Thread Tools
Old 30th March 2008, 15:48   #61 (permalink)
low_bass_makker's Avatar
The effort to put these rubber sheets will be more than buy noise skill at 150 persqft.
Old 30th March 2008, 16:56   #62 (permalink)
DerAlte's Avatar
Originally Posted by adityamunshi View Post
However one shop had a roll of thin neoprene, no smell, light weight, flexible and Rs110 per kg. It was perfect in all ways except that it wasnt self adhesive
Exactly the reasons why it will not work! Self-adhesive is the least of the worries, what you need is dense material which has enough weight per unit area to act as a damper. Yes of course you can apply it with rubber-adhesive, except it takes a LOT longer to complete the job. First get proper damping material.
If ready-made damping material is not available in Baroda, get it from Mumbai.
If you are worried about the cost, you can
a. minimize the area on which you need to stick it (treat large areas not interrupted by a bend, fold, or stiffener) or
b. use appropriate alternate materials, such as
* 'tar felt' (layers of paper and jute bonded with tar-based material; use for roof sealing; limited flexibility; contains mica filler to stabilize tar so that it doesn't melt and ooze out in hot weather)
* closed cell foam stuffed in areas which have a mechanical support (metal straps, another metal sheet) close by
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 30th March 2008, 17:30   #63 (permalink)
adityamunshi's Avatar
Hi deralte
Its not about the cost or getting proper damping here. The problem is that im selling this car off in 6 months max.
There's no point in wasting any amount of proper damping on it. There were atleast 20 different grades of rubber there, ill look for something else and I'll also try and look for the alternatives you suggested.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 30th March 2008, 18:24   #64 (permalink)
shrivz's Avatar
I couldnt find self adhesive sheets
However one shop had a roll of thin neoprene, no smell, light weight, flexible and Rs110 per kg. It was perfect in all ways except that it wasnt self adhesive.
Is it possible to stick it with a rubber based adhesive ? And if i do that what should i use to apple pressure until the adhesive cures ?
My friend, neoprene will NOT do the job!
as DerAlte has mentioned, you need something dense which will be heavy!
If you are selling the car soon, don't bother with damping it!
__________________
Technical skill is the master of complexity, while creativity is the master of simplicity...
shrivz is offline   Reply With Quote
Old 30th March 2008, 18:43   #65 (permalink)
I guess i'll look around a bit more for self adhesive butyl rubber sheets. If i cant find them i shall drop the damping all together, alteast for the time being.
EDIT : Gunbir mentioned something about using waterproofing materials as an alternative at the beginning of this thread. Can anybody explain further ?
(Here : http://www.team-bhp.com/forum/ask-gu...tml#post276899 (Alternative material for damping) )
__________________
Old 30th March 2008, 18:59   #66 (permalink)
shrivz's Avatar
Moreover, I've noticed that in many cases its things like the power window assembly which rattle rather than the door itself.
Ideally eliminate all these rattles first. One could use a filler like silicon rubber around the screws / bolts.
Only after getting rid of these rattles should you contemplate the need for damping.
Silicon rubber is used extensively for waterproofing applications, it doubles in the case of damping. Basically, you could look out for liquid sealants, asphalt based or rubber based.
Its going to be a really messy job working with liquid products!
__________________
Old 30th March 2008, 21:54   #67 (permalink)
DerAlte's Avatar
There's no point in wasting any amount of proper damping on it. ...
Right, if you are selling there is scarcely any logic to put money in serious damping at all. Do the "sasta, sundar aur tikau" thing:
* Get some closed-cell foam sheets, masking tape and bulk araldite
* Try to figure out which places vibrate the most in the door inner pads (your fingertips would be the best sensors)
* Stick the cc foam on the door pad inside with araldite. When the araldite hardens stiff, it will itself provide some damping with the cc foam
* Roll some closed cell foam and stick them to the inner metal part of the door, in a way that the door pad would press the foam when fitted back. Tape the roll down after applying araldite, so that it does not fall away
* Get some masking tape and stick loose cables down wherever you feel they may cause a rattle
* Ditto for the boot
__________________
Old 30th March 2008, 22:02   #68 (permalink)
I am going to use Flashing Tape which is way cheaper than Dynamat and probably have to put 3 to 4 layers to get the result of Dynamat Extreme and its still cheaper than Dynamat Extreme.
