| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | hi, im planning to build a sub enclosure for my pio subs. i have 2 304c 12" and im planning to use 2 seperate enclosures for it. plese advice on the specs of the enclosure(box volume, vent dia, vent length and dimensions if you can).or should i use a sealed enclosure? i have a hyundai accent crdi and i dont care much about the boot space. i like low freq bass. please reply as soon as possible. in future i might buy 2 pio 306dvc. can both the subs use the same enclosure. never mind if it cant. ill build a new one then. currently my subs work best on 50 hz and above. i used my laptop with winisd sgnal generator.connected it to my amp. i have a x944 pio. i wanna go lower much lower if possible |
| | #2 (permalink) |
| Distinguished - BHPian ![]() | Clipto, to determine any subwoofer enclosure, you need a set of data about the woofer, called the T-S parameters (Stands for theile-small) Once you have these parameters, there are a host of box calculating software (mostly free) that will give you exactly what you want. I say, go online, find these parameters, get a box calculating software and do it yourself!! Forget these silly gurus, it will be most fun to do it that way ![]()
__________________ Live the YetiLife® |
| | #3 (permalink) |
| Senior - BHPian | Here you go for the t-s parameters... ![]() I would say go for a bit large enclousre like 1.5 - 1.6 cu ft and it will decrease the qtc and the low freq which you require will increase.... dont go for ported as the sealed enclosre can reporduce the low end efficently than the ported ones.... here is a link for calculating the internal volume of the box... Woofer Enclosures - Fraction to Decimal - Parallel - Series - Port Length and Volume Calculators Last edited by low_bass_makker : 28th December 2006 at 18:57. |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Yes 1.5 cu. ft. selaed seems about the minimum. However if you need a smaller box you can always use an aperidic vent to reduce the Qtc (Q of woofer in box).
__________________ Scixelsyd Etinu |
| | #9 (permalink) |
| I am solely becuase almost all of us want to stuff big subs in small boxes. I find in many cases the AP vent is nicer on the ear than electronic Q control. Then again you can AP vent everything (you might as well go for Open Baffle if you do). An AP vent can help if the Qtc is between 0.7 and 1.0 and can drop that to a less boomy level. Sam you are right, I should explain Qtc. Clipto. a) if you have 2 subs you need twice the volume. What you can do though is build a 2.5-3 cu. ft. box if that will fit and then you can put one sub in and add a second later (with the AP vent mentioned above). b) A speaker has electrical (primarily related to the voice coil) and mechanical (primarily related to the suspension and cone mass) characteristics. These are known as Qms and Qes (m for mechanical). Since the woofer is not in a box these numbers are taken in "free-air" or without a box. see pic below. Qes and Qms are often combined to give Qts (t for total). ![]() Once the speaker is in a box the mass behind the speaker changes and hence the Qts changes and this is known as Qtc. Hope this helps.
__________________ Scixelsyd Etinu Last edited by navin : 30th December 2006 at 13:04. |
| | #10 (permalink) |
| The pic above is not how we meausre Qts (these drives are being "run in") it was just to show drivers in "free-air". And if anyone recognises the make/model of these drivers I'll send them a cigar!
| | #11 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | I see some Scanspeak in there... and possibly some Aurasound... not sure though... I could be totally off... cant see much
__________________ Often imitated, never duplicated! |
| | #12 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | Quote:
but gunnu doesnt smoke.... ![]()
__________________ SINGH IS KINNNNNNNG.. | |
| | #13 (permalink) |
| BHPian | Quote: i just installed my new enclosures in my car. each one is a 56 litre box with 3.75 dia vent about 8-9 inches long. its not finished yet but they have come out to be huge. and thank god they are cause i mistook my subs model no. its 304f not c its the free air one. i connected the to myy 944 bridged. man they are rocking like hell. i knew there was some problem with my earlier enclosure. the installation guys here take you for a ride man. they make the box accordin to your car and not the sub. was really pi$$** with it. i tried three different cars as i thought there was something to do with car acoustis. i tried it in my octy(my car got stolen thank god i removed my system). then in my palio(it got totalled hehe) then fiesta and now accent. its like improvement of around 200% and im not kidding really. il post pictures when i get time. Happy New Year to All you BHPians and The Audio Gurus. i Have a suggestion which ill post a little later got to go now. Thanks ![]() |
| | #15 (permalink) | |
| Quote:
BTW, You seem to have awful luck (one car stolen, another totalled) and great sprit to still be wishing us a Happy New Year. Hope 2007 is not as "exciting".
__________________ Scixelsyd Etinu | |
« need an equlizer
Need some input on reducing rattling noise in the rear due to the oval speakers »
| Thread Tools | |
Similar Threads | ||||
| Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! | Sam Kapasi | Ask the Gurus | 8960 | 18th November 2008 22:24 |
| Advice from Gurus - More thump from Sub | manojgautham | Ask the Gurus | 16 | 5th September 2008 11:04 |
| Audio Gurus: Help Needed | Praneet71 | Ask the Gurus | 12 | 7th August 2007 12:04 |
| A request to all the audio gurus .. Can this be repaired ?? | mclaren1885 | Ask the Gurus | 38 | 13th July 2006 14:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
