - BHPian | ok about the transient or regular here are the complete set of readings which i have got are as below , the whole vdo is 45 sec long and the song i played was in da club by our 50 cents any ways here are the reading u can get some idea from that... 11.4 12.0 10.3 11.7 11.4 9.5 11 10.5 12.3 10.1 12.3 11.6 9.7 12.2 11.9 11.1 12.2 11.5 12.2 9.7 11.4 11.7 10.4 10.1 9.3 12.3 ok this will give u a clear picture what the amps are going through.... ![]() still waiting for the other experts advice........... |
| | #5 (permalink) | |
| Quote:
Calling all "Other" experts!! (... Enter --- SAM)
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 20th July 2006 at 23:27. | |
| | #6 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
Ok so the voltage on those meters looks low. That means that a) the amps output has compressed. OR b) the battery is dumping much more current to compensate for the drop in voltage 1. Are those meters correct 2. RMS readings from an analog meter would make for a clearer picture 3. compressed output sounds louder just ask any radio station. I can see LBM reaching for his SPL meter :-) LOL.
__________________ Scixelsyd Etinu | |
| | #7 (permalink) |
| Distinguished - BHPian ![]() | Well, it's obviously an SPL driven car which is pretty much running at peak capacity or well over. These reading are quite similar to the erstwhile Palio Eyeballer. Obviously the seriously low end notes are probably getting all clipped here. On the Palio eyeballer, while running at higher SPLs, I used to hook up a 150A external power supply that was running at 14.4V to achieve what i wanted. Whatever you are seeing LBM, is normal for an abnormally run SPL system: Regular car electricals (Stock alternator, possibly stock battery) on a system that obviously needs more juice than it's getting.
__________________ Live the YetiLife® Last edited by Sam Kapasi : 21st July 2006 at 00:12. |
| | #8 (permalink) |
| Senior - BHPian | ok since two of u have given the real picture here. Yes it is a spl setup with nearly or less than power requriements as compared to my setup. So the question I was asking is that is this voltage drop should be there while installing the system or the installer should know that the power requirment of the audio system would be more than the car can deliver. Here I am not going indepth of amperage or some thing I am seen the final product of the install which is measured in volts and which are really low.... Navin ji the reading are in .1 to .2 volts differance only when check by a hand held multimeter. One more thing I wanna add here is that the setup was played flat no enhancments we there like bass boost. |
| | #10 (permalink) | |
| Senior - BHPian | Quote:
And where are our other guru log.........Please put some of ur experiance to it..... | |
| | #11 (permalink) |
| LBM...LIke Navin I am also confused here... what is the question here?... obviously YES the electricals are crazily overloaded... YES the installer should know the basics of computing these loads... and YES he should also know the solution.. else its like asking a BUTCHER about Brain Surgery!!!!!
__________________ A closed mouth gathers no Feet. Last edited by kb100 : 21st July 2006 at 12:01. |
| | #12 (permalink) | |
| | #13 (permalink) | |
| Quote:
Else what answer can anyone provide without seeing/ knowing all of the above? If its a knowledgable installer then maybe he has an argument for doing it the way it has been done... and maybe he has a method of getting it to behave when required to (add more external juice etc) .. look around for some external jacks.. ![]()
__________________ A closed mouth gathers no Feet. | |
| | #14 (permalink) |
| Senior - BHPian | All the stuff installed in this setup is brand new and again I wanna say it that it is best stuff avalable this include speaker, amps, woofers, power cable, speaker cable, rca, capacitor and all the rest of the stuff involved. any ways the total load is 2000 watts rms approx. And the alternater is a stock one. Sorry I missed out on the battery but the size would be atlest 70 AH. Yes the engine was running when the reading were taken. The voltmeter error was in the range of .1 to .2 volts ( as said earlier) I dont know about the installer argument ???? How can I know about his comments.. And there is no external jack connection there in the install, as it is not a demo car.......lol |
| | #15 (permalink) |
| LBM... 200 watts?? ... Its clear then that this is a SPL or a SQL set up.. no stock alternator in any car can take the load... If you say its top brand then the insaller must have been good too to be usingt those brands... Then I am sure he would have set it up taking botht the clients needs and the these limitations into count... In other words he would have set it up to ensure that the systems performs AT A CERTAIN VOLUME LEVEL.. at which point all the parameters will be in control.. Remember ... any set up can be driven into cliiping... Anyways... to me it does seem like this is the only explanation... maybe you can tell us the actual settings and the numbers...
| Thread Tools | |
Similar Threads | ||||
| Something wrong with my Dzire, I don't know what. | mentos | Technical Stuff | 8 | 24th June 2008 11:41 |
| Something wrong with brakes. | hellmet | Technical Stuff | 6 | 29th January 2008 14:47 |
| is something wrong here | whatcanthisbe | Technical Stuff | 12 | 24th July 2006 14:52 |
| Something is wrong | Surprise | Shifting gears | 13 | 13th July 2005 01:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
