| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jun 2006 Location: Bangalore
| I have a very bad experience to tell. My beautiful amp (alpine mrv-f345) has been ravaged !! Had given my car for service yesterday (dakshin honda). As usual I removed the faceplate so these ppl don't mess with the system. After I received my car, I put the faceplate back and switched on the system. The only thing I heard was static/noise even when no cd was present in the HU. This noise was coming only from the front speakers. Selected FM, adjusted the fader to rear but still the noise persisted but the rear speakers and subwoofer was fine. Thought the front speakers were blown. Today took the car to my installer and showed him my problem. He removed the speakers and connected them back. And everything works fine!! The front speakers are playing good and loud.But wait...a peculiar problem was observed. Even when the volume is at level 0, the left front speaker is vibrating. Removed the RCA source from the HU/Amp, still the speaker is vibrating!! Put in a different speaker, same problem. Now checked the amp and immediately could find white spots around the RCA inputs. Water !!! Put in a different amp and this problem disappeared. Opened up the amp and could find water spots on the PCB. The amp is installed in the boot and these ***** might have washed the car with the boot open or might have washed the boot itself. Now the amp's gone for repair.Now a few questions: - Is this a major problem? like i said before, the front speakers are playing now but even at volume 0, they are vibrating. - will the amp function as before i.e. has the SQ of this amp compromised now? - finally, is this repairable? |
| | #2 (permalink) |
| BHPian Join Date: May 2006 Location: Somewhere
| If you have the schematic diagram of your Amplifier send a pm to me so I can suggest you something on this issue else take out the Amplifier and do some cold checks on it by putting amp.meter in series to see how much Amps.it draws(compare Amps.with the working set and post results here).Seem to be a capacitor prob as fm your post it seems your fuse has not blown off,good luck dude. |
| | #3 (permalink) |
| Senior - BHPian | I really know what you feel dude. I got this done to my old CD Changer once. And to one of my front speakers recently. Luckily both survived. But I got rid of both, because I couldn't stand keeping on waiting for them to go kaput later. Now I give explicit instructions that NOTHING in my boot is to be touched, and that the boot door shouldn't be opened when washing. And I remove the faceplate and the sub when I give the care for repair anyways. If I could remove anything else I would. Grrr...
__________________ Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #6 (permalink) |
| Distinguished - BHPian ![]() | Yes wiking, you are right, they probably sprayed your amplifier. IMO it doesn't appear to be too bad, I am sure the service station will fix it. Do let us know what they say.
__________________ “I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart |
| | #7 (permalink) |
| BHPian | Hey Wiking, It surely is repairable, a couple of IC's and capacitors out at the most, and wud definately be repaired, thou it might cost a couple of thousand. I reckon you should go and complain and show this to the Works Manager. Honda is a big name, the works manager will surely take a look at it. Wether they reimburse the repairing charges or not, do let it come to the notice of the Manager there so that it doesnt happen to others. a good deed towards the society! ![]() Hope u get back ur amp fast and keepin fingers crossed u dont lose out on any output! |
| | #8 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Like Sam said, it doesn't seem like it's something very major. I would think you're being let off quite easy. For now, don't power up the system at all (or atleast the amplifier). Also please remove the engine comparment fuse for that amp. I am surprised at the carelessness with which service center guys go about spraying the car with water. If you didn't have an engine compartment fuse, and the water reaches some part of the amp's power supply, something like this could easily result into a bonfire in your car when you start up the system.
__________________ Losers Commute. We Ride. |
| | #9 (permalink) | ||
| Senior - BHPian | Quote:
__________________ "Keep your friends close, Keep your enemies closer" | ||
| | #12 (permalink) | |
| Quote:
__________________ Losers Commute. We Ride. | |
| | #13 (permalink) |
| sorry guys... i was busy today and didn't have time to reply !! forgive me ![]() ECM... highly unlikely i will be able to get the schematic for the amp. So hope the repair center gives all clear or be able to fix the amp. LBM... only one of the channels was creating problem (speaker vibrating even at zero olume). Also doesn't look like the amp was immersed in water!! basically the amp is installed upside down, so the RCA input/speaker outputs are facing upwards. so i think water was stagnant on that side and seeped into the amp innards. Yes.. i did put in a strong word with the service manager. he was very apologetic but told me that they handle all expensive items carefully, also said that they give strict instructions to only vaccum the boot and blah blah blah... i don't think anything will happen if i follow up with them!! I never thought that service guys would be so careless, else i would have made doubly sure that boot was not washed. Also would have played the system in front of them as soon as i received the car. Rudra sir... problem is not yet fixed... I shall come to know about my amps condition on Monday. Yeah... even i thought of this solution of drying the amp but it seems that since the power wire is still connected, there is supply to amp. Some of the components might have shorted in contact with water. Keeping my fingers crossed... per se the amp works fine but like i said even when no input source/volume 0, the speaker is vibrating. |
| | #14 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| most likely you have leaky cap or 2 and maybe a damaged transistor. I agree it should be an easy fix by any decent repair guy. I had this happen once when in one install I had an amp under the seat and drove my car though some floods (that was 12-14 years ago). Your amp can return to normal. It's SQ might not be compromised. It's reliability however will depend on the service center's work.
__________________ Scixelsyd Etinu |
| Thread Tools | |
Similar Threads | ||||
| Name suggestions for an upcoming Dealership\ Authorized Service Centre, any one? | arif_t01 | Shifting gears | 43 | 25th February 2008 14:14 |
| Free service can be done at any dealer service station? | dsinz | Indian Car Dealerships | 8 | 15th September 2006 12:55 |
| hello.. Is authorized service center is worth? | Mr.Bangalore | The Indian Car Scene | 2 | 26th July 2006 11:23 |
| A Honda Fan's angst with their authorized Service Center | manveet | Indian Car Dealerships | 12 | 10th July 2006 13:47 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
