Thread Tools
Old 10th October 2006, 15:47   #1 (permalink)
Technocrat's Avatar
Question How to find how much db My ICE puts up ?
Hi Techies,
I was reading through the thread on impact of loud music on infants & grown ups. I have often heard techies saying that they listen to volumes not more than 85-90db. My question is how can a normal person find out how much db he\she is listening to? I am asking coz my ICE as most of the aam junta is kind of more towards SPL than SQ. So how can I find out teh db levels so as to ensure that I am not listening to dangerous levels ?
Techno
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 10th October 2006, 15:49   #2 (permalink)
navin's Avatar
If you have to shout to make yourself heard it is too loud. The volume should be similar to normal conversation.
__________________
Scixelsyd Etinu
Old 10th October 2006, 15:55   #3 (permalink)
Technocrat's Avatar
Ok thats about the loudness part, what about how to find out db ? is there a simple conversion based on wattage etc? sorry if it sounds dumb but I would rather ask than be dumb
Also if what you say is correct you should never need an amp, a set of comps in front & 6X9 at rear should do and the current day HUs IMHO have enough power to fire them at conversation levels
__________________
Old 10th October 2006, 16:14   #4 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
Techno, amps are not for higher sound levels. they are for better sounds. this is the way i look at it, i am an absolute novice here. B&T & navin might give the technical info on these.
on a low output system, have you realised anytime that the best blend of the music comes out only when you turn up the volume ? similarly, i think what the amp does is to amplify those sounds to give you a good output at normal hearing levels.
i hope i haven't sounded stupid. thanks
__________________
Goodbye Dada, you made us proud.
Old 10th October 2006, 16:18   #5 (permalink)
Technocrat's Avatar
I agree with you EL but I believe at conversation levels the Hu does a decent job(IMHO but others may differ ) its only at slightly higher levels that amps help in maintianing teh clarity & crispyness of the sound.
Anyways this was just part of my question, I want to know how loud is bad(Sorry Navin but your answer is very open ended ) & also how can I find out the db levels in my ICE?
__________________
Old 10th October 2006, 17:47   #6 (permalink)
low_bass_makker's Avatar
this is a comparison chart for the db scale....for the music there is not a single value it has a lots of peaks and dips but the max value can be taken also....for measuring the db scale accuratley we need to play sine waves to achive the figure.....what is the system is capable of....
to measure we need db meter....
low_bass_makker is online now   Reply With Quote
Old 10th October 2006, 17:49   #7 (permalink)
Technocrat's Avatar
Hmm pretty much on Navin's line but I guess this ones a lot clear. Thanks LBM
__________________
Old 10th October 2006, 17:54   #8 (permalink)
navin's Avatar
The ear is not linear. Sound pressure depends on the components used (amp and speakers) the insall and the listening position and even then reading would depend on the freq sepctrum used.
You can get a db meter (C weighted or A weighted) and these will give you an average SPL reading over the freq. spectrum as dictated by the weightage (A, C, etc..). The general accepted guidelines are that prolonged exposure (greater than 30 min) to sound above 90-95db can begin to get harmful.
Given that measuring SPL is not really an exact science (not a lot related to audio really is) it is best to realise then that our vocal chords evloved so as to allow us to speak clearly and be heard clearly without damaging another's hearing. it can hence be deduced that if you have to shout to be heard your music is too loud.
Within it's "pass-band" (generall accpeted to be 200Hz to 6000Hz) the human ear is very sensitive and accurate. Alll we need to do is use it.
__________________
Scixelsyd Etinu
Old 10th October 2006, 19:40   #9 (permalink)
Bass&Trouble's Avatar
Not dumb at all, good question. I see that Navin has answered it quite well, and let me do some deciphering here.
SPL can theoretically calculated with reasonable degree of accuracy. For that, you will need to know the SPL of the drivers (or better still the system), and the power input to them. Based on sensitivity at 1W/1m, you can increase the spl by 3dB for every doubling in power, for the same distance. Once you know the system spl at X watts for 1 meter, you can now calculate for the distance required by subtracting 6db, for double the distance, or adding 6dB for half. This way you can achieve the theoretical SPL. But in reality, the effect of the room, cabin of the car, speaker placement etc. will differ from theory. For such situations, a SPL meter is best. (You can get one at Radio Shack for $25 or something)
This is due to the ear's listening pattern. Like Navin said, the ear isn't linear, and is more sensitive to frequencies around the mid-band.
This is also the reason why head units have 'loudness' as a feature. The idea of the 'Loud' function is to boost the lows and highs without altering the midrange, so that at low volume levels, frequencies that are not distinctly audible to the ear become fuller.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 10th October 2006, 20:00   #10 (permalink)
coool B&T , now i get the idea...
__________________
Old 10th October 2006, 20:01   #11 (permalink)
Technocrat's Avatar
Thanks a lot Navin(This one was clearer ) and B&T.
Hmm Now I have an idea how loud should be bad. Now all that I need, is to find some one who has SPL meter to get the db ratings for my ICE(just want to know)
btw this is my current ICE stup colourfull isnt it
Just need to get teh db figures for this setup
__________________
Old 10th October 2006, 20:14   #12 (permalink)
how is the sub mounted
box or IB ?????
Old 10th October 2006, 20:16   #13 (permalink)
Technocrat's Avatar
Ported Box in Alto's Boot below the rear tray on which the rear speakers are placed.
__________________
Old 10th October 2006, 20:19   #14 (permalink)
from where did u made the ported box....which ports are used....any pics would be help full.....
Old 10th October 2006, 21:51   #15 (permalink)
rsjaurr's Avatar
technocrat,this is really a technicolor system
U got all the basic colours,blue,red and green!!!!
BTW why dont u do the way B&T has suggested or ask LBM to courier his SPL meter for few days.He is our residant SPL expert here..
rsjaurr is offline   Reply With Quote
Thread Tools
GM puts temporary brakes on Vette production amit The International Automotive Scene 8 18th September 2008 03:23
Tiff Needell puts his real world skills against David Baker (UK GT4 champ)!!! Shan2nu Shifting gears 5 16th September 2008 22:15
Indian Auto Industry puts Expats in Drivers Seat Dolphin The Indian Car Scene!! 2 6th May 2008 17:14
Where are we going to find an MR2? spdemon Shifting gears 3 3rd March 2006 09:31
An 8 wheel electric car that puts Enzo to shame. v12 The International Automotive Scene 12 25th December 2004 17:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
