| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| Hi guys, Its since yesterday that i am facing few problems with my audio.. I have two amps JBL601.1 and a JBL 75.4 and HU pio 7750. When song is played (low/high volume), the head unit switches off and then immediately get switched on. T Any suggestions??
__________________ TRUE TO THE SOURCE - DD Bass is an addiction... And Professionally I am MAD: Mobile Application Developer |
| | #2 (permalink) |
| Senior - BHPian | it might be the power wiring of the hu gone lose... or the harness fitted has a loose connection.... one thing more check does the amp swtich off when the hu goes off.... does the sound also stop when the hu goes off....
__________________ 156.6 db, naa....time is coming to cross it...... |
| | #3 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| exactly what happened some days back while driving to work. was listening to "beedi jalaile" (hehe...J/k) at high volume, just to realize that on a low note, HU power went off and again came back. it happened thrice on different occasions, when finally i tried swtiching to FM while the HU went off....oops! it stopped reading the CD (changer). tried everything i could but NO. i am going to my installer right now (aaj ka sunday bhi gaya).
__________________ SINGH IS KINNNNNNNG.. |
| | #4 (permalink) | |
| Quote:
I'll check if the amp switches off... but then what do we understand, if the amp does or does not switch off. Ya the sound does stop when hu goes off.
__________________ TRUE TO THE SOURCE - DD Bass is an addiction... And Professionally I am MAD: Mobile Application Developer | |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
I have asked it before that the amp switch off or the sound stops because it might the hu screen had some problem....but as u said the sound stop then it might be the harness or the connector which is connected to the HU....check it out by your installer....
__________________ 156.6 db, naa....time is coming to cross it...... | |
| | #7 (permalink) | |
| | #8 (permalink) |
| BHPian | Hey Amit, Hope this helps... Initially at times when music played at high volume, and there be a big bass punch, my HU power would momentarily go off and come back in a second.... later on i found out it was due to weak battery to amp wiring. The amp load got so high, it drew in more current or something, and shut the hu off. so then on, i changed my batter-to-amp wire to a good thicker wire, and now never faced that problem again. It is sometimes also related to the RC Cords. I suggest u get ur RC Cords and battery-amp wiring checked again. |
| | #9 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
__________________ Scixelsyd Etinu Last edited by navin : 25th September 2006 at 11:22. | |
| Thread Tools | |
Similar Threads | ||||
| ICE for SX4 (Amplifier problem) | anand4linux | Ask the Gurus | 12 | 18th August 2008 23:59 |
| Help/Guidance for Solving the problem in My ICE!!! | rajeevrs | Ask the Gurus | 17 | 14th November 2007 16:18 |
| NHC - BullKit Problem :EDIT: now detected to strut problem | ibcool | Technical Stuff | 13 | 9th September 2007 12:02 |
| Problem with ICE in Indigo Marina | prakashchopper | Ask the Gurus | 7 | 11th May 2007 21:44 |
