| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | hi guys yesterday i went to sony world to check out sony amp and found that quality was nice but sound started to break away at very high volume( this thing is common to all system i guess). sound distorted at only upper level of volume range at rest sound was quite nice. amp used was rated 800w and can anybody give some tips to reduce distortion at high volumes. like using quality cable and better amps etc
__________________ "Holla ain't no stoppin' me Copywritten so, don't copy me" |
| | #3 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| ki haal aya overdose!!! Distortion could be for various reasons. 1. The amp is underpowered for the speakers. Simple rule is, more the powerful amp, more clearner is the sound at high volumes. Dont bother much about the RMS rating of the amp vs sub. The only thing to look is that, the frequency of the two should match. 2. Ofcourse, cables play a very vital role. Its like the back- bone of your ICE. Mods please help him with the link of thread, that explained about the wirings. 3. Battery , caps are optional things that count. Obviously, you would not required to change these unless you have a very high powered system. 4. Problems in woofers may occur if the box built is not according to the specifications (amp/wiring etc. all be perfect with the woofer) Hor dasso, punjab da ki haal aya??? |
| | #4 (permalink) |
| Distinguished - BHPian ![]() | It could also be due to wrong equalizer settings (which isn't very evident at low volume). I was trying to tune the ICS on our Innova yesterday and realised that while all songs sound good at half volume, it doesn't remain the smae when you pump it up. Every songs requires a diff setting for it to play perfectly, bcoz it also depends on the way the song was recorded. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 25th July 2006 at 12:13. |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
__________________ -__- Last edited by jkdas : 25th July 2006 at 12:20. | |
| | #6 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
distortion of the sort you heard can easily be eliminated by choosing the RIGHT components. You might also have noticed that the distorted sound felt louder than similar SPLs of undistorted sound. The reason being that the brain recognises distortion but since it cant tell why it assumes the sound to louder. Most common distorions you are hearing at the shop are due to the physical limits of the loudspeaker or a poor install. Bass reproduction is a significant factor. Bass consumes a lot of energy and one needs to move a lot of air to produce bass. If you want to reproduce music at loud levels without distortion you would need to invest in subwoofers and amplifiers.
__________________ Scixelsyd Etinu | |
| | #7 (permalink) |
| Senior - BHPian | Instead of getting too much into amperes, volts & the works, the basic thing u have to look out for is whether the speakers in ur car are capable of taking the load from your amp & whether the software in ur cd is recorded at right levels. check these things out with a pre-recorded audio cd not MP3. cheers
__________________ Goodbye Dada, you made us proud. |
| | #8 (permalink) | |
| Quote:
| | #9 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Like Navin has already mentioned most reasons for sound to 'break', there are a few points to note. The primary reason, especially in the case of Sony speakers, for the sound to distort could be the speakers themselves. I find them very incorrect and fatiguing even at low volumes. Secondly, I consider it a correct approach for car audio systems with a power amplifier to exhibit some amount of distortion when you approach the last 10% of the volume steps. Although this seems absurd, I'll explain why. By matching the gain at a lower level to an amplifier, it is possible to eliminate clipping distortion totally, and ensure that at even full volume, there is no clipped/ distorted output. Here, of course, we are assuming that the speaker is not creating any nonsense of it's own. However, I would ideally leave some room at the top to allow low recording level program material to be adequately amplified. So when the input signal for the amplfier is lower than the standard recording level, the slightly higher gain allows for the head unit to be able to supply a larger pre-amp out to the power amp, and achieve desired spl even with a low level recording.
__________________ Operator! Give me the number for 911! |
| | #10 (permalink) | |
| BHPian | Quote:
vadia bahi and punjab tarakki te hai hey i am an electronic engg (though undergraduate) and i am not a "lallu" for god sake please. i know a lot but juruji's and experience matter a lot. i know the basics all about class a b ab and d amps mosfets why they are now a day more used but i wanted to know that even after getting right components sometimes sound is not good as it should be. i've heard many systems which sound great on one music type but fail to impress on others. why so much problem and why all identical componets are supposed to be used?????? why.
__________________ "Holla ain't no stoppin' me Copywritten so, don't copy me" Last edited by overdose14 : 25th July 2006 at 16:36. | |
| | #11 (permalink) |
| B&T most HUs have an nominal ouput exceeding 2V. Most power amps have sensitivity in the order of 100mV-2V (depending on gain levels). I would set my amps to clip at about a 1.2-1.6V signal (70% of the gain). This allows for maximum control inside the cabin while ensuring that the HU does not have to deliver it's maximum output to clip the power amps. I hope what you said above means the same thing. :-) BTW my test signal for clipping is not 1kHz but 400hz. It is just hangover from my tape days (where MOL was often tested at 400Hz).
| | #12 (permalink) | |
| Quote:
1. identical components do not guarantee distortion free sound 2. Good components set up or installed poorly can also casue distortions 3. Many if not all systems tend to favour one genre of music over another. Some reproduce all music poorly but very very few reproduce all music well.
| | #13 (permalink) | |
__________________ Goodbye Dada, you made us proud. | |
| | #14 (permalink) | |
| BHPian | Quote:
thats what i was looking for. thanks a lot ![]()
__________________ "Holla ain't no stoppin' me Copywritten so, don't copy me" | |
| | #15 (permalink) | |
| Quote:
__________________ Operator! Give me the number for 911! | |
| Thread Tools | |
Similar Threads | ||||
| How does one calculate the inside volume of a car? | ess_a | Technical Stuff | 8 | 29th January 2008 14:05 |
| World's Top Vehicle Manufacturers - By Volume of 2006 | tanmay_bb | The International Automotive Scene | 15 | 18th January 2008 09:39 |
| Low volume high pitched squealing noise in Siena 1.6 | ece2k2 | Technical Stuff | 3 | 18th August 2007 21:53 |
| Are we too harsh on Tata? | salilpawar1 | The Indian Car Scene!! | 147 | 26th November 2006 18:33 |
| amp clips at high volume | panky12345 | Ask the Gurus | 45 | 14th August 2006 10:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
