| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #77 (permalink) |
| BHPian Join Date: Feb 2008 Location: Chennai
| I was thinking of going for the JBL1004 amp running the Electra 6.1's up front and a JBL 12" sub with the rear channels bridged. The 6.1's had a rms rating of 70watts@4ohms and the 1004 pumps 100w rms@4ohms and it was kind of matched. But the electra 5.1 can handle only 50w rms @4ohms and the amp might be an overkill for those speakers, but perfect for the subs. So what do i do?? look for another amp or go for the 1004?
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown |
| | #78 (permalink) | |
| Senior - BHPian | Quote:
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | |
| | #79 (permalink) | ||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
If you are willing to not perform the abovementioned experiment, then dont worry about the power matching. ![]() P.S. Even the 4.1 can also take the full output of the 75.4/ 1004 with program material and high pass of 80-100 Hz.
__________________ Operator! Give me the number for 911! | ||
| | #80 (permalink) | |
| Quote:
One more question, what's the relation between the rms output and the gain of an amp?? is it like at max gain the amp will push out the specified rms??
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown | |
| | #82 (permalink) | ||
| Quote:
So, if you connect a 6V pre-out head unit to the amp, leave the gain in the minimum position (i.e 6V on the dial), and when you turn the head unit's volume control to max (head unit is now "outputting" full pre-out voltage), the amp will (ideally) deliver maximum unclipped power. But if the pre-out voltage from the head unit is lower than 6V - say 4V, you turn the gain knob clockwise to 4V so that the amp increases its gain to compensate for the lower input it receives. Not to put out more power. But to put out same maximum power at this head unit's full volume.
| | #83 (permalink) | |
| Quote:
supposing that the HU gives out 4v pre-outs, and we set the gain to a much lower voltage in the amp, say 1v(or even less), then will the amp try to push more power, thereby heating itself and killing the speakers?? and also clipping the sound??
| | #84 (permalink) | |
| Quote:
No answer to my earlier post??
| | #85 (permalink) | ||
| Quote:
| | #86 (permalink) | ||
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Approximately correct - depends on the amp rating and the impedance of load connected Yes and no. Depends on the make of amplifier. For example, if an amp makes bad music, giving it a higher HU output might make matters worse. Quote:
* The absolute power rating of the amp * The sensitivity and power rating of the speakers * The 'loudness' demanded - HU volume, and loudness of the music being played
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #87 (permalink) | ||
| Quote:
1.front components and sub running from a 4-ch amp, rear co-axes off the HU 2.front components and the rear co-axes running from a 4-ch amp. no sub. how many pre-outs are required for both these setups?
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown | ||
| | #89 (permalink) | |
| Quote:
2 L+R pairs!
| | #90 (permalink) | ||
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Help for Audio System for Fiesta | 911er | Ask the Gurus | 2 | 23rd October 2008 21:59 |
| Ford Fiesta 1.4D ZXi Ownership Woes. EDIT : REPLACEMENT FIESTA. Pics on Pg. 5 | Mad Monkey | Long-Term Ownership Reviews | 89 | 16th August 2008 01:42 |
| New Ford Fiesta 2008 | amit | The International Automotive Scene | 16 | 30th June 2008 19:07 |
| Ford Fiesta 1.4? | superamerica | Sedans | 3 | 7th July 2006 14:47 |
| Its Come - New Ford Fiesta | lamborghini | The Indian Car Scene!! | 17 | 18th February 2006 17:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
I thought the 6.1 came for that price.
