Thread Tools
Old 9th August 2006, 14:19   #1 (permalink)
whatcanthisbe's Avatar
Default Suggestions
k the car is a lancer music i listen to is DMB incubus matchbox 20 creed etc etc and occasional rap(snoop dr dre) punjabi
I am looking for no chan chan or no boom boom i wand sound clarity and crispness with each note be audible.
I saw a few systems this weekend and kind of narrowed down to
pio 4850 HU (6000 without and 8000 (i cant remember for sure) with B&W)
Jbl 3 way GTO9XX for the rear (4300( with B&W))
I still dont know what to get for the front.
The guy said prices were inclusive of installations but i have read here that you guys pay like 1.5 - 2 k for cables ???? Confused???
do i need a sub and an amp ? i dont think but tell me do i ?
I also have an older model of this DSP closer to this one already and i want to incorporate into the car. i am looking to get this done this sat.
pls advise...
whatcanthisbe is offline   Reply With Quote
Old 9th August 2006, 14:57   #2 (permalink)
iraghava's Avatar
WTCB - I think first of all you should also decide on a budget so considering that a good setup could be advised to you.
Secondly, there has been a new setup advice from the Guru's under which you should get a good set of components for the front and no speakers for the rear. Save the money from the rear speakers and invest it in a good 4-ch amp and pair it to a nice 12" subwoofer in an enclosure & drive the front components off the another channel. This should give you pretty good SQ. So it should cost around:
HU Pioneer: 6-9k
Front Comps: 6-8k
Pio/JBL 4-ch Amp: 7-12k
12" Subwoofer: 4-8k
Install, Box & wires: 2-3k
You would also need better quality cables which we usually budget for seperately. These will cost you around 1-1.5k+box+installation, hence budget of about 3k.
__________________
Power corrupts. Absolute power is kind of neat.
Old 9th August 2006, 15:04   #3 (permalink)
HU Pioneer: 6-9k
Front Comps: 6-8k
12" Subwoofer: 4-8k
From what i know of subs they just produce the boom boom .. rite ... i dont really want that boom boom .. correct me if i am wrong
i want sound clarity and each note to be distinct.... say 20-30 is the budget .. and with the DSP linked above i can set the listening position to driver only and all 4 speakers will be adjusted to my position in the car andthe sound stage set accordingly...
pls let me know...
again i dont want a box as trunk space is critical for me.
Old 9th August 2006, 16:25   #4 (permalink)
low_bass_makker's Avatar
are bhai the dsp linked above are the only models can u clearly specifiy the model is it 7600 or 9200 this will help a lot.....
if it is 7600 the listing position selector is a crap and does not work properly....any ways if u want to listen like this u will have to get a good hu with Time Aligment feature.....
as suggested by iraghava he has suggested u a good setup ....prices can be increased or decreased as you suggest us a model you have sellected...
woofer does not mean boom boom....it will add over depth in the sound....without it I dont think sound is complete.......but again i would like to add it all depends on listing styles.....
low_bass_makker is online now   Reply With Quote
Old 9th August 2006, 16:56   #5 (permalink)
cant remember the exact model it's itting at home .. i think the 9200
20 -30k
Old 9th August 2006, 16:57   #6 (permalink)
Time Aligment
what is that
Old 9th August 2006, 17:08   #7 (permalink)
iraghava's Avatar
Yes but as LBM pointed out subs are necessary. Since you want every note to be clear you need one speaker dedicated to producing the lows in the music & the sub is for that specific purpose. A good sub does not necessarily produce only the boom-boom, it is an integral part of every good sound system.
pls let me know...
DSP's have not really been recommended by our Guru's as LBM pointed out so you might be better off with a Time Alignment enabled HU. But I will let one of the Guru's give you the final advice on this one.
I agree with LBM completely.
__________________
Old 9th August 2006, 17:12   #8 (permalink)
k i am completely confused again now what system do i get 20-30 k at the most
no box
Old 9th August 2006, 23:20   #9 (permalink)
man u can use the eq but u must be knowing how to adjust it ...
secondly go for 4850 but a nice set of componets for the front.....if u dont want to spoil ur boot u can by pioneer 306f sub and install in the rear deck....and buy a 4 ch amp use two channel for the front speakers and other two bridge them and connect the sub to it......I think ur done and all this can be done in 30 k ......
Old 10th August 2006, 02:45   #10 (permalink)
theEnd's Avatar
Sell the DSP and get better speakers or a better amp
theEnd is offline   Reply With Quote
Old 10th August 2006, 16:12   #11 (permalink)
its the 9600
cant sell it as it is old ... no warranty
Old 10th August 2006, 16:34   #12 (permalink)
iraghava's Avatar
WCTB - The best option is to get front comps & a boxed woofer/bass tube. You can put it in the boot & if you need to take it out you can easily remove it. The sound quality without a woofer/tube would be missing the lows and the sound would be very shrill/bright!
__________________
Old 10th August 2006, 16:37   #13 (permalink)
hmm how abt jbl comps up front infinity 6*9's in the back mated with a 4850... witha say 10 inch sub and an amp ?
now tell me what amp and what sub ...
Old 10th August 2006, 16:56   #14 (permalink)
iraghava's Avatar
That's a good setup but what budget are you looking at??
Sub could be Pioneer 306 or JBL GT 12. Not sure if you have too many options for 10"
Amp again depending on your budget either you can get a decent 2-ch amp or a monobloc to drive the sub.
Do you want the speakers to be driven off an amp too??
__________________
Old 10th August 2006, 17:03   #15 (permalink)
rsjaurr's Avatar
Why not JBL 6x9" at back as well or Infinty ref compo at front instaed???
Cheapest sub+amp option will be pio 306 subw powerd by sony 502 2-ch amplifier.
But i will recommend u 504,use its 2 ch for front compo and rear 2 for sub in bridged mode.
This should be decent system,but WCTB,this all is out of ur budget of 15-20k..
rsjaurr is offline   Reply With Quote
Thread Tools
Suggestions doniv Ask the Gurus 11 7th August 2007 22:12
suggestions please impact Modifications & Accessories 4 15th September 2006 18:00
Suggestions please cooldude1988765 Hatchbacks 19 3rd April 2006 10:08
Need Suggestions Technocrat Hatchbacks 15 23rd May 2005 02:29
need suggestions normally_crazy Modifications & Accessories 6 30th June 2004 03:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
