Thread Tools
Old 18th October 2006, 21:34   #16 (permalink)
Sam Kapasi's Avatar
Each woofer inside is 300Wrms/ 1200W peak.
It will need a real strong amplifier. Also more power will be required as it is a bandpass box and the woofers are completely sealed inside.
__________________
Live the YetiLife®
Old 18th October 2006, 21:46   #17 (permalink)
blueraven316's Avatar
Originally Posted by anToNIcHeN
whereas, in the other case, if you carefully adjust the gains.... you are safe..... like hydrashok has said.. only upper 2/3rd.... that if you have 600 RMS sub, you can safely attach 1000 RMS amp to it..
regards,
ant.
I have to disagree to this, if you run a 600 RMS pair of subs with a 1000 RMS amp and adjust the gain so low to that it comes down to approx 600, then why buy a 1000 RMS amp in the first place ? its a waste of money.
On the upper 2/3rds gain of a CEA rated 1000 RMS amp the amp will still chrun out close to 1000 RMS which is a whopping much higher than 600 RMS. It is dangerous, period,
If one uses a 800 RMS amp with a 600 RMS pair, then one can play with the gain, but using a 1000 RMS amp and then underpowering it is no good.
blueraven316 is offline   Reply With Quote
Old 18th October 2006, 21:48   #18 (permalink)
Yeah Sealed and Bandpass enclosures need powerful amps to get the right potential of the subs to come out.
But that need not be double the power, even 20 % more than subs is fine.
Old 18th October 2006, 23:30   #19 (permalink)
Sam Kapasi's Avatar
No blueraven baba, you aren't entirely right here. Navin will be along shortly to technically explain why, especially in the case of subwoofers, more power is better.
I do hope he will be well enough to post that. Come on old chap, explain to to the young one why.
__________________
Live the YetiLife®
Old 19th October 2006, 00:56   #20 (permalink)
redeye's Avatar
sam i asked john about the recent thread "bad experience with sprocket" he told the lancer had local wiring so he advised to change him for better ones and there was distortion because the pioneer speakers were wore out ...told john about team-bhp he said he's gonna join very soon..
redeye is offline   Reply With Quote
Old 19th October 2006, 00:59   #21 (permalink)
redeye's Avatar
i bought this beast for 25k on 5th sept ..did'nt enough money to buy a powerful amp then, i bought it in sprocket ..john told me i'm the first to buy in bangalore ..i'm not sure i'm the first in india... but i would be really happy if i am the first...
Old 19th October 2006, 11:40   #22 (permalink)
hydrashok's Avatar
Don't sealed sub set-ups need double the amp power vis-a-vis ported set-ups to achieve the same output?
In a ported box, the air pressure/rear wave of the sub's excursion gets to exit through the port. So the sub's cone can move in and out quite a bit, and generate more sound output, as well as pressure. And since the resistance to movement (of the cone) is not much, the power required from its amp is not so much.
But in a sealed box, the air pressure created by the rear wave remains inside the (airtight) box. So the sub's cone cannot move backward much. It cannot move forward a lot either (as compared to a ported set-up) as the vacuum built up by sealed rear area limits its forward excursion. This way the beats (outward & inward movements) are quick & tight. And this resistance (to a lot of outward & inward movement) requires that a lot more power (ideally double the power) be fed to the sub if the output is to be more-or-less equivalent to the output the (same) sub can produce in a ported set-up.
Now have I talked myself stupid here? Huh? Huh?
And doesn't the same principle apply to a bandpass sub? After all, a bandpass box is mostly like a sealed box in a ported box (or a sealed box joined to a ported box), right? Gurus, could you correct me if I'm wrong?
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 19th October 2006, 11:52   #23 (permalink)
navin's Avatar
I guess Sam really wants me to mouth words like "The Mechanics of a woofer (sub or not) is best explained by studying mass-spring dynamics."
