Thread Tools
Old 17th October 2006, 18:48   #1 (permalink)
redeye's Avatar
Question
Guys i need your help i have a sub woofer for which i'm confused to choose which amp to buy... can any one pls tell what should i look for while buying an amp..
my budget is 35k
THis is MY SUBWOOFER
GTO1204BP-D
Dual 12" Bandpass Enclosure
Specifications
  • Power Handling, RMS 600 Watts
  • Power Handling, Peak 1800 Watts
  • Sensitivity (2.83V @ 1m) 96dB
  • Frequency Response 30Hz - 150Hz
  • Impedance 2 Ohms
my choices right now are
The GTO601.1
Specifications
  • Power Output : 424 Watts RMS x 1 channel at 4 ohms and ≤ 1% THD + N
  • 580 watts RMS x 1 channel at 2 ohms, 14.4V supply and < 1% THD + N
  • Signal-to-Noise Ratio: 72dBA (reference 1 watt into 4 ohms)
  • Dynamic Power: 580 Watt at 4 ohms
  • Effective Damping Factor: 6.326 at 4 ohms
  • Frequency Response (~3dB): 10Hz - 302Hz
  • Maximum Input Signal: 5.3V
  • Maximum Sensitivity: 210mV
  • Output Regulation: .21dB at 4 ohms
  • Dimensions (W x H X D)
  • Main Unit: 15-1/8" x 12-15/16" x 2-3/8"
is amp enough to power the sub woofer at it's best...
my other choice is
The GTO1201.1
Specifications
  • 787 watts RMS x 1 channel at 4 ohms
  • 1114 watts RMS x 1 channel at 2 ohms, 14.4V
  • Variable cross-over.
  • Variable Bass Boost.
  • Speaker Level Input
  • Frequency Response (–3dB): 10Hz - 302Hz
  • Overload protection
  • Maximum Input Signal: 6.1V
  • Maximum Sensitivity: 140mV
  • Main Unit: 18-11/16" x 12-5/16" x 2-3/8"
pls suggest what to buy any other company amp also is ok
my budget is 35k
redeye is offline   Reply With Quote
Old 17th October 2006, 21:03   #2 (permalink)
rsjaurr's Avatar
redeye, GTO601.1 should be enough for you.
As u have asked for other brands i will also suggest u to have a look at audison,JL audio[slash series] and alpine amplifiers.
rsjaurr is offline   Reply With Quote
Old 17th October 2006, 21:13   #3 (permalink)
blueraven316's Avatar
Look at Rockford Fosgate too, their amps are simply kickass.
JL will cost you a lot more but its again very good and worth it.
Any good amp can be tuned to sound like the way you want, SPL/SQL
So if you are into a balance of SQL/SPL typo, then look at Power Series RF amps also, they churn out a lot more than rated power at times even 45 to 50 % more and will blow JBL counterparts to bits but at a premium of cost and a little difficult to find in Bangalore everywhere.
Your budget for just the amp is 35 or totally ?
Even Hifonics have an Amp the Brutus 606 which is kickass too and costs a lot less than any RF amp coming very close in performance.
blueraven316 is offline   Reply With Quote
Old 17th October 2006, 23:12   #4 (permalink)
redeye's Avatar
35k for amp only , and how do you choose i mean by specifications
should rms of sub woofer and the amp have to be close to each other
or
the watts of the amp should be near to the peak power watts of the sub woofer
Old 18th October 2006, 00:47   #5 (permalink)
RMS to RMS, I think your subs are Dual 4 Ohms subs, so Ideally you need to run them either at 4 Ohms or 1 Ohm, of which 4 Ohms is the better option.
Even if your subs are higher on RMS it's okay, but the amp shud not be run at a higher RMS rating than subs.
It's good if you can run the setup at 4 Ohms, tht way the amp runs cooler and more efficient and still churns out a good amount of power (if it's powerful), or find an amp that is 1 Ohm Stable,
Both JBL 601 and 1201 are not 1 Ohm Stable.
Old 18th October 2006, 00:52   #6 (permalink)
Sam Kapasi's Avatar
The GTO 1204-BPD is a bandpass box with 2 terminals on it. Each one is 4 ohms.
Both in parallel make 2 ohms.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 18th October 2006, 00:59   #7 (permalink)
aah, so the subs are single coil in there ??
