Thread Tools
Old 15th August 2006, 14:13   #1 (permalink)
Default If my front compos were 100 rms each, what rms amp do I need?
The compos are 100 rms @ 4 ohms...what kind of an amp should I be looking at?
wannabelean is offline   Reply With Quote
Old 15th August 2006, 14:26   #2 (permalink)
jkdas's Avatar
which compos are those. Can you get the one KB got?
__________________
-__-
Old 15th August 2006, 14:48   #3 (permalink)
which one is that? the polk momos is what I'm thinking of getting. Had JBL on my mind but when I have people coming down from the US I changed my mind.
Old 15th August 2006, 15:04   #4 (permalink)
viper's Avatar
Am assuming that the max power is 100 WRMS. If it is a high end speaker set I would recommend a minimum amplification of 50-75 WRMS for the same. IF you like blaring your music then you can go higher up depending on your budget.
Viper
viper is offline   Reply With Quote
Old 15th August 2006, 15:09   #5 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Any decent 4 channel amp with 75W RMS per channel will be fine I suppose.
Why 4 channel? You can bridge 2channels if you're not happy with 75W. And in the process, you can burn some coils too.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 15th August 2006, 15:13   #6 (permalink)
low_bass_makker's Avatar
I would add some thing here first which model no are those polk momo`s
then according to the model we can decide which amp will be best suited for the job
also add some info what type of music do u listen to and what is ur budget.....
I think no one could suggest an amp only by the RMS value of a speaker......
low_bass_makker is online now   Reply With Quote
Old 15th August 2006, 20:39   #7 (permalink)
Bass&Trouble's Avatar
Genuine 100 rms? Is it a 2-way/3-way?
Most 6" comps can handle 100 W rms only if they are not fed sub-bass.
The amplifier choice will not depend on the speaker's power handling alone. In fact, the choice of the front speaker based on power handling itself would be incorrect unless the rest of the setup matches up. What else do you plan in the car? What rear speakers, what sub? Based on all these factors, it will be easier to choose the amp for the fronts, so that the end result is a balanced sound.
__________________
Operator! Give me the number for 911!
Old 15th August 2006, 21:00   #8 (permalink)
jkdas's Avatar
which car? 100W nominal? and the HU is? YOu would need lot of damping to I guess. @75W x4; look at Pio 944 or JBL GTO75.4. Pio 944 can deliver 250W x 2 in bridged mode
(OT! thsi is what Karthik's Audiobahn 6x9 are being fed now!, would it hurt the Audiobahns? 250W X2)
__________________
-__-
Old 15th August 2006, 21:12   #9 (permalink)
929RON's Avatar
Default 100 RMS components
Yeah there can be 100 RMS component Speakers, Audiobahn comes with a component speaker model ABC60003N which is a 3 Way 320 RMS component.
Ideally if you have a 100 RMS component Speaker....... (which you dont actually need, cos our car cabins are so small that due to so many reflections any above 100 RMS on components on the front door may not sound that crisp and will become too loud, if tuned to the max potential)
......you need a 150 RMS amp, I will tell you why, any amp will perform very well in terms of clarity in about 40 to 50 % Gain, so take the juice up to about 40 % and tune the HPF, and you can have much better sounding system than an amp which is 75 RMS powering the 100 RMS speakers.
Just see to that someone who knows his work tunes the speakers and does not throw in too much power into the speakers, which can blow and before blowing will scream a lot too.
929RON is offline   Reply With Quote
Old 15th August 2006, 21:12   #10 (permalink)
rsjaurr's Avatar
If money is not problem for u,do consider JL audio's slash series or at least 'E' series.
rsjaurr is offline   Reply With Quote
Old 15th August 2006, 21:19   #11 (permalink)
929RON's Avatar
YEPP !! JL ROCKS !!!
I personally feel they sound better than Focal K2 Power Series components.
Old 15th August 2006, 21:22   #12 (permalink)
rsjaurr's Avatar
Is it so????
So u mean if amplifier is rated to produce 150wrms @4ohms,it will produce just half of the rated 150 a in given set-up at 50% gain???
So to extract full juice of amp,do we need to keep the gain at full??
Our experts will know better but i would think otherwise.
Old 15th August 2006, 21:47   #13 (permalink)
That Audiobahn rating is for the whole set, not each individual speaker, or one side. So it means that one each of the 6" woofer + the 4" midrange + the 1" tweeter can together handle 160W rms, bot 320 as you seem to be believing.
I disagree that a speaker's power handling and the reflections in the car have much to do with each other. Even if the speaker is low powered and your car's acoustics are a nightmare, it stil is a bad seat to be in.
I don't agree on that bit about use a 150 W amp and keep the gains half. Gains should always match up with your head unit, and if you are keeping it any higher/ lower than that, you are making up for some other deficiencies in the system. It would all depend on what the amp's performance characteristics are like, and by that I mean, what kind of peak power the amp can deliver. So a 100 W rms should suit it just fine if the amp can put out the extra power momentarily when there is a surge in the signal. That also sorts out the problem of 'throwing in too much power', and you're safe unless you run the amp into clipping which I assume one can safely hear.
__________________
Old 15th August 2006, 22:50   #14 (permalink)
Link to the amp - MMC6500 - http://www.polkaudio.com/caraudio/specs/mmc6500/
Head unit will be the Alpine 9857
The Sub will be a JBL one. I'm not sure if I should get the tube or bandpass one. I'll think about that later.
A stinger amp wiring kit.
The music I listen to usually is pop. 80s music is da best!
Old 16th August 2006, 01:28   #15 (permalink)
929RON's Avatar
Is it so????
Gain is not a Volume control, and most people who have been on this forum for some time will know that, I am suggesting this out of personal Experience, Different Amps differ in their power delivery etc,
Some of the powerful amps sound the best when only about 50 % of the potential is used, the SQ is optimum without even a hint of Degrade. This not every common person can understand, only Tuner's ears can differentiate,
This is what I compared, (well I don't say I have the best ears)
I had powered a pair of RF T312D4 1000 RMS subs with a Single T30001bd Amp, now , under any ciscumstance this amp produces way above 3000 RMS, Keeping the gain at about 40 % and tuning the Freq, gave very very crisp sound Quality and good amount of bass,
The same car had 1 RF T8004 4 Channel Amp powering 3 sets of RF T162s Components, the amp churns out anywhere above 800 RMS in total, so why did'nt the speakers Blow, cos the max power rating in total was just 300 RMS , because they were tuned optimum, barely 25 % of the gain was used, but it sounded marvellous, the effect was not the same when the speakers were hooked up with a P4004 4 channel amp.
Try it out, it works.
What B&T said " It would all depend on what the amp's performance characteristics are like " is absoultely correct.
Amps differ, what method I suggested may not work good for all amps, the level of gain will be different for different combinations of amps and speakers / subs.
Thread Tools
NHC owners with front compos...where/how do you have your tweeters installed? wannabelean Ask the Gurus 10 15th July 2008 15:43
RMS and Peak Power... maverickzCar Ask the Gurus 16 25th January 2008 17:27
M&M to invest Rs 100 cr for M-Hawk upgrade dadu The Indian Car Scene!! 6 18th January 2008 16:42
TheLoudest.com speakers - 350W RMS!!! gopz Product Discussions 16 13th July 2007 19:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
