| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #136 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
There is no such correlation between 'woofers and basstubes'. In fact, I find it rather inappropriate to describe bass as punchy. It's a very vague term. As for vibrations, all sound is vibrations. And for good bass, it is necessary that only the woofer cone be vibrating and nothing else. Bass tubes are as diverse as subwoofer drivers themselves. The only common thing is that almost all of them are ported, cylinder-shaped enclosures.
__________________ Operator! Give me the number for 911! | |
| | #138 (permalink) |
| Distinguished - BHPian ![]() | Thats a million dollar question my friend. And no one here will have that answer simply because it depends on your tastes. If you like boomy bass with lots of reverberations then the bass tube. The subwoofer will give a tighter bass.
__________________ \ / ][ |) `/ [_] "!" (\./) (o.o) ( X ) This is Bunny. Copy Bunny into your signature to help him achieve world domination. |
| | #139 (permalink) |
| Distinguished - BHPian ![]() | This is ALL WRONG (in the glossary section too) Listen up man - A tube is a subwoofer. A subwoofer is sold in the open market in 2 ways - As a driver - This can be either used while making your own custom enclosure, or in a Infinite Baffle (tray mount) application As an Enclosure - where the company makes the enclosure (box) and sells you the entire unit. Enclosues can be Sealed, ported, bandpass or tube type. All sounding different.
__________________ Live the YetiLife® MA-DONNA! MA-DONNA! MA-DONNA! |
| | #140 (permalink) |
| Distinguished - BHPian ![]() | Yup Sam I was just trying to make it simple. Both are subwoofers with different constructions. I wasnt clear in my choice of words and didnt want to go too much into details of construction. Sorry.
| | #141 (permalink) |
| BHPian Join Date: Mar 2006 Location: Bangalore
| Hi, I need some clarity on Coaxials vs Components. My understanding so far - 1) Coaxial consists of a midrange/woofer with a tweeter placed over the cone 2) Components consist of midrage/woofer speaker and a discrete tweeter along with a crossover component to split the frequencies. My doubts 1) One of my friend had JBL GTO607 (Component) in the front and JBL GTO637 (Coax) in the rear both powered by HU on Swift. I tried listening to the front pair and rear pair of speakers seperately by adjusting the balance between front and rear. Components (Front) - the midrange and high frequency sound being clearly reproduced but the low frequency range was totally missing. Coax (Rear) - though the highfrequency wasnt crisp, on the whole it did well because it seemed to reproduce low frequency (bass) better than the components Is it that the Coax does better in low frequency than Components? 2) If I'm not planning to install Subwoofers, how will all 4 coax or all 4 components sound for example, in Skoda Laura, all doors have tweeters, midrage and a third speaker (may be ones that produce low freq sound). 3) Will adding a JBL 60.4 add punch to an existing HU powered sub ? Will the 6in speakers be ready for the extra power and performance ? Vishnu |
| | #142 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| I would suspect that the Component should produce better defined bass than the coax. I dont know what you heard in the Swift but I would check if both front speakers have been wired in phase. Or maybe it is just a characterisitc of the JBL 607/637. Also if the highs are not very detailed the balance shifts towards the lows so the speaker can sound like it is producing more bass. The Laura is a large car. it would be advisable to use 3 way components designed for it's door. You cant power a Sub properly with any HU. An amp is almost mandatory, not optional.
__________________ Scixelsyd Etinu Last edited by Rudra Sen : 13th February 2007 at 19:25. |
| | #143 (permalink) |
| Senior - BHPian | Wouldn't the co-axial with a bigger cone be able to produce lower frequencies better than the 6 inch component one ?
