Thread Tools
Old 26th February 2007, 12:15   #166 (permalink)
navin's Avatar
Originally Posted by Sam Kapasi View Post
That is simply because the Pioneer head units use MOSFET transistors in the little power amps inside the HU. That's it guys. No more, no less.
...and that dont make them better amps. In many ways I prefer some BJTs to many MOSFETs but I'm told I have strage taste and stranger tendencies (read as DIY).
__________________
Scixelsyd Etinu
Old 23rd March 2007, 14:51   #167 (permalink)
nura's Avatar
What does the term baffle in the following sentence from a BHP post mean? The front speaker enclosure in the Santro has no baffle.
__________________
Every man has his follies.
And often they are the most interesting things he has!
nura is offline   Reply With Quote
Old 24th April 2007, 06:09   #168 (permalink)
mithun's Avatar
In Pioneer DEH-P7950UB, I've found the following features. Can someone please explain the following nomenclatures and their specific uses ?
1. Rotary Commander
2. Direct Sub Drive
3. BMX (Bitmetric Equalizer)
4. Spectrum analyzer
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 24th April 2007, 09:22   #169 (permalink)
vid6639's Avatar
1. Rotary commander: It's the round knob used on the player to control all the features. With this round commander you can navigate through all the menus in the player. you can turn the knob, or push it in, press it to the right, left, up or down like a joy stick.
2. Direct Sub drive: A few of the pioneers advertise their capability to drive a sub directly through the HU. Although the sound will leave you wanting for an amp. It is not advisable as the HU will not be able to give sufficient power to the sub.
3. BMX: It is an equalizer setting which allows you to modify the frequency response curve. You can adjust the bass, treble frequency points.
4. Spectrum analyser: Just shows you the frequency bands and how they are adjusted. Basically a display effect.
__________________
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 24th April 2007, 10:28   #170 (permalink)
vid6639's Avatar
One correction. I got confused between EQ-EX and BMX. BMX is just a correction for MP3's. since there is a loss of some frequencies in MP3, BMX corrects it by increasing the level of frequncies.
__________________
Old 24th April 2007, 11:22   #171 (permalink)
low_bass_makker's Avatar
also the BMX is a alpine thing and the EQ-EX is a pioneer thing.......both the things are a total waste and should be disabled every time as they are just loundness function with a different name......
Old 24th April 2007, 11:49   #172 (permalink)
vid6639's Avatar
nahin yaar L_B_M BMX is there in pioneer as well. 5750, 6750, 7750, all had it. not sure about newer ones.
__________________
Old 24th April 2007, 13:14   #173 (permalink)
my bad I got confused with MX which is the alpine standard...ya you are correct the BMX is in pioneer also......thanks man.....
Old 28th April 2007, 07:37   #174 (permalink)
mithun's Avatar
Does BMX "really" provide any noticeable difference in the audio quality of the MP3's since I couldn't detect any difference with my co-axials ?
OR is it just a waste as mentioned by LBM ?
__________________
Old 28th April 2007, 12:15   #175 (permalink)
vid6639's Avatar
Well it does bring about a little difference. But now almost all the systems from pio have the BMX. It's not a deciding factor but you can play around with it.
__________________
Old 28th April 2007, 12:31   #176 (permalink)
I think you have connected your speakers with the HU.....now even if you enabled the BMX the HU amp has not got enough juice that one can feel the differnce in increase of lower freq....but you can surely feel the gain in higher freq that also not so major as the coaxial cannot reproduce them much.....
and like VID said is it not a deciding factor for getting the HU.....
Old 3rd May 2007, 00:18   #177 (permalink)
s0uljah's Avatar
Thumbs up
Baffle - usually a soft material (foam, thin ply etc) that is used while mounting a speaker to the door. It serves to protect the speaker from dirt/rust/dust/water etc as well as keeping the woofer tightly in place.
__________________
"Its not the size, its the heart, so dont hate... Accelerate !!!"
Old 3rd May 2007, 01:13   #178 (permalink)
I hate this is not the meaning of baffle in the previous post....the term in context there is the mounting place of the speaker......or we can say the mounting plate.....like when we mount the sub in the rear deck it is termed as infinite BAFFLE.....here infinte as the sub is opened in the boot and it a very big enclosure.....thats why infinte....and baffle is the mounting on the deck.....hope this clears the doubt......
the baffle you are confused is to protect the driver as you mentioned but it is acoustically transparent......
Old 3rd May 2007, 01:15   #179 (permalink)
s0uljah's Avatar
I guess I had not read his post completely and missed the santro part... anyway one more addition to the glossary!!
__________________
Old 3rd May 2007, 13:13   #180 (permalink)
navin's Avatar
........like when we mount the sub in the rear deck it is termed as infinite BAFFLE...the baffle you are confused is to protect the driver as you mentioned but it is acoustically transparent......
IB means that the sub is in an enclosure that is so huge it might was well be infinite.
What you guys are refering to is the GRILL. The problem with the stock front speaker location in the santro is that the grill/baffle combo hangs down (it is moulded but it looks like it is hanging) from the dash this means that atleast once side of the grill/baffle is not closed. This means that there is a certain ammount of bass cancelation.
The GRILL in in front of the speaker and protects the speaker from prying fingers and the baffle is what he speaker is mounted on. In the Santro the grill acts like a baffle as the speaker is mounted behind it and directly to it. Very shoddy i you ask me.
__________________
Scixelsyd Etinu
Thread Tools
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever Ask the Gurus 18 25th October 2008 01:39
iS my ICE OK? sandyrocks Ask the Gurus 11 27th November 2007 12:58
Ice!!! vivekiny2k Ask the Gurus 15 14th August 2007 17:58
Need your help on ICE....Please!!! shiv Ask the Gurus 3 4th May 2007 21:51
Car Glossary needed on Team-Bhp navdeep Technical Stuff 6 8th March 2007 10:05
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
