Closed Thread
Thread Tools
Old 16th October 2006, 23:19   #1 (permalink)
Hey Gurus
First of all, let me thank you for making my car-buying decision easy.
Bought a petrol Innova (V-Model). It came with a double-din system, which I found pretty ordinary.
Now I want to go for a change (budget around 25K). I went through the INNOVA install threads and could not find anything that advised around this budget.
I normally listen to mostly Hindi/South Indian music, not a very high volume guy but prefer clarity.
Now my doubts:
1. Can I keep my Head unit and change only the speakers ? (Are the supplied speakers any worth ?).
2. Is the option of two amps (one 4 channel for speakers and a mono for sub) is good or the option of 4 channel for speakers is good.
3. If I want to go for a sub-which is the best place? I am not very comfortable having it in the dickey ( almost non-existent to me in INNOVA).
4. I was thinking of going in for a JBL amp(mono CS300.1) and a sub with box (CS1204B) and comp-speakers for the front. Should this be OK.
I have been given two tweeters that are placed near the small window in the front, will they still be connected in the new setup ? Is there any specific advantage of the BASS Tube Sub?
5. Looking at other INNOVA threads, looks like Dynamat Damping is necessary. How much would that cost
5. Finally, are there any good installers in Hyderabad that any bhp-ians had a good opinion about?
TIA
Sudheer
sudheerys is offline
Old 17th October 2006, 01:51   #2 (permalink)
Hi sudheerys,
First of all have a look at these threads.
http://www.team-bhp.com/forum/car-en...k-25k-30k.html
http://www.team-bhp.com/forum/car-en...ta-innova.html
http://www.team-bhp.com/forum/car-en...up-innova.html
http://www.team-bhp.com/forum/car-en...a-install.html
Cheers,
Mugen_Power.
Mugen_Power is offline
Old 17th October 2006, 11:20   #3 (permalink)
esteem_lover's Avatar
hi sudheerys,
welcome to T-BHP ICE.
i would suggest you keep the double din & spend money on the speakers etc., since you are on a budget.
__________________
R.I.P Islero
esteem_lover is offline
Old 17th October 2006, 16:48   #4 (permalink)
Sam Kapasi's Avatar
Originally Posted by sudheerys
Now my doubts:
TIA
Sudheer
1. Yes thats the first thing you need to change
2. If on a budget, you can install just a 4 chanel amp. Bridge the rear for the sub and use the other two for the front compos. Sure if you can afford it, go for a 4 channel amp with a mono block, it's better
3. Well, look at the specified links and you might get some ideas.
4. No, if you buy a component set, then you existing tweeters should be removed. No advantage or disadvatnge to a subwoofer enclosure. The bass tube is a popular, VFM bass enclosure that sounds pretty darn good.
5. Dynamat damping, or any other brand damping is not necessary. Yes It improves the sound and reduces the rattling and metallic vibrations quite a bit, if it is there. At this level you may not find it necessary.
5.(what? again?) I will leave that open for some hyderabadi team-bhpians to answer
__________________
Live the YetiLife®
Madonna is a Goddess.
Sam Kapasi is offline
Old 17th October 2006, 20:58   #5 (permalink)
Default Thanks a lot
Thanks a lot guys for the immediate response, that surely helps me decide soon.
Thanks a lot Sam, for the advice. Another (rather stupid) question, is there an amp which has both 4 channel and mono block. I could not find anything like that in the JBL brochure that I got. Any model number would help.
Spoke to a bhp-ian who works with me (Satish), he was saying there are none.
I visited the impressive JBL stall in the recent Lifestyle show, somehow I was feeling they should have an inhouse installer who should make people realize how good the JBL accessories are and also how different they perform when installed correctly.
May I go ahead and suggest that they should get an enthusiastic guy(who is not necessarily knowledgeable about JBL) and train him inhouse.
Now, from the advice what I have decided: I will go for a JBL amp (may be cs60.4) with a comps for the front and leave the rear ones as they are.
In the next installment, buy a sub and rear co-ax speakers.
