Thread Tools
Old 13th October 2006, 13:50   #1 (permalink)
bruce's Avatar
Default Uninteruppted Power for ICE
Hi Frens!!
I have a concern with the music system in my car, more of an annoying issue really...
I have Alpine 9851R fitted with the Kenwood OEM speakers from Suzuki, all is fine.... except the system restarting every time I switch off the engine.
I would like to avoid this, also if I have the radio on the powered antenna goes down and starts again...
I feel that there's some possible solution by drawing power directly from the battery...
has anybody thought about this? if you have found a solution, please can you help me?
Any valuable feedback is very much appreciated!!
Thanks in Advance!
__________________
Bruce
_______________________________________
If at first you don't succeed, skydiving is not for you!
bruce is offline   Reply With Quote
Old 13th October 2006, 14:00   #2 (permalink)
navin's Avatar
You can take power from the battery instead of from the ignition switch. be careful is you leave your stereo on overnight accedently you might not be able to start the car the next morning.
__________________
Scixelsyd Etinu
Old 13th October 2006, 14:12   #3 (permalink)
Sam Kapasi's Avatar
Your alpine 9851 has two power cables. One is Yellow (always on) and one is Red (works with the ignition key)
If you wish to have the system always on, simply disconnect the red cable from where it is now and join it to the yellow cable.
1. Make sure you use lots of insulation tape.
2. As Navin rightly pointed out, make sure you switch your system off when you leave the car, or else you will run down your battery.
__________________
Live the YetiLife®
Old 13th October 2006, 14:45   #4 (permalink)
tsk1979's Avatar
What exactly do you want, an always on system, or a sytem which retails its power when engine is off but key in in ignition?
My indica system remains on on engine turn off and goes off only when the key is removed from the starter.
I think thats what you want, rather than an always on system which gets power wether the key is in ignition or not?
__________________
Reclaiming.....!
Old 13th October 2006, 15:11   #5 (permalink)
Sam Kapasi's Avatar
Your Indica ignition switch is designed like that. Once switched on, it stays on, regardless of the engine condition, till the key is pulled out. It has absolutely nothing to do with the system wiring.
Certain cars cut off the ignition supply to the accessories while starting up. I think he is referring to this fact. When you turn the ignition on, the deck comes on. (Assuming you didn't put the system off, just used the key to shut it down, while leaving the car) Then when you crank the engine, the deck goes off and the power antenna begins to retract etc, then once the engine is on, the power antenna goes back up and the deck comes back on.
__________________
Live the YetiLife®
Old 13th October 2006, 15:20   #6 (permalink)
Technocrat's Avatar
Bruce I think it is possible to get what you want, One of my friends Wagon R has Balu HU & its power is independant of the Key, i.e. teh HU works irrespective of whether engine is switched on or off or whether there is key or not. The bad is you haev to remeber to turn your system off every time you leave the car.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 13th October 2006, 15:23   #7 (permalink)
ess_a's Avatar
I have heard people saying that cranking a car, with the music system on, can ruin the system in the long run...(Reason- a sudden gush of power supply, after cranking can cause trouble with the system) Is it true?
__________________
The speed of sound is the fastest when some talks in the car, that I am driving...!!
Michael FOREVER...
ess_a is offline   Reply With Quote
Old 13th October 2006, 15:29   #8 (permalink)
Sam Kapasi's Avatar
@technocrat - Older Blaupunkt head units had intelligent on. If you tried to switch the unit on, with the ignition off, it would still switch on, but shut itself after an hour. A typical case of European over-engineering. I am afraid the Alpine does not do this.
@ess_a - There can be no sudden "gush". The battery is 12V and 12V is all it can gush out. However, it is not nice for any electronic products to be switched on and off rapidly. Also, when cars are fired up (by cranking the engine) the voltage may drop to as low as 10V because of the load of the starter. In the case of sophisticated electronics, this sudden drop may hurt the components inside.