__________________ "can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?" The Bean effect on my 4 year old |
| | #144 (permalink) |
| Distinguished - BHPian ![]() | To answer your questions: 1. The coaxials were kept in the boot so they had a large air volume assuming they were on a plank. This would produce larger bass. The components on the other hand kept on the front door with almost no enclosure volume hence perceived as lower bass. Also you may want to check the speaker polarities in the front as lack of bass element may also be due to inverted polarities. 2. 4 6" components will sound good in the laura. All can be placed in the stock door position. the laura takes 3 way components i think. 3. If you amp these with the 60.4 they will sound much better as they will now be recieving the power they need to drive them. A HU normally has only 10-20w rms whereas the amp will give 60w to each speaker. The speakers generally are of 80w rms. But even if you put 4 compos there is no substitute to a sub. A sub will provide the low frequencies whereas the compos only provide midbass. edit: esteem_lover: a 6X9 will provide lower bass than the 6" compos. this is because the 6X9 has a larger cone area.
__________________ \ / ][ |) `/ [_] "!" (\./) (o.o) ( X ) This is Bunny. Copy Bunny into your signature to help him achieve world domination. Last edited by vid6639 : 13th February 2007 at 14:37. |
| | #145 (permalink) |
| BHPian | One related question- people always vouch for components over coaxials for better sound quality. They are also priced reasonably higher as compared to similar coaxials. Can experts please explain justification behind this? What I have found so far is that components can provide more direct paths for sound to listening positions, thereby reducing obstacles/reflections for high frequencies. Are there any other advantages too, or is it the ONLY reason? (If the later is true, then I would assume that the sound improvement obtained by mounting tweeters at higher locations like pillars or panels behind ORVMs rather than coaxials which usually go inside doors or parcel tray, must be quite significant.... can it be confirmed?) |
| | #146 (permalink) |
| Senior - BHPian | newbies please browse around before starting a new thread or use Search function navin , could you please merge this thread to the old one... http://www.team-bhp.com/forum/car-en...inology-9.html
__________________ "She may not look like much, but she's got it where it counts, kid." |
| | #147 (permalink) | |
| Senior - BHPian | Quote:
![]() Also take into consideration the dedicated crossover in component sets that assist in tweaking your sound. Oh and let the vet's and guru's do the actual explaining, I just thought Id add my 0.02ps while we wait ![]()
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson | |
| | #148 (permalink) | |
| Quote:
However, some manufacturers will choose to water down the coaxial versions of the line, and will use w-cone tweeters for the coaxes while the comps use edge driven domes, and will not supply a crossover for the coaxes etc. In such a format, there is bound to be a huge difference in both sound and price. This is common in entry to lower mid level lines. Sometimes, it is also a manufacturing limitation. The dome tweeter is too deep to be accomodated above the cone without having a very high tweeter post, if driver is a shallow chassis based one (mostly the case with entry level lines). You are spot on about the direct path thing also. But that does not mean any cost addition for the manufacturer. ![]()
__________________ Operator! Give me the number for 911! Last edited by Bass&Trouble : 13th February 2007 at 18:51. | |
| | #149 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| JBL comps definitely produce better output than coax....ditto for 3 other brands that i heard. but in my case, I could harly hear the front comps playing beacuse of sound imaging (I think)....time to contact Gunman I guess!!
__________________ SINGH IS KINNNNNNNG.. |
| | #150 (permalink) | |
| Quote:
I just did not understand "harly hear the front comps playing beacuse of sound imaging". P.S. I was looking forward to meet you at the Delhi meAt. You were described to me as an enticing piece of female undergarment. gr8guzzler (serial kisser of mumbailand, and the other cheap guest) and I tossed (not that tossed) to decide which one of us would hit on you, and I had actually won. ![]()
__________________ Operator! Give me the number for 911! Last edited by Bass&Trouble : 13th February 2007 at 19:22. | |
| Thread Tools | |
Similar Threads | ||||
| iS my ICE OK? | sandyrocks | Ask the Gurus | 11 | 27th November 2007 11:58 |
| ICE - Santro | Vino_David | Ask the Gurus | 15 | 7th September 2007 10:09 |
| Ice!!! | vivekiny2k | Ask the Gurus | 15 | 14th August 2007 16:58 |
| Need your help on ICE....Please!!! | shiv | Ask the Gurus | 3 | 4th May 2007 20:51 |
| Car Glossary needed on Team-Bhp | navdeep | Technical Stuff | 6 | 8th March 2007 09:05 |
