Thread Tools
Old 27th June 2006, 09:52   #46 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by delu
Here is my 2 cents..... I tried not to duplicate items already described with an exception where I felt needed.....
Thanks just a word of caution. IF these definitions are extracted from another website or publication you should state that. If you need to edit your post accordingly PM me and I'll do the needful. Ok?
__________________
Scixelsyd Etinu
Old 27th June 2006, 09:59   #47 (permalink)
Sam Kapasi's Avatar
Originally Posted by khanak
what are "2 way" and "4 way" speakers?
The objective of a co-axial speaker is to deliver (in absolute laymans terms) all the bass, midrange/vocal, and treble.
This cannot be faithfully achieved by one single speaker.
When you use 2 different kinds of speakers in tandem to do this work, it is called 2 way. 3 speakers in tandem will be called 3 way and so on.
The number of ways do NOT make a speaker better. In fact 4 and 5 way speakers (coaxial speakers for cars) are generally a commercial gimmick designed to fool you.
The objective is not to count the number of "ways" - the objective is for your speaker to reproduce all the different frequencies of the music.
A well designed 2 way, or 3 way coaxial speaker can achieve this result quite well.
Also, i have found that the 4 and 5 way speakers often do not really add any quality to the sound. In many cheap car speakers often the "super tweeter" is either just a cosmetic farce or a piezo-buzzer.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 27th June 2006, 15:50   #48 (permalink)
khanak's Avatar
Another Question - What is sound stage? nd sound imaging?
__________________
Adhish आधीश् ஆதிஷ் ادهش
adhish.wordpress.com
__________________
khanak is online now   Reply With Quote
Old 27th June 2006, 21:09   #49 (permalink)
delu's Avatar
Sound stage is basically perception of music and sensing its depth, height and width when you listen to it. Think of a stage where different instruments are placed at different positions, distance and height now when you listen to it you can feel their actual direction and positioning even if you close your eyes. This has very close relation to imaging which is the capability of your system to reproduce each and every instrument as positioned at the time of recording. A sound stage is created through a sound image.
Now let the experts take from here.
__________________
There's a typo in this sentence, but it slides away when your eyes move toward it.
delu is offline   Reply With Quote
Old 27th June 2006, 23:58   #50 (permalink)
Vivekphadnis's Avatar
And these piezo tweeters produce that "keech keech" sound that i just hate. When I bought my Pioneer 5750 the shopkeeper told me to buy the Pio 6991 or 6990 or some such 5 way coax. The tweeters and mid on top looked like an alien with three eyes. The sound, to say the least, was bull. So like Sam said, go for good 2 or 3 way "well-designed" coaxes.
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Old 7th July 2006, 00:27   #51 (permalink)
luvjascha's Avatar
Default Sub and Amp expln.
Guys, I am a total novice to audio jargon; hence, kindly bear with me.
What are Subs and Amps? What do they do?
Are they required while installing a sound system in a vehicle?
Won't the HU and the speakers do the job?
__________________
HONK IF... you love silence.
luvjascha is offline   Reply With Quote
Old 7th July 2006, 01:07   #52 (permalink)
kb100's Avatar
BUddy Luv... Please refer post # 1 of this very thread!
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 7th July 2006, 01:11   #53 (permalink)
luvjascha's Avatar
I have!! But that doesn't explain anything or what their individual functions are.
__________________
Old 7th July 2006, 01:25   #54 (permalink)
kb100's Avatar
AMP = AMPLIFIER - like the word says it AMPLIFIES the signal it receives - in this case from the HU - and feeds the speaker stronger signals... this is most times very good!
HU = HEAD UNIT - you know that!
SUB/SW = SUB-WOOFER (speakers that produce only low requencies usually less than 100hz) .. Then there are MIDBASS - that reproduces frequencies from about 75 hz till about 900 hz ... and MIDRANGE - that reproduces frequencies between about 900hz till about 3khz (or more). .. and TWEETERS - to reproduce high frequencies above that! If you use all of htem you technically have a FOUR WAY system!! ... you can also have a three way and a two way... ONE WAY??.. that is called FULL RANGE - YEs.. you get them too... not very popular though!
5. MONOBLOCK = Amplifiers with a single channel of amplification - usually used to drive subs.
To answer your other question... YES an HU and speakers can do the job... and even in speakers you get all the above choice and a couple! - but an amp and sub make the sound more complete - you kid of hear it like it was recorded - presuming of course you have a combination of equipment needed to reproduce all the frequencies...
Use the search function and Read up...Am sure you will get the hang of things midway thru the 100th thread...
__________________
Old 8th July 2006, 14:37   #55 (permalink)
Sam Kapasi's Avatar
Default Why a 4 channel amp?
A lot of Audio Innocents have no idea what a 4 channel amplifier is and why they need it.
Here is a typical example of a 4 channel amplifier and it's usage. For example this amplifier give out 150W per channel and 600W when bridged. Numbers vary, depending on the amplifier you use.
Thanks to Tobias Runge for these slides.
__________________
Live the YetiLife®
Old 8th July 2006, 14:39   #56 (permalink)
Sam Kapasi's Avatar
Default How is an amplifier connected?
Thanks to Tobias Runge for this slide too.
__________________
Live the YetiLife®
Old 8th July 2006, 15:40   #57 (permalink)
low_bass_makker's Avatar
gud .. good sam my man.... here is from my side about bridged install
http://www.bcae1.com/bridging.htm
__________________
156.6 db, naa....time is coming to cross it......
Old 11th July 2006, 18:29   #58 (permalink)
shuvc's Avatar
What is GAIN ?
My active sub has a control for it.
__________________
PIGZILNKILJBSCOMB
Old 11th July 2006, 18:31   #59 (permalink)
Sam Kapasi's Avatar
Well, put very simply, a gain functions pretty much as a volume control.
However in simple terms, gain is generally a master volume control that you set and forget and then you change the volume using the volume control on your HU.
__________________
Live the YetiLife®
Old 11th July 2006, 18:36   #60 (permalink)
thats is right sam
here is some thing from my side.....
http://www.bcae1.com/gaincon2.htm
I love the above site is it very well explained .......
__________________
Thread Tools
iS my ICE OK? sandyrocks Ask the Gurus 11 27th November 2007 11:58
ICE - Santro Vino_David Ask the Gurus 15 7th September 2007 10:09
Ice!!! vivekiny2k Ask the Gurus 15 14th August 2007 16:58
Need your help on ICE....Please!!! shiv Ask the Gurus 3 4th May 2007 20:51
Car Glossary needed on Team-Bhp navdeep Technical Stuff 6 8th March 2007 09:05
Powered by vBulletin