There are actually 12 components that make up the loudspeaker. They are the Basket, Top plate, Back plate, Pole piece, Magnet, Cone, Voice coil, Spider, Dustcap, Gasket, Leadwire and Terminal. When you look at a loudspeaker from the front you see the cone and dustcap, and it looks like a speaker. If you look at the loudspeaker from the side you will see the bottom of the cone has two wires coming out that run to the terminals. These two wires are the two ends of a single wire called the voice coil. If you look a little closer, you will see the cone is attached to another corrugated piece at the neck or bottom. This is called a Spider. there is a cutaway pic here.
http://electronics.howstuffworks.com/speaker6.htm
about 2/3rd of the way down on this link below is a electrical circuit that is analgous to the mechincal components of a loudspeaker. I find this the easiest way to visualise how a loudpspeaker functions.
http://en.wikibooks.org/wiki/Acousti...ic_Loudspeaker
The Spring effect is created by the Sealed Box behind the Loudspeaker. The less Lossy the box the sitffer the sping and the more the energyry will be required to counter the spring effect. Similarly the heaviver the mass of the cone the more the energy required to move it. Hence Heavy woofers in small sealed boxes require the most energy to move. Energy is what the amplifier provides (measued in Watts). A simple way to understand this is here
http://www.trueaudio.com/st_trade.htm and this site is an excellent resource for DIYers. (shamless plug: if you look at the Dave Platt link you will find one of my earlier crossover circuits under "go here for further information").
For the more technically inclined this PDF covers the basics well.
http://www.iet.ntnu.no/courses/ttt41...ng_answers.pdf and YES! microphones and to some extent record player styluii work almost the same way!
__________________
Scixelsyd Etinu
Old 19th October 2006, 11:53   #24 (permalink)
navin's Avatar
Originally Posted by hydrashok
or a sealed box joined to a ported box...
This is a 4th order bandpass. A 6th order bandpass is ported - ported.
I can see some of you logging oout and others crying "U-N-C-L-E". :-) Sorry if I digressed.
__________________
Scixelsyd Etinu
Old 19th October 2006, 12:18   #25 (permalink)
Bass&Trouble's Avatar
"U-N-C-L-E"... you forgot the poor surround! Or maybe when you say cone, you mean cone-surround assembly.
Also, worthy of being named separately would be the former.
__________________
Operator! Give me the number for 911!
Old 19th October 2006, 13:24   #26 (permalink)
navin's Avatar
Thanks B&T former and surround so that makes it 14 components. The physics still remain the same.
__________________
Scixelsyd Etinu
Old 19th October 2006, 13:47   #27 (permalink)
I still believe more power is ok but not double the power for a speaker in our cars, especially the stuff that sells in our markets are very entry level stuff and connecting a 600 RMS amp to a 300 RMS voice coil sub is dangerous and pushing it's luck no matter what enclosure is used.
B&T ? Navin ? Autophile ? Someone reply
Old 19th October 2006, 18:33   #28 (permalink)
prince85's Avatar
Are you by any chance referring to JBL Subs/Amps as entry level stuff???? coz we are discussing JBL equipment in this thread
prince85 is online now   Reply With Quote
Old 19th October 2006, 19:39   #29 (permalink)
Sam Kapasi's Avatar
lol no prince, you can lower those eyebrows hehehehe
Blueraven means to say that in India we sell more entry level equipment from higher end brands. Not to be confused with Sony et al. That is dysentery level stuff.
No, for example in the USA JBL sells mostly the GTi series, $1000 subwoofers and $5000 amplifiers.
__________________
Live the YetiLife®
Old 19th October 2006, 19:50   #30 (permalink)
redeye's Avatar
so guys if i choose the gto1201.1 amp would it be too much power .. i'm confused which one is the best for my sub woofer ... to perform at it's best..
Thread Tools
Choosing an amp for IDQ12V2 + worthy HU theEnd Ask the Gurus 17 12th October 2008 23:40
Help choosing smartphone... shad0ww Gadgets, Computers & Software 12 22nd May 2007 20:17
Choosing between Estilo & Santro ranarula Hatchbacks 26 24th April 2007 17:56
Please help me in choosing my first bike. cool.aquarian Motorbikes 18 6th November 2006 19:07
Need help with choosing a car in the US raihan Luxury, Imports & Niche 60 16th August 2005 07:14
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
