| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #346 (permalink) | |
| Senior - BHPian | Quote:
about the sub u dont need to worry a bit as there are many shallow subs avalable in the market.... like this one....http://www.illusionaudio.com/docs/electra.htm with which u can install them...without letting any space wastage in the boot.....and not to remove any luggage on a weeked trip also..... rest for ur present setup I would suggest go for a font componet only no need for real fill as it will be not required as much .......so the final product will be if u like would be... hu->6850 front -> only 6.5 component kit amp->4 channel (2 channel for the front and bridge the other two for the sub) sub -> shallow sub in the boot Last edited by low_bass_makker : 18th September 2006 at 23:34. | |
| | #348 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Quote:
a) the Illusion electra sub isnt really a shallow mount, unlike their other series, the electra sub has 4.5" mounting depth, which is about average for 10" subs. I just compared with two other regular models of other makes, one had a mounting depth of 4.8" while the other 5" b) Most shallow subs available in the market, still need large enclosures. Do your calculations, with the Hoffman Iron Law in mind, and you will see what I mean. You cant really use them in space saving applications just because they are shallow mount. For example, a 94dB sensitive 12" shallow mount subwoofer with Fs of 33Hz, .4 Qts and 3.92cuft Vas will need approx 2cuft sealed box to play with authority above 65Hz, and then too with poor low end response. I'm surprised you havent done the math...
__________________ Often imitated, never duplicated! Last edited by gunbir : 19th September 2006 at 03:36. | |
| | #349 (permalink) |
| They are shallow mounting subs which needs big box. In this case it really does not matter how deep is the subwoofer as it is just saving space inside the sub box.
__________________ Danes Don't Lie ! Last edited by Autophile : 19th September 2006 at 03:34. |
| | #350 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
Firstly, let me point out that if you're going by the specs for the subwoofer based on the Illusion Audio website, they are unfortunately wrong. They have different specs from those mentioned, and were mis-quoted on the site ever since it was re-done to include the Electra series. I have measured all the Illusion Audio drivers myself at the Peerless testing facility to ensure that they are fit for use in sealed applications. I also have the older specs as measured for all the drivers and my findings by measurement measure up to them within allowable production tolerances. With your experience with using Illusion, I was assuming you probably knew that the specs on the site are way off considering the way they sound. All Illusion Audio resellers have copies of the 'real' specs or access to the same, and on all occassions, they have been most happy using Illusion Audio subs in sealed applications, based on my recommendation. It's unfortunate that the website has such misleading information, and I can't blame any of you for being misled thus. Not concerned with Illusion Audio or any brand of subwoofers, I must mention that sometimes there is an unnecessary quest in audio buyers to buy subwoofer drivers with stupendously Low Fs values, and try to get them to run out of small sealed boxes. There are implications of the same. Not only sensitivity, which is still by and large forgivable if you can invest in more amplification bucks, but also in terms of linearity, impulse-response and the overall natural feel of the bass. Also, too much engineering is invested into getting the sub to play a part of the frequency spectrum that is nearly absent in most popular forms of music.
__________________ Operator! Give me the number for 911! Last edited by Bass&Trouble : 19th September 2006 at 22:31. | |
| | #351 (permalink) | |
![]() taken from pioneer shallow sub manual and the sub i was saying is.....http://www.illusionaudio.com/docs/luccent_subs.htm also shown on the mugen power thread Last edited by low_bass_makker : 19th September 2006 at 23:07. | |
| | #352 (permalink) |
| Newbie Join Date: Aug 2006 Location: BANGALORE
| Hi Folks I m from bangalore and pretty new to this form , round a month back I had put a query regarding audio setup in my swift, thanks to some of the suggestions and after going thru a lot of threads, I had selected the setup which was suggested by many pio 9680 gto 607c jbl sub sony 4 channel amp got the setup done from sound factor in bangalore for 30k . The sound is great but the problem is the back seat where the thump from sub becomes too much compared to the comps in front so the rear passengers dont hear anything much besides the boom from the sub I thought of putting speakers in the rear door but my budget is around 2 k since the jbl gto637 at 4K is out of budget, can u guys suggest any alternative say in pioneer also any place in bangalore where I can get authorised pio stuff |
| | #353 (permalink) |
| Senior - BHPian | u can check the pioneer speakers but I would recommed not buy them ...instead u can reduce the bump of the sub so that the rear people in the car could match the sound of the front and the rear....also in which position is the sub firing ...is it facing back or upwards..... |
| | #355 (permalink) |
| Hi Guys ... thanks for ur replies ... LBM - The sub ( dont know the model but peak power is 1000 w ) is facing upwards ... Rsjaurr- Though as of now i dont know how to reduce the gain, but will search thru the threads and try figuring it out.. Since none of you suggested putting pio speakers, I am thinking of putting speaker plan on hold for now Guys could you tell me, how much CS series speaker will cost or rather how much cheaper it will be compared to the GTO's .. I cudnt find CS series info on JBL site |
| | #356 (permalink) | |
The thing rsj is saying is bringing down the gain....that can be done from the HU itself from the sub menu in the audio section.... | |
| | #357 (permalink) |
| BHPian Join Date: Aug 2006 Location: Mumbai
| Kaustuv, you could try tuning your amp such that the rear seat people are not overpowered by the Bass. I had a similar problem (bass was too boomy) and after doing tuning.. managed to get the sound I wanted. You could refer to the following links for help on tuning: http://www.team-bhp.com/forum/car-entertainment/13141-tuning-your-amps.html http://www.team-bhp.com/forum/car-entertainment/16593-amplifier-tuning.html |
| Thread Tools | |
Similar Threads | ||||
| Suggestion with my Old Audio System into new car | mezereo | Ask the Gurus | 4 | 29th March 2008 02:49 |
| BlueTooth Car Audio System + Security System | venky6009 | Ask the Gurus | 1 | 2nd November 2007 05:45 |
| Best Car Audio System under 16k | nishantv2003 | Ask the Gurus | 38 | 12th July 2006 22:38 |
| Suggestions for Car audio system | psynaps3 | Ask the Gurus | 8 | 29th March 2006 10:28 |
| suggestion for octi - car audio | ibe | Ask the Gurus | 6 | 18th July 2005 11:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
