Thread Tools
Old 7th August 2006, 19:56   #1 (permalink)
Unhappy no sound from speakers
hi
just recently i bought a pioneer deh 3850 and jbl mono block + subwoofer. so far i wired up the HU to the car exactly as the manual says except i didnt wire up the HU to the monoblock or sub. the HU powers on and i can select tracks on CD's, choose radio stations and change settings...
the only problem is i don't hear sound from all 4 of the speakers. is this because i havnt wired up the monoblock or something more serious???
p.s. i double checked all wires were correct by following each wire to its speaker and made sure it was either +ve and -ve. i had to splice the wires to connect them and secured them with duct tape.
any advice or suggestions wil b greatly appreciated, else il have to pay $150 to shop to wire it up T.T
bunnarith is offline   Reply With Quote
Old 7th August 2006, 20:13   #2 (permalink)
Sam Kapasi's Avatar
Hello Bunnarith..
$150 to wire that up? Man Australia is expensive!
OK this is how I understand it
You are wiring up 4 speakers to your HU and then you are gonna add on the monoblock and sub.
If your HU is powered on. AND you have connected the speakers to the correct wires, you should have sound. It's as simple as that. It has nothing to do with the monoblock amp.
If you don't:
well
1) Either you have a faulty HU
2) You have blown up the power chip inside the HU due to a wrong connection or the speaker wires touching each other by mistake.
In either case, you would need to take back your HU.
__________________
Live the YetiLife®
Old 7th August 2006, 20:23   #3 (permalink)
Bass&Trouble's Avatar
Originally Posted by bunnarith
hi
Just run this small test.
Disconnect the speaker wires from the head unit. Now identify the wires that are going to the speakers, not the ones coming from the head unit's amplifier.
Connect the -ve of the cell to the -ve wire of one of the speakers. Hold this firmly in place with one hand, and momentarily touch the wire going to the +ve of the speaker to the +ve of the battery. You should here a click from the speaker in concern everytime you make contact. Repeat this for all the speakers. This will ensure your speakers are ok, and the wiring is not open somewhere, or shorting. In both cases, you wouldnt hear clicks. If you dont get a click on one of the speakers, check the speaker and the wiring running to the speaker, as the wire leading to it could be shorting somewhere. If it were open, the HU would not have a problem playing the other 3 connected channels.
If this worked fine, make sure that no loose wires behind the HU, any of the pre-outs, turn-on lead are touching some metal part of the HU or car, or each other. They should be well insulated. To test this, power up the HU with all wires intact, and without pushing it into the dash manually run a check. If all is well, proceed to push the HU into the dash.
If your HU is still quiet, check to see if you have 'Mute' on.
Beyond this, you will turn poorer by atleast $150.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 7th August 2006, 22:41   #4 (permalink)
low_bass_makker's Avatar
Originally Posted by Bass&Trouble
Just run this small test.......Beyond this, you will turn poorer by atleast $150.
I think u must be poorer by 150 till now....
Old 8th August 2006, 16:54   #5 (permalink)
thnx for the replies guys,
ill test it out right now but i am a bit unsure what 'cell' refers to in the sentence " Connect the -ve of the cell to the -ve wire of one of the speakers." so i will assume it is the cars metal body, plz correct me if i'm wrong.
Old 8th August 2006, 17:01   #6 (permalink)
jkdas's Avatar
think a 1.5V battery cant be a 12V to your speaker! (AA battery)
__________________
-__-
Old 8th August 2006, 17:01   #7 (permalink)
Hi, the "cell" here refers to a dry cell battery
jvedanand is offline   Reply With Quote
Old 8th August 2006, 17:35   #8 (permalink)
Oops sorry, I forgot to mention that, any AA, AAA pencil cell would be fine. don't use the car battery, that could be too much. Thats why I also said, touch momentarily. You could also use a DMM (LBM has one that is widely advertised), in continuity mode.
__________________
Old 8th August 2006, 17:53   #9 (permalink)
ohhh ok. well i've tested each speaker with a AA battery and each speaker i tested made a thump sound so i guess d speakers r ok. n so i re-wired the HU n made sure each connection was insulated n each exposed wire was insulated.. lol n i checked the mute. still no sound
the only prob is the shop guy warned me i wont b able to return the HU if i spliced the wires... but if i can prove the HU was already broken maybe i can still swap the HU with a working 1. wot do u guys think?
Old 8th August 2006, 22:55   #10 (permalink)
navin's Avatar
your power amp chip might be dead.do you have a spare car audio amp lying around? if you do use the preamp out and the spare amp and check.
__________________
Scixelsyd Etinu
Old 8th August 2006, 23:55   #11 (permalink)
or if u dont have a amp u can connect a head phone to the preout and check u can also try this there must be a line in your tv or audio system u can connect it there also but for doing this u will need long wires to power up the HU
If you get any sound then ur hu amp is gone but the hu is working...... and u will have to change ur hu....
Old 9th August 2006, 00:03   #12 (permalink)
Sam Kapasi's Avatar
I am telling you this from experience. The power amp IC on your HU is blown. It happens while installing, if speaker wires accidentally touch each other.
__________________
Live the YetiLife®
Old 9th August 2006, 19:06   #13 (permalink)
is d power amp IC easily replaced, can d head unit b repaired at a cheap price?
Old 9th August 2006, 22:43   #14 (permalink)
I think u to take to the shop from where u had purchases it ....u said in the earlier post that if there is a problem he will change it.....
the power ic is not easly avalable u would be requiring a old karab HU of same model or series for this purpose ....... even if u get a old HU u change the ic still it did not work then what to do....
add amp simple.........
Old 9th August 2006, 22:55   #15 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Adding an amplifier will solve your problem dude. But check by connecting an amp to make sure though before you buy.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Thread Tools
Hissing sound from speakers when not playing music. Please help. vishnuvijay Ask the Gurus 48 13th June 2008 14:51
Pioneer with JBL Speakers.. Crackling sound glidealong Ask the Gurus 6 14th February 2008 14:39
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
ICE Troubleshooting - No sound from speakers. uttamc Ask the Gurus 17 19th June 2007 15:22
Whining sound from speakers at low volumes... frankmehta Ask the Gurus 16 17th May 2006 16:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
