| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2006 Location: BOM / MIA
| Hi People, Following is the audio configuration that I was initially looking at: HU : Pioneer6850 Front Components: 6 1/2 inch JBL GTO607 Rear Coaxials: 6x9 JBL GTO937 Amplifier : Pioneer GM-6200F Subwoofer: Pioneer TS-W306C/DVC Wiring Kit : Interlink Jr. by Monster See, initially , my budget was 30K from 20K (I guess I got a little carried away reading the various threads on ICE). I primarily listen to both, hard rock and soft rock, along with some instrumental music. All I am lookng for is something with GOOD sound clarity and VFM. I am almost certain that my current set-up exceeds a little over 30K. I need some advice from the audio guru's. Would it be advisable to go for JBL's GTO series and lose the amp+sub? OR Go for JBL's CS series and keep the amp. minus the sub? OR Simply stick with the CS series minus the amp+sub? The GTO combo itself (front comps + rear coax) would cost me somewhere around 9-10K! I think that at this time, budgetwise, I want to stay in the vicinity of 20K. I might be willing to stretch to 25K, if absolutely needed. I look forward to some comments and suggestions. P.S. I wish to have JBL as my choice of speakers.
__________________ HONK IF... you love silence. |
| | #2 (permalink) |
| Senior - BHPian | HU : Pioneer6850 : 9k Front Components: 6 1/2 inch JBL GTO607 : 6.5k Rear Coaxials: 6x9 JBL GTO937: 4k Amplifier : Pioneer GM-6200F :7k Subwoofer: Pioneer TS-W306C/DVC :3.5k? Wiring Kit : Interlink Jr. by Monster : 2k? well?
__________________ -__- |
| | #4 (permalink) | |
| [/quote] Quote:
__________________ HONK IF... you love silence. | |
| | #6 (permalink) |
| LBM, I could go for JBL's CS series which I think, would be almost 5K cheaper than the GTO series, and still get to keep the amplifier minus the sub OR do you recommend that I stick with the GTO's and have the amplifier and sub fitted later.
| | #8 (permalink) |
| Senior - BHPian | ok so its 32k( was lazy to add up last night ).Yes; set by set setup would be nice. It took me 6months for me. Get the Pio HU + compo + 6x9 now. CS series should be the old GTO series ( me right Sam?) and hence VFM. A 6x9 would serve as a small sub for now. If you can you can get a sony 4 channel amp at 4k now if you have saved money from getting CS series or maybe the Pio amp. Could you post the specs of 6200 as I havent heard much abt it. which car by the way? And are you buying thsi 4 channel to run the compos + sub?
| | #9 (permalink) |
| CS series should be the old GTO series ( me right Sam?) and hence VFM. So, what do you suggest? Should I go for their GTO series which supposedly, is more superior, or go for their CS series which is a VFM. A 6x9 would serve as a small sub for now. If you can you can get a sony 4 channel amp at 4k now if you have saved money from getting CS series or maybe the Pio amp. I'm sorry, but what Sony 4-ch amplifier comes for 4K? If I were to have an amplifier fitted, would Sony or Pioneer be the preferred one? Could you post the specs of 6200 as I havent heard much abt it. 4-Channel Power Amplifier with 600 Watts Max. Power
General Number of Channels: 4 Width: 11.8 in Bridging: Yes RMS Power Output: 60 W/channel THD at Rated RMS Power (Unbridged): 0.01 % Peak Power Output: 600 W Weight: 13 lbs Warranty Information: 1 Year Limited Warranty Height: 2.3 in Depth: 13.2 in Max Frequency Response: 50 kHz Min Frequency Response: 10 Hz Signal To Noise Ratio: 80 dBA which car by the way? Indica XETA And are you buying thsi 4 channel to run the compos + sub? I guess? My knowledge is pretty limited; however, what would you suggest?
__________________ HONK IF... you love silence. Last edited by luvjascha : 8th August 2006 at 07:56. |
| | #10 (permalink) |
| I'd like to have as much fitted within my budget, if possible. However, I wish not to compromise on quality, so if this means, having other items fitted at a later date, so be it! Sound clarity and VFM are my top 2 priorities.
| | #11 (permalink) |
| Senior - BHPian | Pio would be teh preferred one as its more powerful. Since you would be using compos( by the way try to get old GTO606Ce; as it cheaper now as 607 is out) and would liek to add a sub later,get a good 4 channel amp like the Pio 6200 or 6150. Best bet would be, buy a good and powerful 4 channel and sub later. Keep aside/save 15k for this to be on safe side. Get the rest for now. DONT cut teh extra wire cables as you may need them when you get the amp.
| | #12 (permalink) |
| Any idea on the price of the GTO606Ce? I understand that what I'm about to ask is off topic, but I didn't want to start a new thread, simply for one question that's been on my mind. Wouldn't a fairly powerful system put a ton of load on the car's battery? Is it the amps. put out by the speakers, that affect the battery load? Again, wouldn't climbing the ghats with both, the a/c and music, put a tremendous load on the battery? Would appreciate if some fellow BHP'ian would throw some tips on the same.
| | #13 (permalink) |
| BHPian | I dont think you have to worry about the battery as yet. There are guys with several 15" subs, amps (including 1000W monoblocks etc) whose cars are still functioning OK. Only once you get into the serious stuff would you need to think about replacing the battery. My cost cutting suggestion for you is for the moment dont put those 6x9 coaxials in the rear. Front compos and a sub will cover the entire freqency range, and unless you really want to entertain your backseat passengers i feel that sound should be best at the front end of the car. |
| | #14 (permalink) |
| It'll just be me ! I very seldom drive with pax in the rear seat. So, I have 2 suggestions: 1. Eliminate the amp+sub, keeping the front comps. and rear coaxials. 2. Eliminate the amp +rear coaxials, keeping the front comps. and sub.
| Thread Tools | |
Similar Threads | ||||
| Confused !!..Cool Sounding Car Audio on Budget advice needed | quake6 | Ask the Gurus | 77 | 18th July 2006 12:30 |
| Audio Config For My Bro's New Swift.... | freakrz | Ask the Gurus | 36 | 10th March 2006 22:25 |
| Needed: Best Audio config for a tata Indica | msk_kapoor | Ask the Gurus | 52 | 24th February 2006 09:44 |
| Proposed Audio Config.. | allajunaki | Ask the Gurus | 38 | 1st September 2005 00:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
