| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Oct 2006 Location: New Delhi
| Hi forum, After much reading and asking question on the forum and off it, Bought a new maruti baleno (Lxi) on the 16th of Nov' 06. Also when it came to the ICE turmed back to the ever helpful and always present TEAM- BHP after going through the various threads and excercising my knowledge.. Now the current situation is: A brand new baleno Lxi HU: Alpine 9846E Speakers Front: JBL CS2165 Rear: JBL GTO937 Now I am not a loud buff but someone who will love music from Panthera to the vivaldi 4 seasons to bollywood.. I just want to add an amp for some added crispness of sound. I need assistance from the gurus of mobile sound to suggest "should I go for a 2 channel or a 4 channel amp" and then which brand should I go for with the current setup in mind. Also how much will it cost me to buy it and any other suggestions, they are more than welcome...
__________________ Speedme _______________________ Live Free Die well..... |
| | #2 (permalink) |
| BHPian Join Date: Sep 2005 Location: Batala
| congrates on buying new car!! It all depends on ur budget but ideally,u should go for 4-ch over 2-ch amp as u can power all spk from single amp and moreover later if u need to add sub,u can use 2 channels of amp to power that sub and feed rear spk from HU's internal amp. Cheapest 4-ch amp would be sony for abt 5k.next real VFM is pio6100 for 7k but w/o B&W and then Kicker,JBL50.4,75.4,alpine and audison etc. U will also need amp kit+spk wire as well.here u can buy china made amp kit for 500-800 which we dont recommend,kicker,JBL,audison. Do tell us ur budget to get bit more specific answer. ![]() |
| | #3 (permalink) |
| Senior - BHPian Join Date: Oct 2005 Location: Morbi - Gujarat
| As already suggested by Rsj, you should have to go for 4 channel amp so later when you want to add sub you can use 2 ch for sub and 2 ch for front. What is your budget ? if you are looking for value for money than you have to buy either Pioneer 6100 4 ch or 6200 4 ch amp. other options are JBL,audiobahn. Mugen_Power. |
| | #4 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | How many preouts does your HU have? If it's more than 1, close your eyes and get a 4channel amp. How much is your budget for this amp?
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( |
| | #5 (permalink) |
| Thanks guys, My HU is with 1 preout and the following specs
Also have learnt a lot about the importance of good wiring from the forum. As far as the Sub is concerned not sure if I ever will go for it. Hopefuly now you can help me better. Again thanks a lot guys for the help.
__________________ Speedme _______________________ Live Free Die well..... Last edited by Speedme : 8th December 2006 at 13:46. |
| | #7 (permalink) |
| Senior - BHPian | With only 1 pre-out, your options are a bit limited as far as flexibility is concerned. 1 pre-out + subwoofer level control means that that pre-out is actually meant as a sub-out. Option 1 You can use this preout for a 4-channel amp that accepts one input for all 4 output channels (most do). Ideally this amp should have a pre-out too, so you can give that output to another amp in a daisy-chain fashion if you feel the need for a sub later. (My old Kenwood Amp KAC-848 I think had both options). The problem with this setup is that you will not be able to fade the output between front and back from your HU. The fading will have to be controlled with the gains settings on the amp. Option 2 You can get an amp that takes speaker-level inputs. Your speaker wires will act as the inputs for the amp. There will be a small hit in sound quality, but you will be able to use the fader function in your HU, and you will be able to use the sub-out in your HU for another amp for a sub if you plan one later. And, you will be able to control the sub-level from the HU too. (My old KAC-848 had this speaker-level input option too). Did you mention that you are ready to spend 7K for the wiring alone, or that you are ready to spend 7K for the wiring and the Amp? If it is the second (I hate saying latter), unless you go for real cheap options, it will not work out. Wiring: You will be able to an Audison Power cable set (FPK300 - Rs 3500/-) and RCA set (FT2600 - Rs 1000/-). This is the best option. A little costly, but it will last as long as the car, and give you very good output. Amp: A good 4-ch amp will run to at least 8K. We don't recommend the cheaper Sony amps. The JBL CS60.4 is a very good amp. It will come to 9000/-, but it is good value for money, and it will go very well with your alrealy JBL speaker setup.
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #8 (permalink) |
| Senior - BHPian | budget? can I quote an option with a new HU? ![]() dont forget that adding an amp means you would need to spend decent money on installation...2k or so. and, do get 4 channel the Pio as navin said as it can mix 2 4 channel out even with a pair of inputs.
__________________ -__- |
| | #9 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
JK, what ever happened to the intall with the Rs. 1L amp.
__________________ Scixelsyd Etinu | |
| | #11 (permalink) |
| Hey JK whatz the gig with Rs. 1L amp (the one naveen is talking about) Does such a beast exist??? Well i guess I should opt for a 4 Channel pio or a Blau, Since the reviews are not in favour of Sony so will elude the same from my search. Then I can power all 4 speakers from a single amp, and if some day that is one day i feel the need for an Sub then I can power the rear GTO937's from the HU and the sub can be power happy... On one of the threads by revtech, Sam has said in regard to the availability of a 10" bass tube by JBL... Maybe some time will go with that. Hey Naveen, The pio still do the job for it...
| | #12 (permalink) | |
| Team-BHP Support ![]() | Quote:
Read more about it here http://www.team-bhp.com/forum/244258-post203.html (2 Subs - Dual Mono or Stereo - "Kb ka dB")
__________________ The Holy Trinity: Traction, Torque and Tarmac | |
| Thread Tools | |
Similar Threads | ||||
| ICE Setup in my Baleno | shadyrulez | Sound Off and Show Off | 14 | 31st December 2007 07:42 |
| hi to all guru's - Q on adding a Subwoofer to existing setup | ajji | Ask the Gurus | 8 | 6th July 2007 13:29 |
| Help for adding speakers to an existing ice setup | shrayv | Ask the Gurus | 3 | 20th June 2007 23:56 |
| What abt this setup?? For My Baleno | mega5918 | Ask the Gurus | 26 | 13th January 2007 11:52 |
| Which sub/amp to add to existing system? | sidharth_j | Ask the Gurus | 52 | 25th May 2006 18:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
