| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jul 2006 Location: Hyderabad as of now
| Hi, When an HUD is sold as "with three pre-amped outputs" and a"sub-woofer control" what does that mean? Am not very sure what this jargon means.....
__________________ 1984 Yamaha RD350 2000 Mitsubishi Lancer GLXI |
| | #2 (permalink) |
| BHPian | A pre amp out is nothing but an RCA output which is used to connect amps to head units. Typical 3 Pre out head units have Rear, Front and Subwoofer outs. The Subwoofer out/control is to adjust the level of output the Amp receives from the head for the sub. This is typically to adjust it to suit different listening preferences and it comes very handy switching between genres of music which need different levels of bass. Hope this helps, some people will be able to elaborate more. ![]() |
| | #4 (permalink) |
| What's the big deal though? I need an amp for a standard HU.. and I need an amp for an HU with a sub-woofer control... so how does it make a difference? What kind of an amp will be needed to connect to such outputs if I want to power a sub and 4 four-way speakers? THe HU itself should be able to support the 4 speakers right?
| | #5 (permalink) | |
| BHPian | Quote:
| | #6 (permalink) |
| Senior - BHPian | ok so what if you set the low pass filter on the amp at about 100 Hz and then for some reason while driving you want it at say 63 Hz or 80 Hz. if you change it from the head unit will it make a diff >> as in will it switch to the desired freq or continue to be at 100 hz regardless of the HU LPF ?? Rev
__________________ Revin Beyond Limits !! |
| | #7 (permalink) |
| Distinguished - BHPian ![]() | Wow, so much confusion. Katalyst, let me try and clear it up for you. In one way, you are correct. A pre-out, is a pre-out regardless of what it says. You run a line-level wire (what we call an RCA cable) from this pre-out to an amplifier. This principle stands true for all genres of audio, car, home etc. Yes, correct again, the HU can definitely support 4 speakers, but the quality and power of the amplifier inside the HU is limited. You cannot compare it to the power and quality of a dedicated amplifier. The various kinds of pre-out only come into existence when using multiple amplifiers, OR multiple channels of amplification (sometimes in one body, like a 4 channel amplifier) Now, what's the big deal with various kinds of pre-out, you say? It's like this. Let us say you have an HU with ONE pre out. And let's say you want to run front and rear speakers off an amplifier. You will have no control over the fader. OR for example, if you had a subwoofer and 2 speakers running off a 4 channel amplfier, BUT your HU had only one pre-out. How would you adjust the level of the subwoofer? Different recordings have different needs.3 Now consider this. You have a 4 channel amplifier for your 4 speakers and a 1/2 channel amplifier for your subwoofers. You may need to fade betweeb speakers. You may need to increase or decrease the subwoofer level independently. For advanced users, you may need to change the low pass frequency, or invert the phase. There are a lot of things you can control using your HU, for which otherwise you would have to crawl into the boot of your car. Therefore if you intend to use amplifiers and subwoofers, it is always better to get a head unit with front and rear pre outs PLUS a subwoofer out. I hope this helps you. If it doesn't please send me some naked dancing girls on a flight to escort me to hyderabad and I'll offer you a better explanation in person.
__________________ Live the YetiLife® |
| | #8 (permalink) |
| thanks guys... i understood the basic concept.. (i think..... ) So...... I have the HU with the pre-amp outputs and a sub controller I have two 4 way speakers It sounds great But i need 1) A sub 2) An amplifier 3) 2 more 4 way speakers My understanding - the four 4 way speakers would be a bit dodgy on just the in built HU amp. So i might need TWO amps? Step one would be to get an amp and sub combo - what kind of an amp would I need for this? Thanks a ton of helping me with the basics guys ![]()
| | #9 (permalink) |
| Distinguished - BHPian ![]() | You have 4 way speakers in the rear I assume. You will need front speakers, no not 4 way lol. If it's your lancer, you will need 5.25" speakers, preferably a component set. So yes, like you said, you will prolly need 1 4 channel amp for your speakers and another 2 channel or monoblock (preferred) to drive your subwoofer.
__________________ Live the YetiLife® Last edited by Sam Kapasi : 26th February 2007 at 01:06. |
| | #11 (permalink) |
| This is the HU http://www.kenwoodusa.com/products/L...k3=172&pr=2707 I went with this because: 1) I have been extremely satisfied with the performance of my current Kenwood HU (quite dated though) 2) I wanted a USB interface 3) I wanted to be able to use my current 10cd changer ![]() The HU looks kinda average - but then its the performance that I want ![]()
| | #12 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | I think it's a good HU with some nice features. Congrats on your selection. I would agree with Sam. Get a 4channel amp to power your speakers and get a monoblock or a 2 channel amp to power your subwoofer. Please get some decent component speakers for the front and a 6.5" coax for the rear. Match the output of speakers or preferably, get both of same brand/series. Get a decent sub and put it in a sealed enclosure. LPF can be set at 63hz or 80hz according to your pref. For speakers and sub, I would prefer JBL, Hertz and alpine. For amp, I would suggest JBL, pioneer and Alpine. Ofcourse if money was not a problem, then Audison! Spend some time experiencing different brands in the market and select what your ears (and in between) feels comfortable with. Enjoy! And share your install pics here.
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( |
| | #15 (permalink) |
| THanks guys.. Satish - how does the coming weekend sound? I don't see my install happening till Mid - March. I will however postup as soon as it is done ![]()
| Thread Tools | |
Similar Threads | ||||
| Help needed for a Vtec Controller | ssjr0498 | Technical Stuff | 5 | 2nd April 2008 13:28 |
| Alpine Sound Field Controller 3342 | gopz | Ask the Gurus | 10 | 10th September 2007 18:51 |
| Music Controller steering on Zen | nicejits | Modifications & Accessories | 1 | 18th July 2007 17:45 |
| For Sale VtecMivec Controller & Dual Stage Shift Light | viper | Shifting gears | 0 | 9th February 2007 09:57 |
| IBM Raid controller Card Required | Ford Rocam | Gadgets, Computers & Software | 0 | 26th November 2005 14:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