I was thinking I will listen after the amp and comp installed with my existing HU and then decide on replacing the HU . As I want to replace my doublel-din with a good double din. Till now , I could find only FHP5000MP or FHP4200MP. I would also like to know if anybody has experience with these models.
Thanks a lot,
Sudheer
Old 18th October 2006, 11:59   #6 (permalink)
navin's Avatar
JBL does make 6 ch. amps you can bridge 2 ch. for the sub. But usually these 6 ch. amps are more expensive than a 4ch. amp + monoblock combination. Sam, Gunbir, B&T can provide price datails for comparision of a 5/6 ch amp vs 4 ch. + monoblock.
__________________
Scixelsyd Etinu
navin is offline
Old 18th October 2006, 19:58   #7 (permalink)
Thanks Navin sir....I googled and found that GTO 755.6 is one 6 channel amp that is from JBL but I am not sure whether it is available in India....especially in Hyd'bad.
Sam, can you pls. help me if I can get this in Hyd'bad.
Sudheer
Old 19th October 2006, 03:05   #8 (permalink)
I have replaced double din to single din in my innova.
Have a look..
Cheers,
Mugen_Power.
Old 19th October 2006, 03:06   #9 (permalink)
I googled and found that GTO 755.6 is one 6 channel amp that is from JBL.
Visit www.fxaudio.com for more details about JBL.
Cheers,
Mugen_Power.
Old 19th October 2006, 04:06   #10 (permalink)
speedzak's Avatar
Have a look..
Pic
Cheers,
Mugen_Power.
That's a good thing to do. Single din would be better than Double din.
BTW, Mugen! In the pic, the HU seems to be a bit protruded than the below cubby. Ain't it supposed to be flush mounted as in LBM's Swift?
Is it just because of the way this pic is shot or is there a difference between upper and lower dins?
__________________
Music heaven a touch away!
SK456's Santro.
speedzak is offline
Old 19th October 2006, 11:03   #11 (permalink)
navin's Avatar
There are more single DIN HUs out there and most development happens in 1 DIN hence you tend to get some very nice 1 DIN Hus while many 2 DIN HUs are quite ordinary.
__________________
Scixelsyd Etinu
navin is offline
Old 19th October 2006, 19:17   #12 (permalink)
Thanks a lot Mugen_Power for the photo and thanks Navin sir for the advice.
Mugen_Power : one question, were you able to exchange the HU gave by Toyota ?
I think I will postpone my HU replacement for a while and start with adding an 4-ch amp and comps for the front.
The reason for my interest in 2-din is two fold; one - I have a lot of casettes (mainly my wife's - so can't mess around with those) and two - it fills the place quite neatly.
Saw a pioneer 2-din in a friend's wagon-r, looked quite impressive.
Sudheer
Old 19th October 2006, 20:54   #13 (permalink)
Sam Kapasi's Avatar
Sorry Sudheer, but the GTO755.6 is not sold in India.
__________________
Live the YetiLife®
Old 19th October 2006, 22:42   #14 (permalink)
sudheerys,
I have sold my Toyota Head Unit to my friend who replaced his single din head unit to double din in his Innova G.
Cheers,
Mugen_Power.
Old 19th October 2006, 23:21   #15 (permalink)
Thanks Sam....that leaves me with no choice but to go for a 4channel amp (st60 or st75).
Thanks mugen_power.....I will have to look out for a Innova G .
I will write about my installation exp. in Sprocket, Hyderabad.
Sudheer
Closed Thread
Thread Tools
ICE budget 25k...period sanchits Ask the Gurus 6 3rd August 2008 22:58
Budget 50K.ICE in my i10. somebodystopme Ask the Gurus 25 18th May 2008 16:45
ICE for Innova BUSA Ask the Gurus 265 10th May 2008 10:22
ICE for Alto - Budget Rs. 12,000 vebmetal Ask the Gurus 102 6th May 2008 22:50
ICE for Fusion budget 25k harshalm Ask the Gurus 10 3rd November 2007 15:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
