Thread Tools
Old 11th January 2007, 14:39   #1 (permalink)
mobike008's Avatar
Question Battery Effect due to ICE Usage
I drive a viva crdi and have the following ICE set-up
Pio 6850
Sony 4-Channel Amp
Pio Sub-Woofer
Blaunpunkt Front Comps
JBL Rear co-axials
My question is can i play my music even if my engine is switched off? I mean will this drain the battery or something?
Is it different for a petrol engine against a diesel one?
Please advice
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 11th January 2007, 14:49   #2 (permalink)
hydrashok's Avatar
Better not play music with the engine off. You have an amp and a sub. That is reason enough. Extended sessions will drain the battery. Short sessions (5 minutes or so) may not cause as much harm, but why take the risk?
I never use my ICE with the engine off -- not even for a minute. And now I've got into the habit of switching off my HU before turning the engine off, so starting the engine later will not strain the battery, with 2 amps and a HU to power-up along with the engine. I have a 1.2 (Petrol) Palio, by the way.
I'm not sure if a diesel car will behave differently.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 11th January 2007, 15:18   #3 (permalink)
navin's Avatar
My wife's car has 2 amps (a Blau velocity 504 and a PA275) she has run her system for about 5-10 minutes with the car off without a problem but any extended session would drain the battery to the level where there wont be enough cranking amps to start your car.
__________________
Scixelsyd Etinu
Old 11th January 2007, 15:30   #4 (permalink)
vikram_d's Avatar
I have a 6850 also. I use its inbuilt volt meter when I use the system witht he engine off. I use it max till about 12.1V remaining. Have never faced a problem.
__________________
She's back.
vikram_d is online now   Reply With Quote
Old 11th January 2007, 15:39   #5 (permalink)
tsk1979's Avatar
Get a battery with higher Ah.
For example if your car needs a 55Ah battery, get one which is rated at 65Ah. This should take care of medium length sessions.
__________________
Reclaiming.....!
Old 11th January 2007, 15:44   #6 (permalink)
jkdas's Avatar
check this thread
http://www.team-bhp.com/forum/car-en...much-load.html
__________________
-__-
Old 11th January 2007, 15:59   #7 (permalink)
mobike008's Avatar
Thumbs up Thank You
Thanks a bunch folks, Since mine is a new car, dont intend to change the batter just for the sake of music.
I reckon will stick to music on the move
I got my answer. Mods, Kindly do the needful
__________________
Old 11th January 2007, 16:03   #8 (permalink)
Sam Kapasi's Avatar
At low volumes, i think you can easily run for about half an hour with no trouble. At higher volumes i'd say 15 minutes.
But be careful. Imagine the scenario.
You're with your lady, sitting by the sea, whispering sweet nothings. You play soft romantic music to get her into the mood. And it's your lucky day. The lips meet, the hands explore. The sweetest time flies by accompanied by beautiful songs.
Then it's late and she has to go home. And your car doesnt start and she can't steer, so you ask her to push. There goes love, down the toilet. Better to start your car and play music.
__________________
Live the YetiLife®
Old 11th January 2007, 16:08   #9 (permalink)
mobike008's Avatar
Thanks Sam-bang on target, thats exactly i am afraid of
__________________
Old 11th January 2007, 16:22   #10 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
Default Never try this in your car
And you get her all panting by the wrong means. LOL. sam, you are a riot.
i have used/been using my ICE for extended periods, say 80-120mins with the engine off. so far sam's scenario has not happened to me. but i would not recommend anyone to try this & curse me for giving false ideas.
BTW, i have a DVD player, amp, sub, LCD screen all running at that time & my battery is DIng Dong Amaron. I guess it also depends on the car's running & the battery condition also. If you are driving for extended periods in the night, then your battery is not at full charge, in a petrol engine scenario. On the other hand, if you drive extensively during the day, then your battery is in top charge, just like sam is when he sits in his car under the moonlight.
__________________
Goodbye Dada, you made us proud.
Old 11th January 2007, 16:58   #11 (permalink)
tsk1979's Avatar
Battery should have top charge even with headlights and AC on. I have driven 8 hours at night with Headlights(130/110W), AC and ICE system(mp3 player at medium volume).
Check the voltage at your battery terminals with Lights and AC on, if it falls below 12.5 there is trouble brewing with your alternator.
__________________
Reclaiming.....!
Old 11th January 2007, 17:07   #12 (permalink)
@tsk1979...it will charge, but there will be moments when you are stuck in the traffic with the headlights & AC on, there will be a discharge in petrol engines.
__________________
Old 11th January 2007, 21:00   #13 (permalink)
Bass&Trouble's Avatar
Asking is one thing, and happening is another. Faced with such a request, the only thing mine would push is me.. down a cliff.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 11th January 2007, 23:57   #14 (permalink)
tsk1979's Avatar
In my indica diesel even at idle with headlights and AC on it stays above 12, in the 12.5 range. So battery is always charging.
__________________
Reclaiming.....!
Old 12th January 2007, 00:11   #15 (permalink)
in idle with ac & headlights on, the ideal position is being neutral, else the battery could get screwed up. i really dont know much about diesels. i had a 118 with nissan diesel engine & it had absolutely no battery hassles, basically because the diesels do not require the battery power when the engine is running, but the petrols always require battery power
__________________
Thread Tools
OEM car battery life - How long did your OE battery last? shuvc Technical Stuff 142 10th October 2008 01:27
ICE & Battery / Power issues s0uljah Ask the Gurus 38 21st September 2008 00:17
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 20:56
Battery consumption due to security system paish Modifications & Accessories 16 20th March 2008 12:42
Effect Of Budget 2008 on ICE prices!! amit_mechengg Ask the Gurus 6 3rd March 2008 13:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