Flashing tape I got was 150mm and 10metres roll. Got it for 11 GBP i.e., 880 Rs. and is sufficient for dooors easily. Will be putting it next weekend and will tell the results..
kiran1103 is offline   Reply With Quote
Old 31st March 2008, 11:13   #69 (permalink)
DerAlte's Avatar
Originally Posted by kiran1103 View Post
I am going to use Flashing Tape which is ...
What is "Flashing Tape"? What makes you infer that this tape will deliver performance equivalent to Dynamat Extreme even with any number of layers?
__________________
Old 31st March 2008, 16:15   #70 (permalink)
[COLOR=#000000]Flashing Tape s a self adhesive tape, comprising of an aluminium foil backed by a flexible modified bitumen adhesive compound. It is used for the repairing of pipes, joints, glazing systems etc.[/COLOR]
Ideally Dymanat Extreme is what I would have used or anyone for that matter, but thie point is budget deadening.
I mainly took this for the cost effective reasons and moreover I dont want to spend much on my car which I am sure of upgrading it in a year. And I am expecting a decent sound thats it..
And I did read in some forums that 3-4 layers does make considerable difference. The effective part may not be near Dynamat Extreme, but we are talking abt cheapest option and if effectiveness is required, I would definately go for Dynamat Extreme or Damplifier Pro kit from Second Skin.
Old 31st March 2008, 17:06   #71 (permalink)
Is it available in India ? If yes, where ??
__________________
Old 31st March 2008, 17:25   #72 (permalink)
I dont think so?? This is especially made for colder countries where the roof outlets are sealed off to prevent leakage. Google around and you will see how many have used this as an alternative deadening material in their cars. I can provide links of the installs also but dunno if its appropriate to post link of other forums.
Old 31st March 2008, 17:45   #73 (permalink)
DerAlte's Avatar
Oh, OK, it is a more sophisticated equivalent of "tar felt"!
Sure, it should work, as long as it feels heavier than neoprene and other rubber sheets per unit area. Even it is twice as heavy as ordinary rubber sheet of same dimensions, you will be close to ideal in 2 layers, 3 layers being even better.
__________________
Old 31st March 2008, 19:17   #74 (permalink)
nickoo's Avatar
hi folks...i am not new to this forum since i have been tracking this section for quite some long but this is my first post.
I have a Swift with Pio 5050+ MTX Compos(TXC 6.0) in the front door and Kenwood (KFC-HQ718)in the rear.I am quite satisfied with the sound quality but the only issue is the rattling of the front doors. I have been looking for decent value for money dampening material since the front door rattle a lot. Any idea from where i can procure Noise Kill in Delhi or NCR regions.
Would appreaciate any kind of help.
nickoo is offline   Reply With Quote
Old 31st March 2008, 19:44   #75 (permalink)
DerAlte's Avatar
Though damping reduces rattling, it is more by way of the nip-and-tuck that takes place during applying damping.
If you facing rattling, like "a couple of small stones in a plastic bottle" type, have someone open the door pads and tape the lose cables and wires down. Also check if there is any play in the window winding mechanism and the latch / lock mechanism.
Once you have got these problems sorted out, you can invest in damping - which will reduce / remove the annoying buzzes, the squeaks and the trrrr's.
__________________
Thread Tools
The Damping Material and Sound Deadener Thread kb100 Product Discussions 563 1st November 2008 01:46
How effective is sound deadening material in tackling rattling ? swathyd Ask the Gurus 19 15th August 2008 21:15
sound proofing material query makanaka Product Discussions 3 11th August 2008 12:53
Fiesta Vibration Damping unleash_me Ask the Gurus 2 14th March 2008 23:55
Sound Proofing material for car ezee Modifications & Accessories 18 3rd February 2008 14:35
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
