Closed Thread
Thread Tools
Old 16th October 2006, 10:07   #1 (permalink)
hey guys, i got a Sony XM-554ZR 4 channel amp driving a pioneer 306 DVC. i dont what is bridging, but i'll try and explain the wiring, one voice coil is powered by the front output, +ve from left channel and -ve from the right channel. and the other coil is powered by the rear output +ve from left channel and -ve from the right channel. i hope you've got an idea what i am trying to say. now the problem is that whenever i listen to a very bass heavy song like - nelly - grillz(ya'll should listen to it, if u got a system) the amp trips or overheats at high volumes. i mean you can feel, the woofer turning off for 2 seconds, then turning on for 4 seconds and then turning off again for 2 seconds. this goes on till i reduce the volume to a decent level. any solutions??
and one more problem.. sometimes at high volumes, suddenly the "mids" and "highs" sound really high and then they are suppressed again... this happens for a few times and gets alright usually after 10 minutes.
got any idea on this??.. pioneer speakers in front, audiobahn in the rear. powered by an old headunit pioneer 5650 (ya ya, dont laugh, my JVC exad got stolen), speakers are powered by the HU only, HPF on at 80Hz
saint_sinner is offline
Old 16th October 2006, 12:53   #2 (permalink)
Bass&Trouble's Avatar
Check what power cable you are using for the subwoofer amp. You need 8-gauge. Likewise for earthing. And check the earthing point, should be a good contact with the metal, free of paint and grime, using a good quality ring terminal.
Which speaker cuts off? The fronts or rears, or both? If it's the rear, most Audiobahn speakers come with a poly switch protection to prevent clipping from damaging tweeters. This could be kicking in. If that is the case, you are turning up the volume too loud for the speakers.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now
Old 16th October 2006, 13:02   #3 (permalink)
low_bass_makker's Avatar
the power wiring could be the culprit....are u using BOSS power cable....as they give more rubber than the copper in it....
__________________
156.6 db, naa....time is coming to cross it......
low_bass_makker is online now
Old 16th October 2006, 13:07   #4 (permalink)
Sam Kapasi's Avatar
Also please realise that if you like playing your system loud (which is a big yes, I suspect) your amp is simply not enough to drive the woofer in question and is probably clipping, overheating & begging you for mercy in Japanese.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Sam Kapasi is offline
Old 16th October 2006, 13:24   #5 (permalink)
yes, the wiring is 8 guage. from the battery to the amp, and so for the grounding. but for the remote power, yes the wire is really thin.. i really dont think a thicker wire could be needed there. as for the amp not being powerful enough.. i really dont have a very good idea.. i think the woofer is 1000 watts, and the amp is 600 watts. also, the LPF of the amp is switched on at 80Hz. gain for both channels is set at about middle position. HPF of the HU is at 125Hz(it was at 80 earlier, what do you think is better?)
as for the speakers, there is no poly switch protection is the rear speakers, you can just feel that speakers worth 5000 bucks are sounding like 200 Rs karol bagh speakers. but the fluctuation of the mids and highs happens only for the initial 5 - 10 mins, is u play it loud. after that it does not happen again no matter how loud you play it.
I will get pics ASAP, as currently i cant, due to this...
Note from mod: Please dont deviate from topic. If you want to share info about your accident, there is a section called "Street experiences". Please read the announcements section before posting
Old 16th October 2006, 13:44   #6 (permalink)
Sam Kapasi's Avatar
Umm because your number plate broke in a small accident?
Did you have to post 3 large pictures to say that much in a thread you created about your overheating amplifier?
__________________
Live the YetiLife®
Old 16th October 2006, 13:52   #7 (permalink)
I must apologize for trying to help.
__________________
Old 16th October 2006, 14:05   #8 (permalink)
well thanks for the help B&T, might be a problem with HU, as the technician told me.
MOD PLEASE CLOSE THIS THREAD
Old 16th October 2006, 14:20   #9 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Note from mod: thread closed on request of poster
__________________
Reclaiming.....!
tsk1979 is offline
Closed Thread
Thread Tools
Gear Box Heating OHC VTEC malcolm Technical Stuff 12 19th November 2007 11:40
weird heating problem in accord prateek Technical Stuff 23 22nd June 2007 16:29
Over Heating Problem lancer_maniac Technical Stuff 13 13th December 2006 19:32
Esteem heating up. bhogalrajnish Technical Stuff 24 13th August 2006 01:49
Guess this one ajmat The International Automotive Scene 4 25th March 2004 18:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