Old 18th October 2006, 01:22   #8 (permalink)
hydrashok's Avatar
or
Well... from what I've heard, for best results (regardless of budget, of course) you should choose an amp with output wattage in the upper two-thirds of the sub's maximum output wattage. If you get an amp as powerful as this, you should be able to keep the output (from the amp) to the sub safe (and optimum for the sub) by keeping the gain settings on the amp at a safe level. A little experimentation with some good cds of your favourite music will be required for this. From your choice of sub (dual bandpass) I take it you are a rap & hip-hop guy, right? If I'm right, you will definitely need to keep the gains safe 'cause that kind of music will definitely keep the sub busy.
Am I wrong, gurus?
__________________
Coming soon: Balls of STEEL!
Old 18th October 2006, 01:32   #9 (permalink)
Sam Kapasi's Avatar
let me answer your question specifically since it is specific.
I have heard the 1204BPD. It needs atleast 601.1 to drive it. It bangs with the 601.1 but It sounds much better, louder deeper with a 1201.1 driving it.
Hope this helps
Dhoom Responsibly.
__________________
Live the YetiLife®
Old 18th October 2006, 06:10   #10 (permalink)
speedzak's Avatar
Congratulations!
That Bandpass you've got for yourself is a great beast and possibly you're the first owner in India.
Let me suggest you to get JBL 1201.1 amp for this. Another option is Alpine 1001 which will be hard to find. (I hear that Alpine has some pieces left with them, PM me for details) Anything less, you're unfair to those subs.
Get a good installer to get the job done.
__________________
The squeaking wheel doesn't always get the grease.
Sometimes it gets replaced!!
Old 18th October 2006, 09:20   #11 (permalink)
Sam Kapasi's Avatar
Originally Posted by speedzak
Congratulations!
Big Bassy Beast it is.. For sure. Here's the picture. It's got blue lights and all too lol
I don't know if he is the first owner though. I think the first purchased unit would be in New Delhi somewhere.
__________________
Live the YetiLife®
Old 18th October 2006, 10:07   #12 (permalink)
speedzak's Avatar
Gunbir should've thrown more light on this. But seems he is lost these days.
Sam, what's the best way to drag 2 ICEy Sardars back to this section?
The pic explains all. That's a big bassy beast for sure.
@Redeye. Which car have you chosen to plant this beast into?
__________________
Old 18th October 2006, 11:50   #13 (permalink)
Question
I am unable to understand this, the subs have a combined power of 600 RMS and what Sam said is have two input terminals 4 Ohms each, so in Parallel it's 2 Ohms and series (for which the enclosure has to be opened) it's 8 Ohms,
now the MRD1001 is a 1000 RMS @ 2 Ohms amp , which will smoke the subs in time even if the gain is kept low, the amp does not need the gain to be high either to throw out 1000 RMS, and I have seen many installs with that amp and INDEED its a beast, so how does a 600 RMS pair of subs match a 1000 or a 1200 RMS amp ??
Old 18th October 2006, 18:58   #14 (permalink)
blueraven... its the otherway around!!...
if you underpower, you have higher chances of smoking ur sub....
by underpowering means.... you have 600RMS sub and ur amp is only say....400RMS or so.... this means that... you can drive amp into clipping!!... by clipping , you are actually suppling more power to sub...(you need to google and see the graph for power supplied when an amp is clipped to understand better)... This way, its possible that you can fry the voice coil of the sub...(in prolonged clipping)... also its very hard to make out when the amp is clipping..
whereas, in the other case, if you carefully adjust the gains.... you are safe..... like hydrashok has said.. only upper 2/3rd.... that if you have 600 RMS sub, you can safely attach 1000 RMS amp to it..
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 18th October 2006, 19:23   #15 (permalink)
rsjaurr's Avatar
oh.....i take my words back as i thought u have bought single sub but this beast has two subs in it,so u would need 1201.1 amp and not 600.1.
BTW is 600wrms is combined power of spk or its individual's?
Thread Tools
Help choosing smartphone... shad0ww Gadgets, Computers & Software 12 22nd May 2007 19:17
Choosing between Estilo & Santro ranarula Hatchbacks 26 24th April 2007 16:56
Please help me in choosing my first bike. cool.aquarian Motorbikes 18 6th November 2006 18:07
Choosing the right dealership luvjascha Indian Car Dealerships 10 14th September 2006 18:11
help on choosing speakers kallil Ask the Gurus 25 5th August 2005 14:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
