Thread Tools
Old 30th July 2006, 15:27   #1 (permalink)
929RON's Avatar
Default Another Sub and amp combination , wiring doubt ?
One of my friends is fitting a pair of dual 4 Ohms Kicker L5s with a 2 Channel Audiobahn A8002T , the bridged power @ 4 Ohms is 800 RMS, now how should we wire this to get the final Impedance as 4 Ohms, as If we wire S1(C1=C2)||S2(C1=C2) the impedance is 4||4 = 2 Ohms, how do we achieve 4 Ohms, any Ideas ? Can the two subs be wired in series to other ?
Experts, If my calculations were wrong tell me what is right ?
929RON is offline   Reply With Quote
Old 30th July 2006, 16:10   #2 (permalink)
Sam Kapasi's Avatar
If it were a mono amp - What I would suggest is that you wire each coil in series with each other, thereby giving you 2 woofers of 8 ohms each. Together in parallel they will give you 4 ohms.
Otherwise, you can wire them in parallel so giving you 2 subs of 2 ohms each and you connect them to the amp, non-bridged. One sub on the left and one on the right. That is easier to do and should sound the same.
__________________
Live the YetiLife®
Old 30th July 2006, 19:01   #3 (permalink)
Bass&Trouble's Avatar
Wrong sub-amp combination. Get another sub, or get another amp. Right now, the only option you have is to drive just one coil of the sub with the amp.
The Audiobahn amp in concern is a Class AB mono amp and is not stable below 4 ohms. For the budget and the configuration, I think you would be better off using the Audiobahn A12005DN which is a Class D monoblock with 600W rms output at 2 ohms. See if you can get the amp changed.
__________________
Operator! Give me the number for 911!
Old 30th July 2006, 19:34   #4 (permalink)
929RON's Avatar
Can we do something like this ? each sub here is a single coil sub , so we can consider each coil to represent a sub in the below diagrams.
What will be the final Impedance for this setup ?
Old 30th July 2006, 19:45   #5 (permalink)
The diagram says 4 ohm at the amp, so each of those single coice coil subs is a 4ohm sub. Each of 2 pairs is paralleled to achieve 2 ohms and then serialled at the amp to get 4 ohms again. This is similar to 2 x 4ohm DVC subs in all impedance matters. And so, if you buy another one of those dual 4ohm subs,you can also achieve exactly this.
__________________
Old 30th July 2006, 19:49   #6 (permalink)
929RON's Avatar
Yeah we have it, it is not 1 L5, its a pair of L5s
Old 30th July 2006, 19:56   #7 (permalink)
I didn't notice the word 'pair' in your first post. I thought you were referring to the voice coils. Sorry!
No troubles, just hook it up the way it's shown in that diagram.
__________________
Old 31st July 2006, 15:12   #8 (permalink)
low_bass_makker's Avatar
Man ur forgetting ur pair what will happen if i go away for too long........
Old 31st July 2006, 16:22   #9 (permalink)
I shudder to think, thank you for the support, and please perish the thought of going away again.
__________________
Old 2nd August 2006, 02:04   #10 (permalink)
929RON's Avatar
Default Subwoofer wiring again
This is one of the setups we are trying for a Skoda RS , it was running on a RF T10001bd which is 1 Ohm Stable
Now plan is to fit a T20001bd which we just got down in the same car which is 1 Ohm stable again with 3 Audiobahn ALUM12N subs, they are 1000 RMS Dual 6 Ohm subs,
Now, how do we wire this ?
S1(C1||C2)||S2(C1||C2)||S3(C1||C2)
=> 3Ohms||3Ohms||3Ohms
Is it 1 Ohm or something else, Experts ???
Old 2nd August 2006, 03:36   #11 (permalink)
it will be 1 ohms and u can connect them like this...
but one thing u have to see that the output of both the amps are equal.....
And yaar why always make a new thread when u can continue in the older thread mods plz do the necssary changes....
Old 2nd August 2006, 11:23   #12 (permalink)
navin's Avatar
the only other option wold require strapping amplifiers this was discussed on this forum some time back. a seach might help.
If strapping can be done i'd suggest using these subs wired to 9 ohms.
http://www.cartel.fr/IMG/pdf/JackHam...ers-manual.pdf
or page 10 of this manual
http://www.kicker.com/06/tech-suppor...DAmpMANUAL.PDF
__________________
Scixelsyd Etinu
Old 2nd August 2006, 12:21   #13 (permalink)
Autophile's Avatar
It is 1 Ohms Exact !!!
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Old 2nd August 2006, 12:25   #14 (permalink)
929RON's Avatar
Thanks for all the replies, but , the installation will not have 2 amps, its just one RF T20001bd, so according to Autophile its exact 1 Ohm,
cool, then We will get it setup , this is going to be ONE LOUD Setup,
Old 2nd August 2006, 12:40   #15 (permalink)
ron the T20001bd is 2000 watts rms in 1 ohms so the amp will be under powered in ur case if u go for a single amp. In this way u will be getting the full juice out of the amp but the woofers can take more.....so think again when going for this setup.
OT which type of enclousre ur going to use......sealed , ported , band pass, or a single box with all the subs in it with no partitions
Thread Tools
Best combination of amps for 3 subs? somubj Ask the Gurus 21 13th November 2008 20:09
My MBQuart amplifier & Phoenix Gold wiring have arrived. blue2ki Sound Off and Show Off 13 24th July 2008 23:19
Speed & Gear combination for Chevrolet UVA arunnn Technical Stuff 6 10th December 2007 23:01
Is it the Wiring/ Amp / H.U nosfreak Ask the Gurus 9 27th July 2007 10:32
SMART forfun2 - A combination of two cars captainsokhi The International Automotive Scene 0 29th September 2006 15:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
