| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #196 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
__________________ Scixelsyd Etinu | |
| | #197 (permalink) |
| BHPian Join Date: Mar 2006 Location: Bangalore
| Hi. I am a little confused on the pre-outs on a HU. Can you please clarify. What can 2 or 3 pre-outs do? Not the definition but if you can also mention the use in a simple setup: 2 pre-out > 2/4 channel amp > can 2 amps be connected > how many pairs of speakers/sub can be powered 3 pre-out > 2/4 channel amp > can 2 amps be connected > I assume 2 pairs of speakers and a sub can be powered |
| | #198 (permalink) | |
| Quote:
3 pre out - front, rear and sub controls.
| | #199 (permalink) | |
| BHPian Join Date: Jan 2007 Location: delhi
| Quote:
2 pre-outs allow you to separately control the front speakers and the rear speakers, or the front speakers and subwoofer (where subwoofer is connected to the rear) (you can use the hi-pass low-pass settings on the external amp and get good results with this HU) in a 3 pre-out head unit, the 3rd pre-out is usually a dedicated subwoofer output. this is better if you want to have a four speaker amplified setup with speakers in front and rear, and a separate subwoofer. it allows you more flexibility with a direct control of the subwoofer volume and in many good HUs will have a low pass crossover in the head unit itself. you can use one pre-out for one amp. you can use two pre-outs for one 4 channel amp for front and rear speakers, or any one pair of speakers and one subwoofer. you can use 3 pre-outs on a 6 channel amp or a 4 channel amp and one mono amp. or even directly use the 3rd pre-out for subwoofer in a 4 channel amp and one of the any other two pre-outs for front or rear speakers. regards number of amps being able to use... there are advanced setups which use one mono amp for one channel - say left, another mono amp for another channel - right - so 2 amps for only one pre-out. and two more for the 2nd pre-out for subwoofers. :-) hope this helped.
__________________ life is a song! | |
| | #200 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| I have a couple of questions: 1. What does an MDF board look like? Can someone please post a pic? 2. Is it wooden/fibre/plastic? 3. What are its advantages over factory fitted rear parcel tray? 4. An installer once told me that MDF (wooden) tray is not good because if it is not hinged properly, it makes terrible rattling noises when going over potholes/speedbreakes. Is that true? 5. When fitting the front speakers in doors, is it advisable to retain the speaker grill? I know some installers prefer to do away with grill and instead utilize the factory provided door speaker grill. Isnt that prone to catching more dust and/or letting in water etc in the speaker? 6. What difference do cables make in installation and listening? Thanks in advance. - N |
| | #201 (permalink) | ||||
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
It is reconstituted wood held together with phenolic resin. Quote:
A LOT! Read what Gunbir and others have written on the subject in the forum. Signal (RCA) and speaker cables can make or mar a good system.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||||
| | #202 (permalink) | ||
| Senior - BHPian | Quote:
![]() Quote:
See what the yeti has to say : http://www.team-bhp.com/forum/produc...tml#post384355 (Wiring kit comparison :)) http://www.team-bhp.com/forum/diy-do...ick-wires.html (So.... why do we need those thick wires??)
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson Last edited by s0uljah : 21st January 2008 at 21:26. Reason: how can I forget links :p | ||
| | #204 (permalink) | |
I have in my car will try posting pics of the same. The advantage is that they need very little power to play loud enough. Also they have very fast transients. One would need very powerful and fast midbass to accompany them. They give very good stage with a perfect center but the stage would not be wide enough. Few horns have a peak at some freq but not all are similar sounding. And yes they are expensive affair. About 50k a pair. A more detail write up... EliteCarAudio.com : Your one stop resource for mobile audio and electronics on the net.
__________________ 156.6 db, naa....time is coming to cross it...... | |
| | #207 (permalink) | |
| BHPian Join Date: Jun 2007 Location: Kochi
| Question 1. Quote:
What I want to know is, what is the concept of "bridging" in the above quote? Question 2. Crossover - the concept of separating output from a HU / amp into bass, midrange, etc, is done by a filtering mechanism, right? And this filtering mechanism is usually a copper coil, right? Question 3. How does a HU/ Amp drive a speaker? Constant voltage with varying output current? Or constant current, varying voltage? Question 4. Why is nobody speaking of "impedance matching" here? I am absolutely noobie to theoretical electronics; but I have read that devices / circuits should have matching "impedances" - like a 4 ohm impedance output should be connected to speakers with 4ohm impedeance, etc. Hence, my understanding was that we need to look at output power of the sound source (HU/amp), and also its impedance, and find speaker(s) of matching power AND impedance. PS:- Off for a couple of days - so please do not any responses from me till saturday.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq | |
| | #208 (permalink) | ||||
this picture should explain it better ![]() picture taken from here Lenard Audio - Education - Amplifiers. go through it if you have lots of time and are curious. Link courtesy Navin Quote:
very simply put , the coils block high frequencies , and pass low frequencies so usually you will find them in series with the mid bass to remove the high frequencies. You might also find them in parallel with a tweeter because it makes the low frequency signals pass through it instead of the tweeter. a capacitor does the exact opposite, they pass HF , and block LF. so you'll find them in series with tweeters , and in parallel with woofers. Resistors are used to attenuate the signal, and sometimes in conjunction with the inductors /capacitors to set the cutoff frequency of the filter Quote:
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 8th July 2008 at 23:55. | ||||
| | #209 (permalink) |
| Senior - BHPian | In Pioneer HUs, I've came across an setting called COMP(compression) that helps to adjust the playback quality. What's the utility of this setting ?
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| Thread Tools | |
Similar Threads | ||||
| ICE for my RS | redsfx | Ask the Gurus | 13 | 19th September 2008 16:39 |
| iS my ICE OK? | sandyrocks | Ask the Gurus | 11 | 27th November 2007 11:58 |
| Ice!!! | vivekiny2k | Ask the Gurus | 15 | 14th August 2007 16:58 |
| Need your help on ICE....Please!!! | shiv | Ask the Gurus | 3 | 4th May 2007 20:51 |
| Car Glossary needed on Team-Bhp | navdeep | Technical Stuff | 6 | 8th March 2007 09:05 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