Ideally, your system should be off, BEFORE you start the car. Ofcourse most of us (including me) don't follow that rule.
__________________
Live the YetiLife®
Old 13th October 2006, 15:37   #9 (permalink)
tsk1979's Avatar
Yes I agree, when you crank engine, system goes off. Thats not the query however. He says that when he turns off the engine, the system resets. though I have seen system off while cranking in many cars, including a indica petrol, I have not seen system going off while engine turning off
__________________
Reclaiming.....!
Old 13th October 2006, 15:45   #10 (permalink)
Technocrat's Avatar
Wow thats a nice feature didnt know this Thanks Sam.
As about switching off the system, I do it before both starting & shutting of almost 95% of the times
__________________
Old 13th October 2006, 16:02   #11 (permalink)
navin's Avatar
What?
As bad as this is I know this to be true (most people don't switch the AC/ICE off). I live in a building where we have to double/triple park so often I have to move a few cars to get my car out. Each car I have moved so far has it's AC on and ICE on (usually at full volume).
One option I can think of is to get a timer that can be set from 5 secs to say 20 secs and is reset when the ignition is turned off. THis way your accessories wont come on untill 5-20 secs after you have got ignition.
__________________
Scixelsyd Etinu
Old 13th October 2006, 16:04   #12 (permalink)
ess_a's Avatar
Oh good! So one neednt worry too much... BTW i have fallen into a habit of switching off the system before turning off the engine.. (Diesels idle to save their engine, i do that to save my system!!) Fear psychosis i guess...
__________________
Michael FOREVER...
Old 13th October 2006, 16:11   #13 (permalink)
Jaggu's Avatar
if its system resetting (as in all settings including clock going to default) then ur yellow wire (direct battery) is also wired with the (through ignition) red wire or a ulta pulta scene, but if its just momentary on n off while cranking then its the way the system is should work as designed by car manufacturer and all the above advices hold good
@Navin.. delay switch is a good idea something similar to professional home systems
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 14th October 2006, 23:58   #14 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
i guess you have developed a good habit & i would suggest you do not kick it. it is hard for people like me though. i like to idle the engine & listen to music while i pick up my things & when i am all set, i just turn off the car & pull out the key.
@Bruce... You can draw power directly from the battery & have uniterrupted ICE only as long as your battery & electricals are fine. if your battery is weak, then your ICE will restart because all the available power would have gone to the starter. like everyone here has said, do not forget to switch off the system when you leave the car. cheers
__________________
Goodbye Dada, you made us proud.
Old 19th October 2006, 19:41   #15 (permalink)
Default hi
Originally Posted by bruce
Hi Frens!!
Thanks in Advance!
all you got to do is to add a 4700 mfd/63v or 10,000 mfd/63v condensor (capaciator) . you will have to wire the positive of the capaciator terminal to the red wire and the negative of the capaciator with the car gruond or earth .
you could add a 470 mfd/63v for the yellow line .
even if the car stalls in the middle of the traffic ,and you want to restart the engine ,the music will still keep playing . however ,when you add the 470 mfd ,after you switch off the ignition ,the system would still play for abt 5 secs ,before your music system switches off .
peak charging current of a car is 14.4 v . Any music system which is manufactured has an operating range of 10-14.4v . Adding the extra capaciators would keep your car supply steady to the music system ,and nothing will be damaged . Infact the system would be much better with the capaciators .
have a try !
greatmana2000 is online now   Reply With Quote
Thread Tools
ICE & Battery / Power issues s0uljah Ask the Gurus 38 21st September 2008 00:17
Brake lights cutting power to ICE??? tmanish76 Technical Stuff 7 31st March 2008 12:28
External Power for ICE, can it be done? vidvai Ask the Gurus 18 14th August 2007 01:01
power-house of ICE need help!!! amit_sound Ask the Gurus 54 17th May 2006 13:27
How to determine what size Power Cables for ICE? Answers inside... gunbir Ask the Gurus 96 8th May 2006 12:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
